SCT Advantage III
SCT Advantage III
Unread postby cedrich100 » Thu Sep 06, 2018 3:29 pm
Hi all, I'm new to tuning with the SCT Advantage III. SCT did a god job with loading the "value files". I loaded the value file foe my 60lb injectors, SCT BA 2600, and Base blower tune. It runs with a lot of back firing. Any suggestions? or directions?
cedrich100
Vehicle Information: 1996 ford Mustang GT, 2V 4.6 PI Heads, Victor Jr intake, 6061 Elbow, 60lb Injectors, 75mm Accufab, , forged pistons, rods, and cobra crank, XE- 274-ah comp cam. long tube headers
Re: SCT Advantage III
Unread postby decipha » Thu Sep 06, 2018 3:43 pm
the value files are just to get you going you still have to dial it in, go ahead and get your fuel situated first the fuel write up on the homepage will give you the specifics
Unread postby cedrich100 » Fri Sep 07, 2018 10:02 am
Do you have a base fuel table for 60lb injectors. Also I read the write up you have about Fuel injector hi-slope and low-slope, but for my injectors I have a high slope of 0.0166 in the write up you said it should be 60. can you expound?
cedrich100
Unread postby Paulie » Fri Sep 07, 2018 10:22 am
cedrich100 wrote:Do you have a base fuel table for 60lb injectors. Also I read the write up you have about Fuel injector hi-slope and low-slope, but for my injectors I have a high slope of 0.0166 in the write up you said it should be 60. can you expound?
SCT has their injector parameters in lbs/sec while Decipha has them in lbs/hr. To convert take lbs/hr and divide by 3600. 60/3600=.0166
Paulie
Vehicle Information: 1990 Mustang LX 5.0, GUFB/A9L, BE/EA, Quarterhorse, HCI, Vortech S-trim 8#, Stock shortblock, FRPP 42# injectors, PMAS MH95, T-5.
Unread postby decipha » Fri Sep 07, 2018 11:11 am
no such thing as a base fuel table for any injector, the base fuel table is just that the commanded lambse, it doesn't require adjustment once you set it correctly regardless of what injector you have
yes as paulie said, sct shows injector slopes in lbs/min instead of lbs/hr
just simply take the data on the homepage and divide it by 3600 to convert lbs/hr to lbs/min
keep in mind for the cdan4 strategy in SCT DOES NOT HAVE THE PROPER SUPPORT TO CHANGE INJECTOR SLOPES
that means, you have to scale your high slope down to the stock high slope value and adjust the breakpoint and low slope with that same scaling percentage
YOU CANNOT CHANGE THE HIGH SLOPE ON A CDAN4 TUNE IN SCT
then adjust the maf by the same scaling percentage and everything else listed in the scaling write up just like you would normally
Unread postby cedrich100 » Fri Sep 07, 2018 3:03 pm
So what you're saying is that I have to use a hi slope of 0.00535 then do what? Sorry, Im not following.
cedrich100
Unread postby decipha » Fri Sep 07, 2018 5:39 pm
correct, scale your tune by that scaling percentage
the scaling write up on the homepage will give you all the info you need
Unread postby cedrich100 » Sat Sep 08, 2018 11:52 am
Is there any way of converting a cef file to mtf for sct? Or is it possible for me to read, open or edit a cef file with prp. I've been doing some reading on the for and it seems like I should have purchased the QH instead of SCT.
cedrich100
Unread postby decipha » Sat Sep 08, 2018 11:58 am
yes its possible but not exactly
you have to load the cef file to your xcal then write the tune to the ecu, plug the QH in and read the bin out, then compare the bin to a stock tune and copy all the changes over to a stock tune file in SCT, voila! you have your cef to mtf conversion
sct works fine no need in getting rid of it if you have it already, just scale your tune and dial it in
Unread postby cedrich100 » Sat Sep 08, 2018 3:23 pm
To make sure im doing this correct, I leave all of the stock 19lb injector setting the same as such: breakpoint: 0.0000100, hi slope: 0.0053500, low slope 0.0065900. Then I used the Scaling airflow percentage, which I have as 1.9805 with a BA2600. For a SCT BA2600 the max was 109 so 109/55 = 1.9805. what does I use the percentage for? I also looked at the fuel percentage and identified that with 60lb injectors I am 315% over 19lb stock injectors. In all the 1.9805 scaling what do I do with that to.
I was also confused to see that with my strategy the highest slope I could use is 42
cedrich100
Unread postby decipha » Sat Sep 08, 2018 7:00 pm
cdan4 hardware only supports up to a 42lb injector slope value, any value you plug in higher the ecu cannot calculate, this is the injector slope clip limit for that processor speed ecu
however, sct does not have access to all of the injector slope parameters to correctly change the injector slope in cdan4 regardless.
incorrect, the only value that remains stock is the injector high slope, you scale down your breakpoint and low slope along with your maf just as the scaling write up states
assuming you have genuine siemens deka 60lb injectors, on the homepage they have a high slope value of 60.267 at 39.15 base fuel pressure.
