PSA about BE version 5.136 and Sailorbob Defs
Support forum for all BE and EA related issues
Unread postby ironmanisanemic » Sat Jun 09, 2018 8:57 am
Hello,
Just to inform everyone, a new BE version rolled out recently. As of this writing it breaks compatibility with all of Sailorbobs definitions. So if you use Sailorbobs defs, you will need to stay on version 5.122 or earlier. This appears to be the last version that is still supports Sailorbobs defs. If you also use the CoreTuning Database, i would suggest to make a backup copy of BE to use Sailorbob defs, and another copy that you can keep up to date for the database.
ironmanisanemic
A+ Contributor
Vehicle Information: 89 Ford Bronco - 393W, Professional Products 190cc heads, Custom Comp Cams hyd roller cam, Edelbrock EFI Mustang intake, 10:1 compression, 30lb TrickFlow injectors, ProM 80mm Mass Air Meter, 2-1/2" into 3" y pipe, no cat, and hooker aerochamber muffler. U4P0 computer with Quarterhorse and BE, EA. AOD with all of the goodies.
Return to Binary Editor / EEC Analyzer
