Getting Started... tuning my cbaza car
Re: Getting Started... tuning my cbaza car
Unread postby pancakeshake » Mon Mar 04, 2019 2:00 pm
decipha wrote:youfn513 the wot threshold doesn't use TP it uses TPREL so at closed throttle TPREL should be 0
1000-150 == 850 TPREL at WOT
...to 550 @1300 RPM (400+150 = 550 TP REL, correct?)...
Ok so 400 TP REL = 550 TP in my case. I guess I just typed that in backwards.
decipha wrote:lambse gets pulled from perload, so whatever perload your at it gets yanked from the base fuel table, everything is interpolated
So regardless if you are in OL or CL, fuel is interpolated via the base fuel table? I guess there is no reason for it not to be. I am just double checking to see if there is some scalar somewhere that changes fuel values when I enter OL.
pancakeshake
Vehicle Information: '83 Capri: 351w Roller, 3550, Intercooled 70mm On3, GT40X, F303, Shootout EFI, 60# Deka, BA5000, McLeod 75307.
Current: Chipped T4M0, 503/573. Runs between 9.5-11.5 for AFR.
Project: QH tune with TunerPro, add IAC, cleanup my cold start issues, smooth out tune
Unread postby decipha » Mon Mar 04, 2019 6:04 pm
instead of all the confusion and calculating just stop logging TP and log TP_REL
correct, 400 TPREL + 150 RATCH == 550 TP
no in closed loop the o2 sensors control fuel there is no adjustment for closed loop since the lambses swing to make the o2's switch
if your running a base t4m0 tune then yes there is modifiers to commanded fuel, the t4m2 has it simplified
post your tune and i'll take a look to help you out specifically
Unread postby pancakeshake » Wed Mar 13, 2019 10:33 pm
We got some snow last week, just got back on the road today.
So, on steady half throttle pulls I start seeing high 15's into the 16's as I get above 2.0 MAFV. I am seeing this consistently on my wideband. The problem is im not getting consistent results in the data log. I'll hold and log 2.5 MAFV on one log and get 1.04 fuel error, and then 1.23 error on the very next attempt.
I assume that because my wideband is ready consistent (and reading lean) I should add some fuel there.
Question: If my KAMS read "1" during a good pull, what does that mean? Ill see a few different values, then a bunch of "1's" right in a row.
I posted a few logs here. Not sure if you can see anything. The "2.5" and "2525" are both short logs of me pulling up to roughly 2.5 MAFV and holding it there. The "dr1" and "dr2" are 3rd gear steady pulls. I was trying to climb to redline, but saw 16 AFR and lifted on each attempt.
pancakeshake
Unread postby decipha » Wed Mar 13, 2019 11:34 pm
your severely rich and need to lean it out, i don't see anything your talking about in those 2 logs i looked at, they both show your wayy too rich
Unread postby pancakeshake » Thu Mar 14, 2019 3:13 pm
pancakeshake wrote:So, on steady half throttle pulls I start seeing high 15's into the 16's as I get above 2.0 MAFV. I am seeing this consistently on my wideband. The problem is im not getting consistent results in the data log. I'll hold and log 2.5 MAFV on one log and get 1.04 fuel error, and then 1.23 error on the very next attempt.
decipha wrote:your severely rich and need to lean it out, i don't see anything your talking about in those 2 logs i looked at, they both show your wayy too rich
Oops I did the math wrong. My calculated error is showing rich now.
Ill start with the factory MAF data again and re-work my curve tonight.
Just to make sure im clear... REDUCING the airflow (kg/hr) column on the MAF curve REDCUCES fuel. Correct?
Is there any reason why I am seeing between 1%-5% rich at 1.99 MAFV and 10%-13% rich once I tip over 2.00 MAFV?
pancakeshake
Unread postby decipha » Thu Mar 14, 2019 5:41 pm
I edited your posted to reword the self insults which are discouraged here lol
honest mistake no harm no foul, at least you learned and won't be doing that again
no, reducing the maf reduces the airflow (airmass) not the fuel. It does however reduce the air to fuel ratio effectively leaning the engine out though.
your fueling is inconsistent because your maf needs to be dialed in. If after you get your maf dialed in you have inconsistent AFRs at a given mafv then your injectors would need to be dialed in. But first you must dial in the maf assuming your injectors are genuine siemens deka 60s. If you have fake injectors which are pretty common being that the siemens injectors are the most copied injectors ever made then you will find you won't be able to get your fueling consistent and accurate.
