help finding strategy for S0M box code.
Unread postby maik21 » Tue Nov 27, 2018 8:35 pm
i was searching without lucky trying to find strategy for box code s0m.
thankyou very much.
maik21
Vehicle Information: mustang 2003, 4.6, 2v,roush stg 1, xsh1/RYAF1, tunerpro rt5, moates quarterhorse, no catalitic converters.
Re: help finding strategy for S0M box code.
Unread postby Landho » Tue Nov 27, 2018 9:49 pm
Following - I have two of those from some Bronco’s I harvested parts out of ... Speed Density for 351w... couldn’t find what I needed either to use them for tuning. Ended up with a D9S, then MAF w/ A9L, and now t4m0
Landho
Premium Member
Vehicle Information: 1969 Ford Bronco - decipha tuned.
Dart 347 stroker, forged internals, Dart Iron Eagle heads, b303 cam, scorpion 1.6 rr, T4M0 EEC, Shorty headers (for early bronco),2.5" to y-pipe, 30# injectors, Ported Explorer gt40-ish style intake w/ 2" plenum spacer, PMAS HPX w/ 3" blow tube. no smog. Innovative MTX-L2 wb o2, QH, TunerPro.
wbo2-b
Vehicle 2 Information: 2017 Jeep Rubicon, 4.5" lift, 35" tires - boring!
Unread postby decipha » Tue Nov 27, 2018 9:53 pm
efi-sd3xx is the hardware code
if its a v8 u can try loading a efi-sd4x cal on it off the homepage
whats it out of ?
in any case, any strategy for that is going to be catch code specific. There is none that i know of for that ecu and will most likely never be any made for it.
Unread postby Landho » Tue Nov 27, 2018 10:24 pm
I pulled mine from mid 90’s Bronco’s with 351w and auto trans ... think they came in some e & f250 4x4’s as well
Landho
Premium Member
wbo2-b
Unread postby motorhead1991 » Tue Nov 27, 2018 10:40 pm
Pull a copy of the binary, I'd be happy to add it to the pile of tunes I'm already tinkering with.
motorhead1991
Unread postby maik21 » Wed Nov 28, 2018 1:45 am
i didnt have the car right now but i can borrow it in a few days to download binary.
its a bronco with 351w. they put a camshaft and now there is black smoke out from exhaust and low mpg. its an auto trans too.
maik21
Unread postby maik21 » Wed Nov 28, 2018 1:48 am
decipha wrote:efi-sd3xx is the hardware code
whats it out of ?
i will take a look. thankyou.
maik21
Unread postby maik21 » Fri Nov 30, 2018 9:52 pm
S0M BIN
maik21
Unread postby maik21 » Fri Nov 30, 2018 11:19 pm
wich could i use to test from SD4:
- C3P2.BIN
- C3P3.BIN
- ICY1.BIN
I see this engine hasnt MAF sensor or maybe i dont see it.
maik21
Unread postby motorhead1991 » Sat Dec 01, 2018 12:03 am
This binary is similar to EFI-SD2xx, so this should be fun
motorhead1991
Unread postby motorhead1991 » Tue Jan 22, 2019 11:00 am
Progress is slow going since I don't have SD2x very far along either, and both are superceded by my work on m0m2.
I do have it started though.
motorhead1991
Return to EEC-IV Tuning
