Simplify Timing on SD LUX0
S/D specific subforum for the Gen-1 Lightnings,
88- Tbird/Stang/Lincoln/Mercury, RV's, and Trucks.
Unread postby Mikestang » Wed May 01, 2019 8:44 am
I don't post that much, but do love the tech articles and info here. But I am hoping for some help this time.
I am using a LUX0 with a DA1 Cal. This is in my racecar, only minor some mods, E-cam and HO stock intake and TB (instead of 86 stuff) Long tube headers.
I am looking to simplify the timing tables. The part that says how to disable Altitude Spark and WOT Spark by using the "memory location"... I have no idea how to do this?? Can someone help?
Everyday I learn how much I don't know....
Mikestang
Vehicle Information: 1986 Ford Mustang GT, Sonic Blue
347 Stroker, custom cam, 185 CNC Trick Flow heads w/PAC springs
Trick Flow upper and lower extrude honed
(many more mods...)
Moates QH chip
Binary Editor software w/Innovate software
A3M1
Vehicle 2 Information: 1981 Mustang SCCA A-Sedan car Restored by Me
86 Capri EFI 5.0L Engine
Mostly Stock, F-cam, Valvetrain upgrades, Long Tube headers
DA1 PCM, Using BE and QH with Innovate AFR
Re: Simplify Timing on SD LUX0
Unread postby decipha » Wed May 01, 2019 9:45 am
You have to get the sailorbob lux0 definition file
Unread postby Mikestang » Wed May 01, 2019 10:41 am
decipha wrote:You have to get the sailorbob lux0 definition file
I already got that file from him. Car is already running and racing. I have already dyno tuned it for the most part, I just want to simplify timing so I don't have to change it in multiple tables. I am also re-wrtting the Columns in FN070 so I can get better resolution where the engine is operating and adjust VE higher than 4000.
I see the write up is for GUBF, but wont most of these changes still work with LUX0?
Mikestang
(many more mods...)
Moates QH chip
A3M1
Unread postby decipha » Wed May 01, 2019 11:26 am
yep lux0 is basically the same
Unread postby Mikestang » Wed May 01, 2019 11:42 am
ok...
So this is the part I do not understand how to do,
The memory location to disable the altitude table is:
0x3713-0x3714 [+0x2000 intel offset] opcode DECIMAL: 484 (stock) to 404
How do I get to/modify from the Memory Location? I dont know what this is, or how to make a change in this location.
Mikestang
(many more mods...)
Moates QH chip
A3M1
Unread postby decipha » Wed May 01, 2019 1:46 pm
thats not for your strategy thats for gufb only
u have to contact sailorbob and ask him nicely to add the hack in
Unread postby Mikestang » Wed May 01, 2019 2:36 pm
decipha wrote:thats not for your strategy thats for gufb only
Ok, well bummer. Is there any other work arounds? I have not looked, but is there a delay I can set to max to keep it out of the WOT timing tables? A way to have it not switch between Sea Level and High Alt table?
Mikestang
(many more mods...)
Moates QH chip
A3M1
Unread postby motorhead1991 » Wed May 01, 2019 6:43 pm
This is the hack that decipha is referring to. It basically modifies the code so only the sea level table is used. On the strategies that I work with the base table is already disabled thanks to a function
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85
Unread postby Mikestang » Wed May 01, 2019 9:54 pm
Humm, I tried to open it several times, only the top 1/4 of the pic loads, something on TunerPro is all I can see.
Ill probably just Email SailorBob tomorrow and see what he says. I can keep tuning the way I have been but Road racing brings about a lot of throttle movement, it would be easier to tune the way later Ford PCM's are set up
Mikestang
(many more mods...)
Moates QH chip
A3M1
Unread postby mustangdriver » Tue May 14, 2019 2:46 pm
...do you mean this? 3 Tables?
Ich schreibe in deutsch weiter, bevor der google übersetzer Mist übersetzt :D
Mach einfach die 3 Tabellen gleich und taste dich an die beste Leistung, ohne das der Motor klopft, heran.
Gruß
my english is not good, but my Mustangs are top :)
mustangdriver
Vehicle Information: 87 LX convertible 2.3 FB1 5 speed manual FB1
Vehicle 2 Information: 79 V8 347cui
Edelbrock Heads, Carb, Manifold, V2a Headers, X-pipe, 340HP
Unread postby motorhead1991 » Tue May 14, 2019 9:52 pm
mustangdriver wrote:...do you mean this? 3 Tables?
Gruß
No, the code hack disables the altitude table, and the base table in some tunes. On my preferred strategy, the base table is disabled via a function.
motorhead1991
Return to Speed Density Tuning
