another erased ecm
another erased ecm
Unread postby p4ndiamond » Tue Oct 02, 2018 1:08 pm
Not sure what's going on. But I use the mongoose to do my loads on my eec v. It's a 1998 cobra Aol3.
I plugged up to it the obd 2 port and USB on the computer and asked be to write to the ecm. It did not detect it and fans and pump were running. This is normally how it starts out for a load. So I power cycled the key to prepare the erase and write. Keep in mind it has not touched the ecm yet. The fans still came on and the pump. So I unplugged the USB and obd2 from the car with the key in the off position. And now the ecm behaves as if it's bricked or erased.
Not sure what happen since the mongoose never wrote or erased anything. Is their an idea of what's happening I need the car so I wrote to an f3 moates to continue driving. The issue makes no sense.
As you know i had another ECM also the DDX4 one that did this also but it was never using the mongoose its always been the QH. it continuously would not work or run without a chip in the J3 port.
Suddenly one day that ECM just works without anything in the J3 port after more than a year of not doing so. What the hell . lol .
Its a confusing and strange issue but i come to a final question here. If the issue is that the ECM data on the ROM is somehow corrupt etc. is their a way to push firmware to it even if the mongoose does not detect these ECM ? i have bin files i can push back onto them .
p4ndiamond
Vehicle Information: 97 cobra W. Temporary (NPI swapped)
Hi tech stage 2 cams
Vortech V7 JT trim @ 10lb
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
3.73 Gears Detroit true trac
Mac o/r H Borla pro xs 2.5"
Re: another erased ecm
Unread postby decipha » Tue Oct 02, 2018 9:24 pm
impossible to brick a ford ecu they flash over hardware not software
yea, just force a write, if your using pcm flash select recovery in settings and u can write anything to it
if the software your using wont let u manually select the ecu type or do a forced write then your SOL
if you try to access any upper level aice functions while the j3 port is overwritten then your aice chip will go in to lala land and u have to remove power from the ecu to reset it. Its happened to me a few times when i go to flash or read an ecu not knowing it had a chip on the j3 port.
Unread postby p4ndiamond » Sat Jan 05, 2019 9:09 pm
interesting ill have to check this out when i get home. Where can i get PCM flash from ? since i am using BE the files are in BEB form . can i get a bin reading from the J3 chip and then force a flash so that i keep the associated token ?
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby decipha » Sun Jan 06, 2019 1:20 pm
pcm flash - http://www.efidynotuning.com/started.htm
pcm flash doesn't currently support flashing 2 bank ecu's though
I have no idea I have not used binary editor is some years since clint remotely disabled my dongle one day
Unread postby ironmanisanemic » Tue Jan 08, 2019 10:02 pm
p4ndiamond wrote:interesting ill have to check this out when i get home. Where can i get PCM flash from ? since i am using BE the files are in BEB form . can i get a bin reading from the J3 chip and then force a flash so that i keep the associated token ?
Had an ecu get erased on me due to an error in BE. BE will say it doesn't detect an ecu if you try to reflash it, but will give you an option to do a recovery reflash. Unfortunately it costs an additional token. Maybe contact Clint or Adam and see if it's something they can help you recover since it may have been an error on the BE side. They covered the additional token in my case since it was the softwares fault.
ironmanisanemic
A+ Contributor
Vehicle Information: 89 Ford Bronco - 393W, Professional Products 190cc heads, Custom Comp Cams hyd roller cam, Edelbrock EFI Mustang intake, 10:1 compression, 30lb TrickFlow injectors, ProM 80mm Mass Air Meter, 2-1/2" into 3" y pipe, no cat, and hooker aerochamber muffler. U4P0 computer with Quarterhorse and BE, EA. AOD with all of the goodies.
Return to EEC-V & SN95 Tuning