Assuming you have a stock regulator or using stock fuel pressure, your scaling percentage is the injector high slope difference.
since the stock ahisl in your stock tune is .00535 you simply use that as your scaling percentage for your high slope.
60.267 / 3600 = 0.01674
since you cannot use that value you have to keep your stock high slope value of 0.00535
thus,
0.00535 / 0.01674 == 0.319593 is your scaling percentage you can simply round it off to 0.32 to make it easier to remember
take your actual injector low slope which is 63.187 / 3600 == 0.017551 * your scaling percentage of 0.32 == 0.00561632
thus go set your low slope to 0.00561632 (20.218 lbs/hr)
do the same to calculate your new breakpoint and plug that in
injector offset doesn't get scaled, plug in the actual injector offset from the provided siemens deka data sheet
set minpw to 0.40 in all tunes regardless
scale down your engine displacement (sarchg) and manifold volume by * 0.32
now your left with the maf
take your actual maf curve, with a ba2600 it flows up top as you said 109 lbs/min, take your entire actual maf curve and apply your scaling percentage of .32 then plug that in to your tune
that would make the top of the maf curve 109 * .32 == 34.88
dont forget to adjust the cranking pw by the difference in your injector size (20/60), it doesn't get scaled same as the injector offset its global and actual pw
save your tune and write it, then fire it up and dial your fuel in
as you can see, your telling the ecu you have 32% of the injector size it actually has, then your telling it its only measuring 32% of the air its actually getting.
Thus, your air to fuel ratio is equivalent as it would be if you were not scaled just as the scaling write up describes but yet you don't clip the ecu by using too large of values or in your case corrupt values since sct wont let you change the high slope correctly.
Unread postby cedrich100 » Sun Sep 09, 2018 10:54 am
Thanks so much! I'm new to tuning and you go into more details. I purchased a Engine Management Advanced Tuning book however, you've done a better job explaining the process. Do you have any book or publications for sale? Again, thanks as I try and understand SCT's software.
cedrich100
Unread postby decipha » Sun Sep 09, 2018 1:12 pm
nothing for sale its all free on the homepage
Unread postby cedrich100 » Sun Sep 09, 2018 3:30 pm
Would I have to just increase the MAF curve for boost and timing only correct. Say I'm running 6lb of boost I only touch and add the percentage to the timing and MAF?
cedrich100
Unread postby decipha » Sun Sep 09, 2018 4:26 pm
I have no idea what your trying to ask but no the maf curve has nothing to do with boost, u dial in the maf the same regardless if its in boost or vac idle wot or cruise, the maf curve does not require any different attention for boost if thats what your asking
read the fuel write up on the homepage and you will understand how it all works and how to dial it in properly
Unread postby cedrich100 » Sun Sep 09, 2018 5:07 pm
Thanks, I'm not sure I know what im talking about either. I'll give a read and most likely have some developmental questions.
cedrich100
Unread postby cedrich100 » Mon Sep 10, 2018 6:47 pm
For the MAF Trans Function I am only allowed to change the "#mass/tic. I can not multiply the scale value of .32 by the lbs/min value. Help?
cedrich100
Unread postby decipha » Thu Sep 13, 2018 5:34 am
simply multiply the mass/tic value by your scaling percentage
Unread postby cedrich100 » Sun Sep 16, 2018 10:17 pm
So I did it the way that you described and it doesn't start. However, what I tried was I used the highest MAF value of 64lb and used my sct 2600 maf value of 119 divided it and came up with a scaling value of 0.5378. I used this value and * it by my entire MAF transfer fuction alone with my Fuel injection breakpoint, low slope. I left the hi slope as 0.00535 and it didn't take the .40 and the input remains at .150 as the min PW. I also * the engine displacement by .5378. the engine wants to crank the stock engine displacement id 0.00155. I also couldn't find manifold pressure on SCTs software. IS there anything I'm missing? I tried both your way and the new way and I get nothing.
cedrich100
Unread postby decipha » Mon Sep 17, 2018 4:39 am
I could have told you that's not gonna work, the curve is not the same between your stock curve and the 2600 curve, you need to load in the 2600 curve and scale it down
i have no idea what that means "the engine wants to crank the stock engine displacement"
post your mtf file and when i get a chance i'll go through it and hook u up
Unread postby cedrich100 » Mon Sep 17, 2018 7:25 am
THanks see attached files,
cedrich100
Unread postby cedrich100 » Fri Sep 21, 2018 6:26 pm
Still have some trouble with scaling the variables
cedrich100
Unread postby cj428mach » Tue Sep 25, 2018 4:11 pm
You load the SCT value files for the injectors first then the MAF and SCT automatically scales everything for the MAF file. If you scale again then you'll have double scaled everything.
cj428mach
Vehicle Information: 03 Cobra TVS, ID1000's, return fuel system, e85
Vehicle 2 Information: 37 Ford 351C 4v with A9L
Unread postby Blown38 » Wed Oct 03, 2018 8:52 pm
Is this what you came up with when scaling the BA2600 by .32? EEC analyzer from eecanalyzer.net is useful when the tuning software clips stuff. It has some common maf curves in the software.
