CBAZA Datalogging Code Testing - 18/11/08
Unread postby decipha » Thu Nov 08, 2018 8:57 pm
any cbaza users want to test out some datalogging code?
I have attached an xdf and an adx, there is 3 steps to testing this
first and foremost load in both the adx and xdf and be sure you have your current tune open then
If you are using the 2 step code disable it first
1> Enable the Restore Knock Routine patch code
2> Enable the Restore Console Code patch code
3> Enable the Datalogging Patch code
then save the tune as _test.bin and write it to the qh, once it writes start polling open the dash and turn the key on and see if it comes to life, hit the throttle and verify its reading if all works as expected fire it up and start recording the log, go for a short drive and stop the log and post it back here
do not use the disable datalogging patch or anything else this is only for testing the new datalogging patch code
Re: CBAZA Datalogging Code Testing - 18/11/08
Unread postby decipha » Sun Nov 11, 2018 3:11 pm
<file deleted>
everything works perfectly verified by premium member
will be posting new cbaza xdf and adx tonight
Return to EEC-V & SN95 Tuning
