1987 Bronco 5.0
S/D specific subforum for the Gen-1 Lightnings,
88- Tbird/Stang/Lincoln/Mercury, RV's, and Trucks.
1987 Bronco 5.0
Unread postby YaBoyHalle » Sun Jun 10, 2018 4:35 pm
i've finally got myself another 5.0 project, an 87 bronco that's been sitting for a while. it'll need a good tune up, and i figure i'll put my QH on it too see what i'm working with.
the stock eec is EFI-sd22B Code "GX"
Sailorbob doesnt have anything for this one so i grabbed this from a 92 f150
efi-sd47a "fun1"
but this one looks to be for the 4.9's which is weird, because the truck had a 5.0
anywho, if these don't work i'll have to keep searching
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Re: 1987 Bronco 5.0
Unread postby decipha » Sun Jun 10, 2018 5:31 pm
ive tuned the efi-24x hardware but never the 22
let me know how goes it, and post the bin when u can
Re: 1987 Bronco 5.0
Unread postby YaBoyHalle » Mon Jun 11, 2018 7:51 pm
the earlier GX bin and the FUN1 are attached. Derek said the 47A was for the 4.9, i'm not sure it makes a difference besides the bin when they're both batch fire.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Re: 1987 Bronco 5.0
Unread postby YaBoyHalle » Thu Jun 14, 2018 10:35 pm
i've managed to grab an -sd48B eec now, but now i need to have it run right on a 5.0, consider i think it came from a 351. catch code LAD1
do you have one of your V2 type tunes for this? or at least a stock 5.0 tune that i can tune on the LHBL0 def? that would help set me on the right path.
I've attached the LAD1 bin in case anybody's hoarding.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Re: 1987 Bronco 5.0
Unread postby decipha » Fri Jun 15, 2018 6:11 am
apparently u didnt notice but that xdf and base tune is on the homepage. Tunerpro histogram dials in the VE table for yoy makes it pretty simple.
Re: 1987 Bronco 5.0
Unread postby YaBoyHalle » Fri Jun 15, 2018 8:55 am
i see it now. i get some kind of error trying to download the stock efi-sd4x bin, but the 60ib injector tune was fine.
thanks for the help!
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Re: 1987 Bronco 5.0
Unread postby YaBoyHalle » Wed Jun 20, 2018 7:00 pm
i got the license for LHBL2 from Derek for the sd48B/LAD1 eec
even though it was for a 351 with the dwell controlled tfi engine it actually managed to run well enough to get gas
i've disabled smog and egr (they were already messed up and disabled) to begin with, set it to 302 systems, and a few other small bits.
i don't know what kind of spark i should be feeding her, aren't these the truck head E7's that mustangs got in 87? the numbers seem small, but there's only one table to tune so it should be reliable.
YaBoyHalle
A+ Contributor
~97 hp
~0 hp
Return to Speed Density Tuning
