V6 MAF ECM options
V6 MAF ECM options
Unread postby neald » Thu May 17, 2018 1:50 pm
Hello, I'm looking for some ECM options with MAF to control my bronco II 2.9v6. trans control is not important. Important are TunerproRT support(xdf, bin and adx
availability). I can swap repin if necessary. I am currently using a ECM configured for six cylinder operation using BE and Quarter horse. I just want to get away from the BE and bugs and registration. Any ideas would be greatly appreciated.
neald
Vehicle Information: 89' Bronco II
2.9 V6(stock), A4LD
Moates Quarter horse
CBAZA, 05 MAF
Re: V6 MAF ECM options
Unread postby decipha » Thu May 17, 2018 4:16 pm
why do u want to get rid of the speed density setup? Ive tuned them broncos before with no issues.
If your wanting to swap to maf you might as well go coil on plug and spark edis ignition on it. You can make amy ecu work just depends on what all u want to do to get there.
Unread postby neald » Thu May 17, 2018 5:56 pm
How did you tune these? I didn't think there was any support for the bronco II? Remember this is the 2.9 V6 bronco II, the same platform basically as the 2.9 V6 ranger. If TunerproRT has the xdf's, bin's and data logging for it I'm interested.
Im currently running a cbaza eec converted to MAF with a full def configured for 6 cyl operation using B.E. I would like to use a v6 ECM that is supported by Tunerpro. I don't want to go back to B.E. I want to keep it simple but still have MAF and tuning capabilities
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Fri May 18, 2018 5:20 am
I write the support. In fact i just tuned an 89 bronco II v6 w/ a4ld just last month. Yes im well aware of the platform.
If u want to stay maf have it already set up why not use cbaza with tunerpro?
Unread postby neald » Fri May 18, 2018 5:44 am
Oh cool! Last time I was tuning on the vehicle was last summer. None of this was available then. The u4po def didn't have the scalars to enable 6cyl use. I was able to do it with B.E. because I bought the definition that was fully broken out. The one in tunerpro at the time did not have the scalars for it. Are you saying that it will work for me now?
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Fri May 18, 2018 6:31 am
no idea what your talking about, its always been available, all u had to do is ask
just simply read your existing tune off the qh right in to tunerpro and continue on, no need in erasing your current tune or double working yourself
Unread postby neald » Fri May 18, 2018 8:16 am
Oh ok. Didn't know I could do that.
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby neald » Fri May 18, 2018 1:07 pm
If you don't mind me asking, what did you have to tune on a Bronco 2? How did it turn out?
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Fri May 18, 2018 4:00 pm
I dont understand what your asking? I tuned the ecu.
that specific one from the other day was a bronco II swap in to a pinto, he swapped the A4LD trans and all. 42lb injectors, head cam and intake work along with all emissions stuff gone
does that help? I dont fully get what your asking, regardless if it was bone stock you still tune it just as you would anything
Unread postby motorhead1991 » Fri May 18, 2018 4:52 pm
If you give me a couple days, I can grab X1L from a 3.0 (which is MAF/BAP) and see if my def works on it (similar hardware code)
motorhead1991
Unread postby decipha » Fri May 18, 2018 6:46 pm
i don't understand what your trying to do? whats the point in swapping the ecu if you already have one up and running?
Unread postby neald » Fri May 18, 2018 6:50 pm
decipha wrote:I dont understand what your asking? I tuned the ecu.
Asked because I'm curious and that's how I learn. Very nice.
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby neald » Fri May 18, 2018 7:00 pm
decipha wrote:i don't understand what your trying to do? whats the point in swapping the ecu if you already have one up and running?
I may just leaving it and finish the tune. Just haven't much time to work on it and figured a actual v6 MAF ECM would get me closer to tuned state quicker and easier than dealing with B.E. but since you said the full xdf is on the site I'll stick with cbaza.
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Fri May 18, 2018 7:18 pm
all ford ecu's are the same, there's no reason why any one would be more or less optimal for any setup, just simply dial it in regardless
yep dex originally made the cbaza xdf, i took over it use it for the vehicles i tune
Unread postby neald » Fri May 18, 2018 7:45 pm
Just thought of this. My be def is a .cry which I think uses a beb file instead of a bin. Is beb an encrypted bin? So I think I may have to create a new bin for the xdf in tunerpro.
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Fri May 18, 2018 7:56 pm
no
see 10 please posts up ^^ or read the getting started write up
Unread postby neald » Fri May 18, 2018 8:05 pm
Ok. So recap is :
-Open Tunerpro Rt
-load cbaza xdf
-read current emulator bin
-load adx
-Tune as necessary
Am I correct?
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Fri May 18, 2018 8:22 pm
thats it
make sure u grab the cbaza specific adx
Unread postby neald » Fri May 18, 2018 8:41 pm
Got it. Thanks!
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby neald » Sun May 20, 2018 7:54 am
BTW since you tuned on a 2.9 V6. Do you have the stock injector specs? I input guesstimate specs into hi/lol slopes, timing vs voltage and offset. I was also wondering since I have an 05 MAF can I utilize the Incorporated IAT? If so would I need to modify the IAT transfer function in the tune?
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Sun May 20, 2018 8:32 am
its a single slope strategy
ahisl 13.968
minpw 0.702
fn367 - inj offset
15.94 1.063
15.00 1.063
13.00 1.406
12.00 1.688
11.00 2.063
10.00 2.594
8.00 6.656
0.00 7.969
0.00 7.969
yep sure can, i always use the IAT on the maf when available and highly recommend it
nope no need to modify the transfer
Unread postby neald » Sun May 20, 2018 6:01 pm
Awesome thanks!
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Return to EEC-IV Tuning
