Page 1 of 2
TunerPro Update
Posted: 2021 Feb 26, 13:27
New tunerpro update to fix some buffering limitation issues.
tunerpro downloads-
http://tunerpro.net/downloadApp.htm
direct link-
http://tunerpro.net/download/SetupTuner ... 0_9290.exe
Re: TunerPro Update
Posted: 2022 Mar 31, 14:13
TunePro updated 1-11-22
Re: TunerPro Update
Posted: 2022 Apr 03, 01:31
by dleach1407
I downloaded the latest update. When downloading from a QH directly to a file, it no longer retains previous settings. For 1 bank ecus you have to manually set the addresses every time to 00000 and 0DFFF to get it to download without an error. The default 56k setting errors out unless you enable advanced settings and change the memory addresses. I also had to follow your getting started tutorial to set it back up LOL. I wish it read and retained settings when upgrading
after using the compare feature, setting the address as I listed above doesnt get a good tune. It appears to be corrupted based on the compare feature so I cant figure out how to download from the QH directly to a file
Re: TunerPro Update
Posted: 2022 Apr 04, 10:35
Re: TunerPro Update
Posted: 2022 Apr 05, 02:25
by dleach1407
Im not using a jaybird. I am plugged directly into the QH. I get an error when using the default 56k settings. I tried to use the settings for the jaybird using the advanced settings but those also didnt work.
Re: TunerPro Update
Posted: 2022 Apr 05, 08:10
must be a big in the new update
can i remote in and take a look with teamviewer?
Re: TunerPro Update
Posted: 2022 Apr 05, 14:23
by wwhite
dleach1407 wrote: ↑2022 Apr 03, 01:31
5.00.9503.00 (General Release) (12/22/21)
Note: this build will reset your settings
Re: TunerPro Update
Posted: 2022 Apr 05, 14:24
by wwhite
decipha wrote: ↑2022 Mar 31, 14:13
5.00.9513.00 (General Release) (1/11/22)
Fixed issue where copying and pasting into multiple cells in a table resulted in incorrect values being pasted
Further optimized table editing when (for example) copying and pasting into the table, stepping, and executing table editor functions
Re: TunerPro Update
Posted: 2022 Apr 05, 15:24
by dleach1407
decipha wrote: ↑2022 Apr 05, 08:10
Yeah, i can install teamviewer. Let me know when you want to do it and I will make sure to make myself available. Im in Colorado
Re: TunerPro Update
Posted: 2022 Apr 05, 15:27
by dleach1407
wwhite wrote: ↑2022 Apr 05, 14:23
I knew it reset the settings. I went back in and configured it. The previous build did not require anything other than click the download button when downloading from a qh to a file. I dont ever remember configuring it but there is no where I can see to configure settings other than advanced options every time you use the feature and it doesnt save your setting so the next time you have to remember the memory address... Now no matter what settings I use, I do not get a valid tune. It either downloads and is corrupted or it fails. It may be something I am doing wrong but regardless. I dont think I should have to put in custom settings every time I need to download a 56k tune.
