Be2012 2 quick questions
Unread postby adfosterm3 » Sun Jul 08, 2018 2:16 am
Be2012... cdan4 sailerbobs def...
1st question... car is a 96gt with a new edge trans and optical sensor.. what do I need to adjust to fix speedo? Says 30 at 55 and 55 is 80
2. Have file done aside from speedo... can I burn to a chip via jaybird with be? If I can load bin into tunerpro what memory addresses I burn a cdan4 yo? Tried 0000000 to 03fffff with no dice
adfosterm3
Vehicle Information: 1999 Ford Mustang v6 with full 04 v8 swap Fgfb2 strategy, quarterhorse
Re: Be2012 2 quick questions
Unread postby decipha » Sun Jul 08, 2018 12:44 pm
the vss teeth gear needs to be changed physically on the rear of the trans to correct your cluster speedo.
VSBART_RT is vehicle speed reverse calculated from the oss teeth count that the ecu uses to shift. Depending on what year trans you got you may need to update the OSS Teeth count in the tune and dial in nvbase to get VSBART_RT to be accurate. The trans write up has all the details.
Yep you can. For all TunerPro multi bank tunes you have to save the entire image 0 to 3ffff same as a 4 bank. Details are in the getting started write up.
Unread postby adfosterm3 » Sun Jul 08, 2018 10:33 pm
It has no vss teeth... new edge trans.. optical magnet sensor..car originally had the vss but blew up.
When I tried to use tunerpro to burn the bin it just cycled the fuel pump endlessly and clicked when key was turned on
adfosterm3
Unread postby decipha » Mon Jul 09, 2018 10:39 am
did you open the maf to make sure you saved it correctly?
Unread postby adfosterm3 » Mon Jul 09, 2018 11:13 am
I did. Files works when on quarterhorse but if I burn it to a chip it fails.
There something special about opening a .Beb eith tunerpro ir sn easy way to save as a bin instead of beb?
Still trying to figure out getting speedo dialed in with the 99+ trans in the 96... going to try playing with the nvbase. I set OSs pulses per rev to 12 as stated in writeups for 99+ trans
adfosterm3
Unread postby decipha » Mon Jul 09, 2018 12:26 pm
.beb file are for binary editor, tunerpro uses actual tune file .bin's only.
the speedo is not controlled by the ecu
Unread postby adfosterm3 » Mon Jul 09, 2018 3:58 pm
If it's not controlled by the ECU then what the hell do I do since it has an optical sensor like the later cars rather then a gear? Speedcal?
adfosterm3
Unread postby decipha » Mon Jul 09, 2018 11:16 pm
either make a digital converter or buy one, i think dallas speedcal has them iirc
Return to EEC-V & SN95 Tuning
cron
