OBDII Flashing & DIY Tuning Support 2005 - 2018 Fords
All 2005+ Vehicles, including the 2000+ Lincoln LS, 2002+ Explorer, 2002+ Thunderbird, 2004+ F150, 2011+ Mustang 5.0L Coyote
Unread postby decipha » Sun Nov 05, 2017 11:52 am
well, its about that time for the 2005 and newer ecu's. I've been working on breaking out some def files for more common strats as time permits. I most likely will be doing the 05-10 first although id rather do the 11+ coyotes first as I seem to get a shit ton of them come in prob cuz we make the only bolt in turbo kit, but unfortunately PCMFlash does support reading and writing those just yet. I will be breaking out the 05-10 GTs and possibly more as people request them. Poison of choice is still tunerpro and reading and writing will be done with PCMFlash software from ecutools.
PCMFlash can also be used to read and write EEC-Vs as well. In either case either a Mongoose Pro Ford can be used or the cheaper generic versions.
Will post more details as I start releasing some stuff.
Re: OBDII Flashing & DIY Tuning Support 2005 - 2018 Fords
Unread postby ironmanisanemic » Sun Nov 05, 2017 7:12 pm
Looking at the different modules available for pcmflash and other than the ones that specifically says eec-v and American ford what modules would be needed otherwise? Since this tool seems to originate from Europe, there are a bunch of vehicles in not that familiar with. I'm also seeing some chipset specific modules that look like they might apply. I'm always looking for alternatives to pulling tunes and reflashing. The price of this tool isn't that outrageous either once you know what modules your needing.
ironmanisanemic
A+ Contributor
Vehicle Information: 89 Ford Bronco - 393W, Professional Products 190cc heads, Custom Comp Cams hyd roller cam, Edelbrock EFI Mustang intake, 10:1 compression, 30lb TrickFlow injectors, ProM 80mm Mass Air Meter, 2-1/2" into 3" y pipe, no cat, and hooker aerochamber muffler. U4P0 computer with Quarterhorse and BE, EA. AOD with all of the goodies.
Unread postby decipha » Sun Nov 05, 2017 7:41 pm
see post below
Unread postby decipha » Tue Nov 07, 2017 3:21 pm
I updated the getting started write up to include pcmflash for the newer ecu's, the three modules you'll need I have listed there
modules:
2
21
29
Return to CAN Tuning
