Electric fan control on Sd4x
Does anyone have sample code and know what pin to use? I'd like to control the fan in software instead of a static temp switch so I can turn it on when AC is on as well. Any guidance is greatly appreciated.
Re: Electric fan control on Sd4x
http://www.efidynotuning.com/foxfan.htm
Duh. Found this but it appears pin 41 is used for the OD switch. Any other ther pins that could work?
https://web.archive.org/web/20070112084 ... nouts.html
if you have an unused digital output just write some code for it
Couldn't you run another relay off the A/C relay?
Then when ever A/C is on, your fans will be on.
If your wanting more control, then do it in software.
I'd like temp control. I started studying the AL9 Fan control code but it's over my head at this point. I am pasting it here for reference. If one of you can help decipher this that would be great. I believe the B2_RE9=0 and BE2_RE9=1 lines are where the output is controlled. I don't understand how that relates to pin 41 or how that would translate to A1C. The orb and an2b opcodes are a mystery as well. Am I even close?
Sub_648c:
648c: 9b,f6,74,00         cmpb  R0,[Rf6+74]
6490: d7,01               jne   6493             if ([941c] = 0)  {
6492: f0                  ret                    return; }
6493: 37,a1,02            jnb   B7,Ra1,6498      if (B7_Ra1 = 1)  {
6496: 20,c1               sjmp  6559             goto 6559; }
6498: 71,df,e9            an2b  Re9,df           B5_Re9 = 0;
649b: 9b,f6,77,b0         cmpb  Rb0,[Rf6+77]
649f: d6,24               jge   64c5             if (Rb0 < [941f])  {
64a1: 9b,f6,76,b0         cmpb  Rb0,[Rf6+76]
64a5: de,21               jlt   64c8             if (Rb0 < [941e]) goto 64c8;
64a7: b3,74,21,42         ldb   R42,[R74+21]     R42 = [29f];
64ab: 9b,f6,78,42         cmpb  R42,[Rf6+78]
64af: d3,17               jnc   64c8             if (R42 < [9420]) goto 64c8;
64b1: a3,74,de,42         ldw   R42,[R74+de]     R42 = [25c];
64b5: 8b,f6,7a,42         cmpw  R42,[Rf6+7a]
64b9: d3,0d               jnc   64c8             if (R42 < [9422]) goto 64c8;
64bb: b3,74,3f,42         ldb   R42,[R74+3f]     R42 = [2bd];
64bf: 9b,f6,79,42         cmpb  R42,[Rf6+79]
64c3: d9,03               jgtu  64c8             if (R42 > [9421]) goto 64c8; }
64c5: 91,20,e9            orb   Re9,20           B5_Re9 = 1; } } } }
64c8: 35,e9,0d            jnb   B5,Re9,64d8      if (B5_Re9 = 1)  {
64cb: b3,f6,71,40         ldb   R40,[Rf6+71]     R40 = [9419];
64cf: 9b,72,ce,40         cmpb  R40,[R72+ce]
64d3: d9,03               jgtu  64d8             if (R40 <= [14e])  {
64d5: 91,08,e9            orb   Re9,8            B3_Re9 = 1; } }
64d8: b3,f6,76,42         ldb   R42,[Rf6+76]     R42 = [941e];
64dc: 7b,f6,6d,42         sb2b  R42,[Rf6+6d]     R42 -= [9415];
64e0: 98,b0,42            cmpb  R42,Rb0
64e3: da,03               jle   64e8             if (R42 > Rb0)  {
64e5: 71,f7,e9            an2b  Re9,f7           B3_Re9 = 0; }
64e8: 9b,f6,6c,b0         cmpb  Rb0,[Rf6+6c]
64ec: da,03               jle   64f1             if (Rb0 > [9414])  {
64ee: 91,04,e9            orb   Re9,4            B2_Re9 = 1; }
64f1: b3,f6,6c,42         ldb   R42,[Rf6+6c]     R42 = [9414];
64f5: 7b,f6,6e,42         sb2b  R42,[Rf6+6e]     R42 -= [9416];