Unread postby pancakeshake » Fri Mar 15, 2019 10:09 pm
decipha wrote:your fueling is inconsistent because your maf needs to be dialed in.
Ok, so once I realized that I was doing some incorrect math I decided to start from scratch. I used the factory provided data for the MAF flowrates/voltages. I went out for a drive and held my MAFV at 1.5, 1.75, 2 and 2.25. I did two "pulls" for each voltage value and used the data logs to calculate my fuel error (Lambda-LAMBSE+KAM).
The (Pre-Mod) data logs are with the factory flow data. The (Post-Mod) data logs are after I did the MAF curve corrections using the fuel error calculation mentioned above.
Pull1(Pre-Mod).xdl - Average fuel errors for each MAFV value.
1.50 - 1.120
1.75 - 1.154
2.00 - 1.136
2.25 - 1.100
Pull2(Pre-Mod).xdl - Average fuel errors for each MAFV value.
1.50 - 0.995
1.75 - 1.012
2.00 - 1.007
2.25 - 1.051
Pull1(Post-Mod).xdl - Average fuel errors for each MAFV value.
1.50 - 0.837
1.75 - 0.925
2.00 - 0.943
2.25 - 0.888
Pull2(Post-Mod).xdl - Average fuel errors for each MAFV value.
1.50 - 0.824
1.75 - 0.911
2.00 - 0.939
2.25 - 0.940
On my steady pulls (Pre-Mod) data logs I had a fuel errors between 10%-15% then on the very next attempt I had fuel errors between 0%-5%. Both LEAN.
On my steady pulls (Post-Mod) data logs I had fuel errors between 6%-17% then on the very next attempt I had fuel errors between 6%-18%. Both RICH.
So...
- (Pre-Mod) logs don't agree. They seem very different between the two pulls.
- (Post-Mod) logs agree. They are pretty close at each MAFV point.
I feel like i'm missing something in this process. The Lambda-LAMBSE+KAM in CL seems very straight forward and I feel like I understand why it works and i'm doing the math correct now. Why is my fueling so erratic?
I posted the logs. They are short, but if anyone can see anything funky in there let me know.
Thanks in advance!
pancakeshake
Unread postby decipha » Sat Mar 16, 2019 12:50 am
i dont understand why your doing all this extra work and making a very simple task extremely difficult
it should take no more than 10 seconds to get the fuel dialed in. Simply hold a set mafv point for 10 seconds and let it stabilize. The fuel error gauge will tell you exactly how much u need to correct. Make the correction and go back to that mafv point and it should be perfect. If it isn't then something is wrong and you have other issues.
Unread postby gamh44 » Sat Mar 16, 2019 8:18 am
pancakeshake
Just looking at one of your logs it looks like you are not holding steady at any MAFV points, rather running, quite steadily I might add, though from around 1.5 to 2.5 MAV.
As decipha says, you need to hold the MAFV at a constant value (say 1.5V) for around 10s then move to the next MAFV point. It is easiest to just use the MAFV values that are in your MAF Table.
Then, there is a FE% value that TPRT calculates for you. It is on the EEC IV dash at least. Rather than picking data off the dash though, TPRT can display History Tables (two icons to the right of the Show Data Dash icon). If you record a log of a bunch of steady MAFV runs, play the log with the HIST_MAF Table open and set the View to Running Average. The values will give you the FE% at each IMAF point (convert to VMAF as required).
Once you have this, you can go back to the MAF function and multiply each point (airflow) by the FE%. Next time you do a run at that MAFV value, the FE% should be 0, or at least a lot closer to.
Of course, this is just a summary of decipha's notes on the Custom Tuning Step 1 of 3 page.
Good luck.
gamh44
Vehicle Information: Cobra replica. 302 HO from Mustang. 8LD ECU with chip. Massflo (Pro-M) EFI. Trickflow heads and cam. QH Jaybird and F3v2 chip. TunerPro RT.
Unread postby decipha » Sat Mar 16, 2019 5:40 pm
thats what I do. Thats why I wrote the histogram and put the fuel error gauge in there.