5.000---- 34.857
4.819---- 31.039
4.644---- 28.071
4.473---- 25.234
4.292---- 22.545
4.106---- 20.012
3.945---- 17.649
3.770---- 15.464
3.599---- 13.459
3.423---- 11.638
3.247---- 9.996
3.071---- 8.526
2.896---- 7.251
2.725---- 6.074
2.549---- 5.066
2.373---- 4.187
2.197---- 3.430
2.021---- 2.772
1.851---- 2.211
1.675---- 1.732
1.499---- 1.326
1.323---- .989
1.147---- .712
.972---- .495
.801---- .328
.625---- .215
.449---- .152
.273---- .134
.098---- .089
.000---- .000
Blown38
Vehicle Information: 95 Thunderbird SC
EEC IV-CZAW0
Quarter Horse
3.8, 8.5:1, Hyd Roller, 80 lb Siemens, BA2400, 4R70W, 2.0 Auto Rotor 24psi, Kooks long tube, 450/450, 10.74@127
Vehicle 2 Information: 03 Marauder
EEC V
SCT PRP, soon Tuner Pro and Quarter Horse
4.6, 9.2:1, DOHC, 80 lb Siemens, BA5000 5" pipe, Built 4R75W, 3.4 Whipple Crusher 25psi, 2" primary 3.5" collector long tubes, Est 700rwhp, 10.19@133
Unread postby cedrich100 » Sun Oct 07, 2018 6:26 pm
@CJ428MACH I don't know if the value files are scaling the tune for me. Im dumping large amount of fuel, the car is running but my A/f ratio is at 10.8 -11 will running warms.
@blown38, those are the correct values, however I can't get the engine to start when I scale everything by .32. Im lost right now almost willing to just take it to a tuner.
cedrich100
Unread postby decipha » Sun Oct 07, 2018 7:16 pm
if its rich just lean it out
Unread postby cedrich100 » Sun Oct 07, 2018 9:13 pm
I'm UP TO 1 LAMDA ON THE BASE FUEL TABLE, AM I LEANING IT OUT CORRECTLY. ANY SUGGESTIONS?
cedrich100
Unread postby decipha » Sun Oct 07, 2018 9:42 pm
the fuel table cannot dial in fuel its only the fuel commanded
if you have the correct injector data in then go lean out the maf, if its in the 10s just multiply the whole maf by 0.7 to lean it out 30%
Unread postby cedrich100 » Sun Oct 14, 2018 6:30 pm
DECIPHA What did you mean BY:
dont forget to adjust the cranking pw by the difference in your injector size (20/60), it doesn't get scaled same as the injector offset its global and actual pw.
I DONT KNOW WHERE THIS FUCTION IS.
cedrich100
Unread postby cedrich100 » Sun Oct 14, 2018 7:26 pm
So, I think im starting to get there. What I did was read the Scaling 101 write up and did it that way.
I took my MAfs top value of 109 and divided it by 55lb/min and came up with a scaling percentage of 1.9805. I took that value and divided my maf transfer function, air manifold volume, engine displacement, all of the injector hi slope, low slope and pw. it runs okay and my fuel is dialed in. I think im on the right path. I took it for a test drive and its bucking real bad at low rpms. I didn't touch the crack pw yet either.
cedrich100
Unread postby decipha » Mon Oct 15, 2018 12:54 am
in sct the cranking pw function is under crank fuel - crank fuel pulsewidth
manifold volume is under fuel --> scalars
i finally got a chance to look over your tune file, absolutely garbage so much so that i took a stock file and whipped something together for you, attached
youd be much better off starting from this, i looked and could not find the minimum airmass clip scalar in sct, if you keep leaning out the maf and cannot get it to lean out then most likely its clipping that scalar. Thats usually the very first thing i change in all my cdan4 tunes.
Unread postby cedrich100 » Thu Oct 18, 2018 8:43 pm
Decipha, thanks I believe that I have to call sct to allow me to read this tune. I have a GGl4 box code that CDAN48, anyway thanks for the help and support I'll continue to read and change some of the parameters.
cedrich100
Unread postby decipha » Fri Oct 19, 2018 8:36 am
that sucks I thought sct locked prp to the strat not the individual cal
Return to EEC-V & SN95 Tuning
