E85 swap on a 97 Cobra
Unread postby GT_Rich » Thu Sep 06, 2018 11:44 am
I have a ’97 Cobra driveline in an old Mercury Comet that I’ve been running for the past couple years. It’s an autocross car and I’m looking for a little bit more power without adding weight or spending much money. I have decided to give E85 a shot. I swapped out the old 24’s for a new set of 60 lb/hr injectors. I cleaned up the gas tune and I’m ready to drain and fill with E85. I have a good handle on what I need to do for steady state fuel and spark. Are there any transient changes that typically need to occur? Anyone have a template or standard procedure for this? Thanks!
GT_Rich
Vehicle Information: 65 Mustang Vert, A9L, Moates QH, Innovate LM-2 WB
302 w/ TF heads, F-cam, ported GT-40 lower/tubular upper, Vortech T-trim s/c, 60 lb/hr inj, Methanol injection, PMAS HPX blow-thru MAF, 400 lph pump.
Vehicle 2 Information: 92 Mustang GT, A9L, Moates QH, Innovate LM-2 WB
302 w/ TF heads, B-cam, ported GT-40 lower/tubular upper, Powerdyne BD-11 s/c, 42 lb/hr inj, 75 mm Pro-M MAF, 255 lph pump.
Vehicle 3 Information: 95 Lightning, ICY1, Moates QH, Innovate LC-1 WB
393 w/ TF heads, custom cam, GT-40 lower/tubular upper, 30 lb/hr inj, speed density. E4OD trans.
Additional Vehicles: 62 Mercury Comet, LLX4, Moates QH
32V 4.6L, IMRC delete, stock rebuild
Re: E85 swap on a 97 Cobra
Unread postby decipha » Thu Sep 06, 2018 3:46 pm
simply set the stoich afr to your e85 value
kick up the cranking pw 25%
subtract 0.05 lambda from the fuel table in enrichment
shoot mbt spark to it in your case 27 degrees same youd shoot to it with premium fuel
Unread postby SlowBox » Fri Sep 07, 2018 7:17 am
I didn't notice any changes in transient requirements when I used it in my fox. Biggest thing was actually idle spark as odd as that sounds.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Return to EEC-V & SN95 Tuning
