Return style fuel system
All 2005+ Vehicles, including the 2000+ Lincoln LS, 2002+ Explorer, 2002+ Thunderbird, 2004+ F150, 2011+ Mustang 5.0L Coyote
Unread postby NxCoupe » Sat Feb 23, 2019 10:35 pm
What needs to be changed in the tune to allow a return style fuel system to be used? I did the injector changes in the tune, setting them to 1. However, I was not able to find any switches or parameters concerning the variable returnless fuel pump. Any input would be appreciated. Thanks in advance.
NxCoupe
Vehicle Information: 2012 5.0 6 spd, on E85, offroad pipe, GT500 mufflers, just started tuning process, gained 40 rwhp over stock so far.
Black with black interior, base model, built shortblock.
SCT Xcal4, using Advantage to tune it.
Vehicle 2 Information: 1992 Mustang Coupe, coyote 5.0, turbo, 5 spd, race car build in progress. Used to run in NMRA Real Street, now building it for NMRA Coyote Modified
Vehicle 3 Information: 1993 Calypso Mustang Coupe, 5.0 no options, strip down coupe. Only has auto and cruise, didn't even come with a radio, lol. Future plans are to put a Windsor with an On3 turbo kit and an AOD with a brake.
Additional Vehicles: 1993 2.3L 5 spd Mustang coupe, future turbo 2.5 build.
Moates chip, BE tuned
GSS340 pump
Spec Stg 3 clutch
V8 T5 with custom input shaft, billet shifter
8.8 rear end with 3.55 gear, 4 wheel disk
V8 front spindles and brakes,
V8 sway bars front and rear
CC plates
FRPP cockpit adjustable shocks and struts. Soft to race with the flip of a switch!
Have 57mm turbo, Stinger header, ebay blow off and waste gate purchased so far.
Re: Return style fuel system
Unread postby decipha » Sun Feb 24, 2019 12:05 pm
keep everything just as it is, go set the deltap multipliers back to what they should be
simply wire up the current fuel pump wiring to your fuel pump relay and set the fuel pump voltage table to all 12s
then disable the adaptive fuel pump voltage correction
Unread postby NxCoupe » Mon Feb 25, 2019 4:55 am
Thank you! It actually started and ran without any codes, but I just want to make sure he won't have anything down the road is why I asked.
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby NxCoupe » Sat Mar 09, 2019 6:46 pm
It ended up having codes. I made the changes you listed and it worked great. I had a few codes to shut off for other stuff, but car ran great.
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Sat Mar 09, 2019 7:00 pm
what codes did it throw?
Unread postby NxCoupe » Fri Mar 15, 2019 6:54 pm
I will go back thru my notes and list them.
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Return to CAN Tuning
