QH and Tuner pro
QH and Tuner pro
Unread postby p4ndiamond » Sun May 05, 2019 3:29 pm
I am rather new to Tuner pro software.
I read through the writeup and saw the memory addresses to read from the ECM itself into TP.
How do you choose where to write the tunes to the QH ? I see the write option , but it doesn't show options to write a second tune , to it neither to erase all the banks , since i've been using this one with BE , i wanted to be sure to erase the entire QH to avoid conflicts.
Is this possible in TP and if so how do i do those functions .
p4ndiamond
Vehicle Information: 97 cobra W. Temporary (NPI swapped)
Hi tech stage 2 cams
Vortech V7 JT trim @ 10lb
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
3.73 Gears Detroit true trac
Mac o/r H Borla pro xs 2.5"
Re: QH and Tuner pro
Unread postby decipha » Sun May 05, 2019 8:43 pm
there is no option to choose you simply click write. Tunerpro uses the default QH memory addressing so it can never run off the wrong tune or have more than one preset like BE.
Unread postby p4ndiamond » Sun May 05, 2019 9:04 pm
i see. does it only support 1 tune at a time ?
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby decipha » Sun May 05, 2019 9:15 pm
yes
Unread postby p4ndiamond » Sun May 05, 2019 9:16 pm
other issue i encountered is that the tune did not read properly from the ecu .
I checked it to see and its only corrupt. I went into BE to look at the QH and its untouched as far as the old tune files i had on it.
TP did not appear to write back to the QH . i used the correct memory addresses to read from the ecm .
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby decipha » Sun May 05, 2019 9:49 pm
are you trying to read a cdan4 tune?
2 bank i believe has to used mode 3 tune slot 4 or something along those lines
in be clear the qh ram, select that slot and write your tune
close be open tp, read it and post the file here ill take a look
Unread postby p4ndiamond » Mon May 06, 2019 3:17 am
RZASA MAV2 ECM
Was trying to read its ecm . this is what it got.
Any attempt's to write back seems it does nothing. when i opened BE it had the same CRAIJ0 tune on it. So i cleared it in there. had to shove off to work though . so when i get off ill see what else i can do .
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby RacerX » Mon May 06, 2019 12:27 pm
That bin file is only 16k. Make sure your buffer address has four F's in it. I was getting 16k files instead of 256k because of that. MAV2? That's a Marauder isn't it?
RacerX
Vehicle Information: 2004 Mercury Marauder
BMD0, SCT PRP, TunerPro w/Moates QH
Unread postby decipha » Mon May 06, 2019 5:44 pm
yep, 04 to be exact. Mike just made a post the other day about getting it. viewtopic.php?f=18&t=3191
Unread postby p4ndiamond » Mon May 06, 2019 6:24 pm
Yup its a sweet car. very clean and rides awesome . new DD.
Let me verify if i had the wrong amount of F's
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby p4ndiamond » Fri May 10, 2019 10:44 am
update.
was able to get it to read and write to the QH so looks like we're in business now.
so TP only supports one tune on the QH ?
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby decipha » Fri May 10, 2019 8:27 pm
yep, no nonsense or questioning what tune or loosing tunes corrupted tunes or running on the wrong tune or any of that crap is possible
Return to EEC-V & SN95 Tuning