No need in making things more difficult
Unread postby pancakeshake » Wed Mar 20, 2019 2:45 pm
So too keep things short, I started logging and using the "Fuel_Error" to adjust my fuel rather than the "Lambda-Lamsbse+KAM" method. It seems to work better. However, I am still having problems getting things dialed in on the road. I might just try and get to a dyno and rent it for an hour.
Anyway, is there a chance someone can take a look at the attached log? This is a drive after I was able to get 0-2.0 MAFV dialed in pretty decent (I think). You can see I'm having major issues with any WOT stab. I just go insanely lean instantly.
pancakeshake
Unread postby decipha » Wed Mar 20, 2019 5:46 pm
the fuel error is the same thing, if you calculated it correctly you would arrive at the same value since thats what the fuel error gauge is doing
its very unwise to use a dyno to dial in closed loop, you have to simulate driving on a road much better off actually driving it on a road rather than pretending to
by it leaning out linearly its obvious you have a major fuel supply problem, most like a bad pump or a clogged fuel filter
Unread postby pancakeshake » Thu Mar 21, 2019 2:22 pm
decipha wrote:the fuel error is the same thing
Ill check that tonight and verify my setup.
decipha wrote:its very unwise to use a dyno to dial in closed loop, you have to simulate driving on a road much better off actually driving it on a road rather than pretending to
Noted. Ill continue street tuning it.
decipha wrote:by it leaning out linearly its obvious you have a major fuel supply problem, most like a bad pump or a clogged fuel filter
So I have a brand new pump and filter installed from only 50 miles ago. However, I agree that it could be fuel delivery related. See that attached logs. These show steady MAFV holds at 1.50, 1.75, and 2.00. On the 1.5 and 1.75 logs you can see the fuel error stabilizes and remains constant for 20 seconds without any sign of moving. The 2.0 MAFV test shows the fuel error dip, and continue to dip, after only 8 seconds or so. More MAFV, more fuel needed, and its going lean.
Thoughts?
Anyone know of a clever way to data log fuel pressure using a pressure gauge?
pancakeshake
Unread postby decipha » Thu Mar 21, 2019 7:21 pm
no thoughts needed, I wasn't telling you what I think I was telling you whats wrong, you have a major fuel supply problem.
Unread postby pancakeshake » Fri Mar 22, 2019 8:15 am
decipha wrote:no thoughts needed, I wasn't telling you what I think I was telling you whats wrong, you have a major fuel supply problem.
Well at least this explains my frustrations while trying to figure out fuel at higher RPMs. Thanks!
pancakeshake
Unread postby pancakeshake » Mon Apr 15, 2019 11:05 pm
Back again!
Took a break from the car for a bit but I finally got my fuel pressure transducer installed so I can "log" fuel pressure.
I used my data acquisition block to log the data from the pressure transducer I installed, then did an overlay to my logged data I wanted to examine.
You can see in the graph below, my fuel pressure only fluctuated +/- 1 psi during the pull. I am vacuum referenced and the fuel appears to to what it should do. Under heavy vacuum the fuel pressure drops about 4psi from what it is under heavy load and low vacuum.
The fuel pressure holds pretty steady yet I am still seeing a good sized fuel error start to develop as the pull continues. I have included a few data logs of me holding a few MAF points. I'm not sure if you can draw any other conclusions using those.
I cant draw ANY conclusion from this. My 1.5 and 2.0 MAFV pulls look fine and my fuel error doesn't take off like it does when I do a light, smooth pull. All of this while my fuel pressure stays consistent. I am running a 340 aeromotive pump, -8AN feed line up to a -6 wye AT the rails. Each rail has a feed with each rail feeding the regulator. All with a -8 return.
15.xdl : Holding MAFV at 1.5 volts. Looks pretty good. No fuel error developing late in pull
2.xdl : Holding MAFV at 2.0 volts. Looks pretty good. Small fuel error developing late in pull
25.xdl : Holding MAF at 2.5 volts. Looks pretty bad. Starts decent then the fuel error jumps way off.
Fuel Check_Pull.xdl: Steady pull from 1.25 - 2.25 MAF. Fuel error starts moving at about 1.6 MAF then really starts diverging around 1.7 MAF.
pancakeshake
Unread postby decipha » Fri Apr 19, 2019 8:19 pm
going by what you said (not looking at logs) I would guess you have bad injectors. where did you get your injectors from?
Previous
Return to EEC-V & SN95 Tuning
