dec v2 update
Specifics pertaining to the DEC
dec v2 update
Unread postby decipha » Mon Dec 02, 2013 3:34 pm
update for those inquiring and patiently waiting, the time is getting nearer and im pretty much done with the majority of the coding just working out bugs and increasing efficiency (as time permits), I'm very happy with where shes at currently although shes not as complete as I would like, its complete enough I feel I can probably build a a new alpha for 2014
the old beta used 4x 16mhz ic's, since then i've done a significant amount of recoding to upgrade to 2x 84mhz ic's, in doing so i've lost many pins but i've also gained some back since now the DEC only supports 12 cylinder engines natively (down from 20 before), what i mean by natively is that 1 DEC can only support up 12 injectors and 12 ignition coils, now here comes the cool part, i've been working on the code to have two or more DEC's linked together and thus can support up to 24 injectors and ignition coils in sync for 24 cylinder engines or for 12 cylinder engines with dual injectors and/or coils!!!
so now the DEC has 5+ custom user programmable pins:
2+ analog inputs
3+ analog outputs and/or digital in/out
currently, the biggest issues i have and still need to resolve before im happy
> no lcd flat touchscreen - i still cannot find a vendor that can create the screens at a reasonable price with the dimensions I need
> i cant find any manufacturer specific coding info anywhere for the factory clusters and various modules on 1999+ networked vehicles, i suspect the only info i'll get will be from me snooping the can-bus and k-line to manually decipha what its communicating, which im not looking forward to doing anytime soon
Re: dec v2 update
Unread postby wywindsor » Wed Dec 04, 2013 10:30 pm
The touch screen I would look at Zietronics, or Dakota electronics. If not give me a bit. I have a guy working on a dash mounted blue tooth setup for the moates.
wywindsor
Premium Member
Vehicle Information: 1990 fox with a custom eaton m112, tfs 192 highports an afm b4 cam accu fab 1 3/4 long tubes, a9p gufb, 80# siemens inj.9.2 to 1 comp. in a 347
Re: dec v2 update
Unread postby decipha » Thu Dec 05, 2013 1:29 am
Ill do some digging in the morning, thanks for the tip
Re: dec v2 update
Unread postby decipha » Sun Dec 08, 2013 7:24 pm
dakota digital is nice, its almost exactly what im looking for but the price is just a little too steep at $800 per unit
i may be considering a more generic approach, just having a smaller-ish lcd touch screen that can be mounted on the dash or what not, large enough to be useful but small enough not to be a hindrance
Re: dec v2 update
Unread postby Shaker666 » Thu Dec 12, 2013 2:16 pm
Some of the Olimex stuff doesn't look too bad or too expensive for a display board.
'89 supercharged 8.6:1 5.0 Mustang: EEC-IV (GUFB:A9L) with EDIS8
'79 Bronco: 8.5:1 408M EEC-IV (GUFB:X3Z) with EDIS8
'71 Mach 1: RIP, but was CDAN4 on a 10:1 408W
'66 Mustang GT: needs EFI
'00 Mountaineer: 9.15:1 302W EEC-V, EDIS, 4R70W stock
'08 Buell: 10:1 DDFI-3
'09 Buell: 12.3:1 DDFI-3
Shaker666
Name: Manu "Shaker" Singh
Vehicle Information: '89 Mustang 5.0 LX Sport: blown 8.6:1 306 EEC-IV+EDIS8. Ported Vic Jr. heads, LMAF, Accufab 90mm TB, KB 2.2 Blowzilla w/Flowzilla, Deka 80s, AEM dual nozzle water injection, shorty stainless headers into 2.5" X-pipe, dual O2. A9L2 QH tuned.
Vehicle 2 Information: '79 Bronco Ranger XLT: 8.5:1 400 EEC-IV+EDIS8 ignition. Stock heads, LMAF, Ford 65mm TB, Cobra upper, 351W GT40 lower, Ford 24s. Full length headers with 1.75" primaries into 3" Y-pipe, single O2. TwEECed A9L.
Vehicle 3 Information: '71 Mustang Mach 1: Totalled
Additional Vehicles: '08 Buell XB12Ss Lightning: factory 10:1 motor with DDFI-3 control. Drummer exhaust, dual O2 mod, baro mod. DDFI-3 tuned via TunerPro RT.
'09 Buell 1125CR: factory 12.3:1 Rotax engine w/DDFI-3 control. APH Engineering exhaust, K&N air filter, tuned via TunerPro RT.
'07 Mazda 3S: mainly stock, minor suspension and chassis reinforcements.
'00 Mountaineer: 9.15:1 302W EEC-V, integral EDIS8. Stock with exception of 1" TFS intake spacer, cold air intake, and Magnaflow exhaust.
Re: dec v2 update
Unread postby decipha » Thu Dec 12, 2013 2:30 pm
Ill have to dig into it, thanks
Return to Dynamic Efficiency Cognitive
