Tune compare
Tune compare
Unread postby streetstallion » Sat Mar 02, 2019 12:22 pm
I would like to compare tunes if anyone has the same mods that I have or close....
This is what I’m running....
- N/A 351, bored .030 over..10.6:1 Compression
- Trickflow R intake
- Canfield heads (29-450-58-0)
- Accufab 75mm TB
- 95mm PMAS slotted MAF (MH95B-3000)
- 4” Anderson powerpipe
- 42lb Ford injectors (part# 280150558)
- Harland Sharp 1.6 rockers
- Compcams 35-518-8, 555/565 lift
- DSS GSX forged pistons
- Accufab adjustable fuel pressure regulator) set at 40psi
- Walbro 255lph fuel pump
- Crane Fireball Ignition box
- Fireball coil...
- Autolite plugs, gapped to 0.45
streetstallion
Premium Member
Vehicle Information: 89 Mustang GT (Cobra cloned), A9L ECM controlled by Moates Quarterhorse, N/A 351w bored .030 over, Keith Black 11.1 compression pistons, Canton windage tray, Trick Flow R Intake, Canfield Stage II heads, TF 75mm PMAS MH90-3000 slotted MAF, Siemens Deka 80lb EV1 injectors, AEM wideband, Ford Motorsport 1.6 RR, Compcam 35-518-8 (555/565 lift), BBK longtubes, h-pipe and Flowmaster Super 44s, TKO600 tranny and 3.55.
Re: Tune compare
Unread postby decipha » Sat Mar 02, 2019 8:03 pm
the two closest canfield headed tunes i have done on your strategy ecu to compare to aren't even remotely close
the closest is back in 2011 he had a 347 dart block with the same canfield heads, 9.3 cr ba5000 maf 80lb injectors edelbrock intake 22lbs boost. Dual precision 76mm turbos so its not going to be even remotely close to yours as far as doing an a/b comparison
and the other closest is from back in 2011 as well he had a 331 a4 block 8.5 cr b451 cam gt40 lower 60lb inj 60lb cal maf and a 2.1 kenne bell at 14lbs so his is going to be even farther from yours
everything else is 400+ strokers nitrous etc... have done a few on cbaza similar to yours but wont be able to compare to being a different strategy
best bet is to just dial in what you have, what issues are you having specifically? If you'd like post your current tune and I'll take a look to see if anything is amiss.
I have attached your last tune from back in 2017 modified for your 42lb injectors and 4" Anderson powerpipe so you can do an exact a/b comparison. That was back before you presumably swapped in the Traction-Lok 31 spline carrier and axles which won't affect anything but just for reference. Back then you didn't have the power pipe and you had 80lb injectors in her so if you do write this tune to the ecu it probably won't be too happy until its dialed in.
this was your fuel error when you put that 4" powerpipe in
550 0.86
500 0.92
475 0.95
450 0.91
425 -
400 0.88
375 0.86 - 0.93
350 0.90
325 0.85
300 0.86
275 0.89
250 0.97
odd thing was that once it warmed up the fuel errors went to zero which lead me to believe you had fake 80s, where did u get them injectors do u remember?
anywho, attached
Re: Tune compare
Unread postby streetstallion » Sun Mar 03, 2019 11:53 pm
I really don’t remember, maybe TREPerformance....but I could be wrong.
Like I told you before, the issue I’m having is that my injector data is not correct I don’t think, because the data seems to be for 24lb injectors and have 42s. It runs fine but I don’t think she runs like a modded 351. She feels like my old 302. Maybe it’s just me. I’m gonna send you a pm, there’s something I need to tell ya.
I’m gonna text you my current injector data with the 42lb injectors I’m running.....
I’m also sending my MAF Transfer data for the current MAF I’m running.....
streetstallion
Premium Member
Re: Tune compare
Unread postby decipha » Mon Mar 04, 2019 7:34 am
ah yes treperformanxe doea not sell siwmwns injectors just knock off fakes
Return to EEC-IV Tuning