64f9: 98,b0,42            cmpb  R42,Rb0
64fc: da,03               jle   6501             if (R42 > Rb0)  {
64fe: 71,fb,e9            an2b  Re9,fb           B2_Re9 = 0; }
6501: 33,e9,09            jnb   B3,Re9,650d      if (B3_Re9 = 1)  {
6504: b3,f6,75,40         ldb   R40,[Rf6+75]     R40 = [941d];
6508: 99,01,40            cmpb  R40,1
650b: df,44               je    6551             if (R40 = 1) goto 6551; }
650d: b3,f6,6f,42         ldb   R42,[Rf6+6f]     R42 = [9417];
6511: 7b,f6,70,42         sb2b  R42,[Rf6+70]     R42 -= [9418];
6515: 9b,74,3f,42         cmpb  R42,[R74+3f]
6519: d1,05               jleu  6520             if (R42 > [2bd])  {
651b: 33,ea,02            jnb   B3,Rea,6520      if (B3_Rea = 1)  {
651e: 20,06               sjmp  6526             goto 6526; } }
6520: 3a,e9,03            jb    B2,Re9,6526      if (B2_Re9 = 0)  {
6523: 37,c5,04            jnb   B7,Rc5,652a      if (B7_Rc5 = 0) goto 652a; }
6526: 91,40,47            orb   R47,40           B6_R47 = 1;
6529: f0                  ret                    return; }
652a: 3b,ea,0c            jb    B3,Rea,6539      if (B3_Rea = 0)  {
652d: a3,f6,72,40         ldw   R40,[Rf6+72]     R40 = [941a];
6531: 8b,74,98,40         cmpw  R40,[R74+98]
6535: d9,02               jgtu  6539             if (R40 <= [216])  {
6537: 20,14               sjmp  654d             goto 654d; } }
6539: b3,f6,55,40         ldb   R40,[Rf6+55]     R40 = [93fd];
653d: 9b,74,97,40         cmpb  R40,[R74+97]
6541: d9,0a               jgtu  654d             if (R40 <= [215])  {
6543: b3,f6,6f,40         ldb   R40,[Rf6+6f]     R40 = [9417];
6547: 9b,74,3f,40         cmpb  R40,[R74+3f]
654b: db,02               jc    654f             if (R40 >= [2bd]) goto 654f; }
654d: 20,10               sjmp  655f             goto 655f; }
654f: 20,07               sjmp  6558             return; }
6551: 71,df,47            an2b  R47,df           B5_R47 = 0;
6554: 91,40,47            orb   R47,40           B6_R47 = 1;
6557: f0                  ret                    return;
the bidi port register is going to be different for every strategy you have to identify it
in rzasa I wrote some very basic code for fan control. would be significantly easier to just copy and paste it bit youd need to know the port reg
What is your exact hardware code?
I’m hacking SD48 and SD47, have a good understanding of circuit board traces and what caps, resistors are needed to add hardware inputs/outputs and mapping in software.
I have sd48. Pins 13, 14, 15 & 18 are unused afaik
efloth wrote: 2023 Jan 04, 22:15 I have sd48. Pins 13, 14, 15 & 18 are unused afaik
And pin #34, some others, also #12.
So, what I know is #34 is for fuel consumption(Trip Minder), circuit board is missing the PWM chip and some resistors, so the circuit is broken.
From my quick references, pin #12 is for 4x4 low range dash light.
Other options could be utilizing the air injection outputs, pin #51(AIRB) or pin #31(canister purge output), but I think those are PWMs.
I'll go trace pin #12, see if it is actually connected to the CPU, probably the best bet.
Your not driving a 4x4 are you?
Yes it's a 4x4. The archive.org link above has a good reference. I have an e4od so that column gets added in. 34 or 35 any good?
