False VID block?
False VID block?
Unread postby motorhead1991 » Thu May 16, 2019 12:47 pm
I've been mulling it over but I'm not sure how to pull it off.
If you're familiar with OBD2 ECMs, then you know that they have a few lines of text at the tail end of the strategy. What if we ported this to older bins so we could denote modifications and combo information?
If nothing else, I can use a dummy address and just used a comment. (The XDF information doesn't display anywhere IME)
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85
Re: False VID block?
Unread postby 034v » Thu May 16, 2019 1:18 pm
In my 56k defs, I do exactly that. No issues so far.
1996 Mark VIII LSC - Turbocharged/Intercooled/Methanol, Stall, Tuned, Fuel Support, LSD, blah-blah, really fun, wins most. XDF Available
1994 Mark VIII Farm Car - N/A, Manual Air Ride, Exhaust, Tuned, Projector Retrofit, cruiser car, fun, wins way more than before. XDF Available
2009 F-150 5.4L - SCT Tuned for corn by me, pulls well.
034v
Vehicle Information: 1996 Lincoln Mark VIII, SCT and TPRT Tuning
Vehicle 2 Information: 1994 Lincoln Mark VIII, SCT and TPRT Tuned
Vehicle 3 Information: 2009 Ford F150, SCT Tuning
Unread postby jsa » Thu May 16, 2019 1:56 pm
That will work, just keep in mind the checksum address range and calculation.
Cheers
John
Power Poster
EEC-IV GHAJ0 ANTI or COSY
Unread postby motorhead1991 » Thu May 16, 2019 4:34 pm
jsa wrote:That will work, just keep in mind the checksum address range and calculation.
We use code outside of the checksum range for datalogging IIRC. I'll have to look again.
motorhead1991
Unread postby jsa » Thu May 16, 2019 4:50 pm
Yes that is the way to go with logging, however some part of the patch code stills ends up within.
Cheers
John
Power Poster
Unread postby decipha » Thu May 16, 2019 8:48 pm
the patch code has to be in rom in order to execute
but yeah you can take any filler you want and do as you please with it.
on eec-v bank 1 e000-ffff is ram so if you have a 256k full binary you can put notes you want there and it wont matter. Its also out of rom so wont affect the checksum and no poasible way for it to be corrupting anything either if u did use filler that a patch ovewrote elsewhere by some chance.
