Quarter horse no data
Moates specific forum for all Burn2, Jaybird, J3, F3, Road Runner, QH, etc... related issues
Unread postby Bonk1070 » Fri Nov 30, 2018 8:12 pm
Just got my quarter horse using tunerpro rt have the dash board up but cant get any data to populate
Bonk1070
Vehicle Information: 1965 mustang 1989 5.0 eec-iv quarter horse tuner
Re: Quarter horse no data
Unread postby Bonk1070 » Sat Dec 01, 2018 12:15 am
Ok in the bottom left of the screen it looks like it is reading data from the ecm but how do you get the gauges on the dashboard to work any help is appreciated
Bonk1070
Unread postby decipha » Sat Dec 01, 2018 4:16 am
did u follow the getting started write up on the homepage?
Unread postby Bonk1070 » Sat Dec 01, 2018 8:54 am
I did went back over them again found a step I didn't do the search for univ when I did it there is no files found not sure what am doing wrong
Bonk1070
Unread postby decipha » Sat Dec 01, 2018 9:07 pm
did u download the latest xdf and adx from the homepage here? search datalogging instead of univ
Unread postby Bonk1070 » Sat Dec 01, 2018 10:48 pm
Yes got downloads here searching datalogging worked but when I double clicked on the patch the box game up current data state says error
Bonk1070
Unread postby Bonk1070 » Sat Dec 01, 2018 11:14 pm
Ok got the patch applied now tunerpro screen shows DA Connected and I see it is getting data I believe but my dash board still isn't populated do I have to select the pids that I want to see on the dashboard if so how do I do that thanks for the help
Bonk1070
Unread postby decipha » Sun Dec 02, 2018 6:54 am
no thats the beauty of tunerpro is requires no user input you simply click log and it goes
what is the xdf name and date and the adx name and date your using?
Unread postby Bonk1070 » Sun Dec 02, 2018 11:24 am
Got the files here http://www.efidynotuning.com/downloads.htm
Were would I find the log tab at
Bonk1070
Unread postby decipha » Sun Dec 02, 2018 11:29 am
at the top of tunerpro what does the adx and xdf say? dates?
Unread postby Bonk1070 » Sun Dec 02, 2018 11:37 am
Xsf file- gufx_180124 adx file-decipha_eec-iv_qh_20171109.adx
Bonk1070
Unread postby Bonk1070 » Sun Dec 02, 2018 11:40 am
The bottom of the screen says
Emulating hardware quarterhorse v1.6q 8.12hz errors0 da:connected
Bonk1070
Unread postby Bonk1070 » Sun Dec 02, 2018 11:41 am
The hz are jumping around
Bonk1070
Unread postby decipha » Sun Dec 02, 2018 12:41 pm
that means its polling
and u have nothing on the dashboard?
Unread postby Bonk1070 » Sun Dec 02, 2018 12:47 pm
No
Bonk1070
Unread postby decipha » Sun Dec 02, 2018 12:56 pm
and you have the datalogging patch enabled?
can you post your current tune file
Unread postby Bonk1070 » Sun Dec 02, 2018 2:34 pm
mustang3.bin
Bonk1070
Unread postby decipha » Sun Dec 02, 2018 5:14 pm
why is it 64kb ?
Unread postby Bonk1070 » Sun Dec 02, 2018 5:46 pm
When I uploaded the 56kb none of the numbers for the tables were right I looked it up said tunerpro uses 64kb and u have to pab the file for it to work
Bonk1070
Unread postby Bonk1070 » Sun Dec 02, 2018 5:48 pm
I went ahead and tried my 56kb tune and still no dash board
Bonk1070
Unread postby decipha » Sun Dec 02, 2018 8:22 pm
where r u getting that info no where did i write 64k
post your 56k tune n ill check it out
Unread postby Bonk1070 » Sun Dec 02, 2018 10:23 pm
mustang1.bin
Bonk1070
Unread postby Bonk1070 » Tue Dec 04, 2018 2:39 pm
Was wondering if you have had a chance to look at my 56kb file. I'm new to all of this so sure there is something that I'm not doing right to get the dashboard set up. Thank you for your help.
Bonk1070
Unread postby stangman86gt » Fri Dec 07, 2018 10:09 am
adx isn't patched.
ctrl+f then type in adx. Will see universal adx datalogging patch.
but here is your bin with it patched if you just wanted to do that.
stangman86gt
Vehicle Information: 1986 Mustang gt
quarterhorse a9l2 gufx using tunerpro rt
Unread postby Bonk1070 » Fri Dec 07, 2018 8:45 pm
my fuel pump just stays running with that bin
Bonk1070
Unread postby motorhead1991 » Fri Dec 07, 2018 9:26 pm
What is this tune based on? I wonder if the strategy is messing up the checksum
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85
Unread postby Bonk1070 » Fri Dec 07, 2018 11:46 pm
Strategy guf1 box code A9P
Bonk1070
Unread postby stangman86gt » Sat Dec 08, 2018 10:28 am
ahh i assumed you were running a9l2 and gufx sorry
stangman86gt
Unread postby Bonk1070 » Sat Dec 08, 2018 6:01 pm
So my with my setup I cant do datalogging
Bonk1070
Unread postby motorhead1991 » Sat Dec 08, 2018 7:19 pm
Bonk1070 wrote:So my with my setup I cant do datalogging
Anything can be datalogged if you're skilled or tenacious enough... I can datalog a '90 Ranger computer :roll:
motorhead1991
Unread postby Bonk1070 » Sun Dec 09, 2018 11:22 am
went to the download page and tried to download the a9l2 bin but it tells me web page cant be displayed does anyone know where I can get the a9l2 bin
Bonk1070
Unread postby motorhead1991 » Sun Dec 09, 2018 12:33 pm
I have one, just give me a couple minutes to put a zip thgether
motorhead1991
Unread postby motorhead1991 » Sun Dec 09, 2018 12:43 pm
motorhead1991 wrote:I have one, just give me a couple minutes to put a zip thgether
http://developer-aa51.com/EEC%20Tuning%20Info/A9L2.zip
motorhead1991
Unread postby Bonk1070 » Sun Dec 09, 2018 1:34 pm
thanks
Bonk1070
Unread postby decipha » Mon Dec 10, 2018 7:39 pm
i fixed the link on the homepage as well, thanks for reporting it
Return to Moates Devices & QuarterHorse
