Finally made some passes
Forum for racing results, dyno pulls, track vids, etc... include time slip and/or link(s) to video(s) if you have them
Unread postby Novi347 » Sat Mar 19, 2016 6:46 pm
Ran a bit slower than I expected. Track conditions were a little tough. AD was 3000' ft. The car is very consistent with the C4 trans. My first pass was a 10.91 @ 124, second was 10.92 @ 124. 60ft for both passes was 1.6
Pass one: https://youtu.be/K-f25yGHge8
Pass two: https://youtu.be/ox92irRzioU
Novi347
Vehicle Information: 90GT (original owner- MM&FF's 7/13 readers rides)
CHP 349 Stroked (9.5 to 1 Comp)
R302 Block
Paxton Novi2000 (17lbs at 5800RPM)
Twisted Wedge Heads (Ported by Ben Alameda Racing)
Cobra Intake (Ported by Ben Alameda Racing)
Flowtech Long tubes
H-pipe w/ 23yr old Flowmaster 2 Chamber Mufflers!
Siemen Deka 80lb Injectors
Comp Cam grind #35-775-8
PMAS MH95
C4 Trans
3.55 gears
Snow Meth Stage 2 Kit
BE/TwEECer RT/Innovate
A9L2
Vehicle 2 Information: 92 SSP Coupe
Stock Block 302 (175k miles)
GT40 Heads (3 Bar)
TFS Street Heat Intake
E303 Cam
Long tubes
Nitrous Express Proton Kit (175 shot)
Tremec TKO
Pro M meter
24lb injectors
3.73 gears
A9L
Re: Finally made some passes
Unread postby decipha » Sat Mar 19, 2016 7:11 pm
you get that suspension dialed in with good weather you shouldnt have any problem getting a 10.0 out of her, im sure youve got a good bit left in the tune too i take it?
how much timing were you shooting to her?
Unread postby Novi347 » Sat Mar 19, 2016 11:21 pm
I had quite a bit of load drop up top, so I'm suspecting blower belt slippage. I didn't get a chance to crank the tensioner down This tune was for 21 deg total.
10.0 is the goal!
Novi347
R302 Block
Flowtech Long tubes
PMAS MH95
C4 Trans
3.55 gears
A9L2
GT40 Heads (3 Bar)
E303 Cam
Long tubes
Tremec TKO
Pro M meter
24lb injectors
3.73 gears
A9L
Unread postby Novi347 » Sat Apr 30, 2016 8:58 pm
Took her out again last night but was only able to make one pass due to a blown header gasket. The two changes I made was tightening the blower belt and adding HEET to my meth setup. Previous logs showed that I had quit a bit of belts slip at 5000 rpm. This time round she peaked at 18psi. Also, because of the added heat she ran on the fat side with an A/F of 10.8 vs the previous 11.7. Anyhow, she ran a 10.66@129mph w/ a 1.73 60ft.
https://youtu.be/UQWLd2E3Pd8
Novi347
R302 Block
Flowtech Long tubes
PMAS MH95
C4 Trans
3.55 gears
A9L2
GT40 Heads (3 Bar)
E303 Cam
Long tubes
Tremec TKO
Pro M meter
24lb injectors
3.73 gears
A9L
Return to Racing & Dyno Results
