1994 f150 Speed Density 351w
Unread postby wwhite » Fri Feb 01, 2019 6:28 pm
Hi,
I am needing to tune my SD, have a catch code of K1D1.
I have spoke with Moates about getting Quarter Horse, but said that there is no software for my truck.
I am assuming that my ECU is similar to Gen1 lightning, but not positive.
I see that LHBL0 - '93/96 covers a variety of Lightnings and other trucks, as well as 89-95 F-Series S/D EFI-SD4X strategies exist.
Truck is having E4OD trans rebuilt, headers, intake and cam added.
Do I need a different computer?
Really want to keep SD.
Can I read stock bin/def on ECU on the bench, then use that with QH?
ECU image below:
Thanks in advance.
Vehicle Information: 1994 Ford F150, SD KID1, TunerPro-RT, QH
Vehicle 2 Information: 1964 M100 460
Vehicle 3 Information: 1964 Meteor 390
Additional Vehicles: 1978 Alfa GTV spica
Re: 1994 f150 Speed Density 351w
Unread postby decipha » Fri Feb 01, 2019 9:05 pm
what is your hardware code on the ecu sticker?
Unread postby motorhead1991 » Sat Feb 02, 2019 12:22 am
decipha wrote:what is your hardware code on the ecu sticker?
While we're on the subject, I'm going to PM you about something I came across today.
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85
Unread postby wwhite » Mon Feb 04, 2019 11:25 am
Is this the hardware code you are looking for: EFI-SD48B ?
Here is an image of the ECU:
Unread postby motorhead1991 » Mon Feb 04, 2019 12:43 pm
EFI-SD48 is the one he's referring to, and I actually copied a tune from one of it's sister ECMs on Friday.
motorhead1991
Unread postby wwhite » Mon Feb 04, 2019 12:52 pm
This sounds promising. Did you copy the tune while the ECU was in the truck or on the bench?
Unread postby decipha » Mon Feb 04, 2019 4:46 pm
yes thats the same hardware code can use the base files and xdf from the homepage and tune it no prob
Unread postby wwhite » Mon Feb 04, 2019 5:32 pm
OK, excellent. And Quarter Horse is the tuning hardware of choice?
Unread postby decipha » Mon Feb 04, 2019 5:58 pm
its the only choice
Unread postby wwhite » Wed Feb 06, 2019 3:07 pm
Quarter Horse ordered. Next question:
Stock setup has narrow band O2 sensor(single), Can or will a wide band O2 sensor work? is it required? Can dual wide band O2 work with Speed Density and Quarter Horse?
I will be putting on headers, where I can relocate the single narrow band.
But, if wide band works, or better yet dual wide band, I would like to know.
Unread postby decipha » Wed Feb 06, 2019 6:27 pm
a wideband is just for info in open loop conditions (startup and wot) the narrowband does all the real work.
the wideband doesnt interface with the ecu its just for logging to know the actual lambda
u can toss dual widebands on it if u like not rly necessary tho. I run dual widebands on my truck but its just for nothing else piece of mind.
Unread postby wwhite » Sat Feb 23, 2019 8:09 pm
OK, received QH in mail, installed in truck no problem.
Read stock ECU, no problem.
A couple of issues and questions.
First my K1D1.bin differs quite a bit from the stock 89-95 F-Series S/D EFI-SD4X PLOO.bin, probably expected.
Browsing via hex editor, and looking at disassembly, the hex value for "Engine Displacement" is in a different location between the two bins.
K1D1.bin from 1994 351w SpeedDensity shows Engine Displacement value of 0xaa7f (7faa).
PLOO.bin shows Engine Displacement value of 0x9c7f (7f9c) for 351.
I have not written the .bin to QH yet, I am trying to learn and understand everything first.
From the comparison of my read bin (K1D1) and the stock one posted on download page (PLOO), these to me appear completely different.
So, question:
Will this PLOO bin actually work with my hardware?
With a different catch code, can a bin be completely different from stock, where it accesses different memory registers etc., running a completely different program with different scalars, etc.?
After writing PLOO.bin to my hardware, I can assume it now has a catch code of PLOO, is this the correct way of thinking what is going on?
Unread postby decipha » Sun Feb 24, 2019 12:02 pm
correct your stock tune file is useless
Return to EEC-IV Tuning
