Perfect Cold Idle but Wants to Stall Moving
Unread postby Frank N. Stang » Wed Sep 05, 2018 11:37 am
Hello again,
Chasing one of the last few things with tune. Car idles perfectly on cold start up with good AFR until I try to give it gas to go. Give it gas and it goes full lean, as in not registering on the AFR gauge, and wants to stall. Take foot off gas and it's idling perfectly again with good AFR. Only does this when cold. Have altered the enrichment table and all it does is make the car run richer at idle and will still max out lean and want to stall. Began happening when the SC went on. No issue at all when warm. So if not the fuel enrichment what other settings should I look at? I have searched the forums and could not find anything specific to this. Any and all help appreciated.
Frank N. Stang
Vehicle Information: 1995 Mustang Gt
T4M2/CBAZA
BE/EA
TunerPro RT
Quarterhorse
302, Vortech V1, GT40 Cobra heads, 1.7 Cobra rockers, B-Cam, 47lb Injectors, GT40 Tubular Intake, 70mm TB, 90mm Slot Maf, Shorty Headers, O/R X-Pipe, Flomasters
Re: Perfect Cold Idle but Wants to Stall Moving
Unread postby decipha » Wed Sep 05, 2018 1:19 pm
there are none, if it does as you say then your fuel needs to be dialed in
Unread postby Frank N. Stang » Fri Oct 19, 2018 8:49 am
Went thru fuel again to fine tune. Issue still happened. Logged cold start. It was the initial T4M2 table settings that caused the issue. Car starts cold at 60 degrees. AFR is close to where it needs to be from 0-10 secs and then at 15 secs it suddenly pegs lean at 19 AFR. In the table at 10 secs and 60 degrees the subtractor is 0.25 and at 15 secs and 60 degrees the subtractor drops to basically zero at 0.05. This is the exact time and temp the car drops to 19 AFR. Smoothed that cluster of cells out with a more gradual decrease of the subtractor using the stock T4M0 table as an example. It is now close to where it needs to be throughout warm up and will fine tune soon.
Frank N. Stang
T4M2/CBAZA
BE/EA
TunerPro RT
Quarterhorse
Unread postby decipha » Fri Oct 19, 2018 9:23 am
as i said u need to dial your fuel in still
Return to EEC-V & SN95 Tuning
