Octane switch Spark table
Unread postby neald » Tue Aug 07, 2018 5:41 pm
Hello. I was just wondering how the octane switch (pin 29 in cbaza) when grounded manipulates timing? Is there a spark subtraction table or something? And can it be used to add or subtract timing when grounded? I just realized I have nothing going to pin 29 on my ECM. I am running your U4P2 def on tunerproRt. I just want to make sure I'm not losing spark. I also have future plans to possibly use it as a spark adder with a water/meth system with a water level switch to ground/unground the spark table when there is or isn't fluid Ithe reservoir. Thanks
neald
Power Poster
Vehicle Information: 89' Bronco II
2.9 V6(stock), A4LD
Moates Quarter horse
CBAZA, 05 MAF
Re: Octane switch Spark table
Unread postby decipha » Tue Aug 07, 2018 10:43 pm
spk_oa or whatever its named is enabled when the octane bar switch present is enabled in the tune and that pin IS NOT grounded
grounding that pin turns off the octane bar flag same as plugging the octane bar in on vehicles so equipped
yes u can use it to reduce timing
Unread postby neald » Wed Aug 08, 2018 3:31 pm
Cool thanks. How about using it to add timing?
neald
Power Poster
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby neald » Wed Aug 08, 2018 6:16 pm
I just tried searching for it, but can't find it. Tried searching "spark", "spark bar" , "octane" , "octane bar" and "bar". No luck. Also tried looking at each choice under there Spark folder .
neald
Power Poster
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Thu Aug 09, 2018 6:40 pm
don't know how you missed it, type in octane and its the only 2 that pop up
1 is for the enabled disable switch the other has the value you want it to adjust, its signed so you can add or remove timing
thats in tunerpro
Unread postby neald » Thu Aug 09, 2018 7:08 pm
When I type in octane it says no items found. BTW this is the cbaza56k def if that makes a difference
neald
Power Poster
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Thu Aug 09, 2018 7:39 pm
what date is it?
Unread postby neald » Thu Aug 09, 2018 7:54 pm
Downloaded a few days ago from this website
neald
Power Poster
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby neald » Thu Aug 09, 2018 7:57 pm
Downloaded the file 8/3/18. Right clicked and properties of file say date created is 9/29/15
neald
Power Poster
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Fri Aug 10, 2018 2:56 am
hmm got to be the wrong file ill look in to it
Unread postby neald » Fri Aug 10, 2018 7:07 am
Thanks buddy
neald
Power Poster
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby neald » Sun Aug 12, 2018 3:26 pm
I found the updated def file on the downloads page. The outdated one I got the other day I think was in the getting started write-up.
neald
Power Poster
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Return to EEC-V & SN95 Tuning
