Binary Request - A4A1
Unread postby ironmanisanemic » Fri Sep 04, 2015 4:36 pm
Hello,
I just got the strategy from Sailorbob for the A4A1 and i need a stock bin for it. I am watching a couple of ECUs on ebay, but until i get one i am wanting to look around and see how this bin was configured.
Thank you
ironmanisanemic
A+ Contributor
Vehicle Information: 89 Ford Bronco - 393W, Professional Products 190cc heads, Custom Comp Cams hyd roller cam, Edelbrock EFI Mustang intake, 10:1 compression, 30lb TrickFlow injectors, ProM 80mm Mass Air Meter, 2-1/2" into 3" y pipe, no cat, and hooker aerochamber muffler. U4P0 computer with Quarterhorse and BE, EA. AOD with all of the goodies.
Re: Binary Request - A4A1
Unread postby decipha » Fri Sep 04, 2015 5:15 pm
cool, I'll post it up when I get to my laptop
you do realize that A4A1 is a cbaza ecu with EDIS correct?
if you want to run a distributor youll have to use the cbaza strategy instead
Unread postby decipha » Fri Sep 04, 2015 6:23 pm
bin file attached to your original post
Unread postby ironmanisanemic » Fri Sep 04, 2015 11:39 pm
I understand that A4A1 Is cbaza with EDIS. Thats exactly why i want to use it. Thank you for the binary.
ironmanisanemic
A+ Contributor
Unread postby decipha » Sat Sep 05, 2015 6:10 am
yea no prob, i'll attach my "A4A2" cal when I get to my laptop
Unread postby ironmanisanemic » Sat Sep 05, 2015 10:23 am
decipha wrote:yea no prob, i'll attach my "A4A2" cal when I get to my laptop
Thats awesome!! I cant wait!! Thank you again
ironmanisanemic
A+ Contributor
Unread postby decipha » Sat Sep 05, 2015 12:29 pm
this is what i have, i still gotta go through it but this is 99% there, follow the same basics as the u4p2 tune write up
Unread postby ironmanisanemic » Sun Sep 06, 2015 10:07 pm
Thank you for the A4A2 bin. What do you think is left to iron out before its ready for primetime? Also, can the A4A1 Strategy be run on CBAZA hardware or is it specific to the A4A1 hardware? If i can get away with just strat swapping with one of my spare T4M0 Processors i would be extremely happy. If not there are a few im watching that are under $50 right now.
ironmanisanemic
A+ Contributor
Unread postby decipha » Mon Sep 07, 2015 5:50 am
A4A1 is the same hardware code as a cbaza automatic ecu
Re: 4 Cyl EDIS
Unread postby vristang » Tue Nov 10, 2015 1:23 pm
Neal, thanks for the link to this thread.
I have been out for a while, so forgive my simple minded questions...
A4A2 is the strategy, correct? No issues with cross-use?
Has the A4A2 successfully run with EDIS?
I assume you confirmed the code was actually there?
A simple bin/strategy change would have saved me a ton of work on my 2.3 EDIS project...
vristang
Vehicle Information: 1990 n/a 351w based project in progress
Vehicle 2 Information: 1987 n/a 2.3 Mustang with CZAJL EDIS conversion. Sent to j/y 10/13
Re: 4 Cyl EDIS
Unread postby decipha » Tue Nov 10, 2015 1:54 pm
a4a2 is the base cal i created, the strategy name is unknown, derek named his strategy file under the a4a1 box code which uses that strategy, he has the complete a4a1 strat for BE if you want to run a cbaza ecu with edis
yes and yes it runs edis from the factory, you still need an edis module though
(the purpose in the other thread was to run an eec-v ecu with edis and coil on plug) << Posts moved here where they belong
Other thread viewtopic.php?f=17&t=1447
Re: 4 Cyl EDIS
Unread postby neald » Wed Nov 11, 2015 8:35 pm
vristang wrote:Neal, thanks for the link to this thread.
No prob. Does this mean your lookin for another 2.3 project?
neald
Vehicle Information: 89' Bronco II
2.9 V6(stock), A4LD
Moates Quarter horse
CBAZA, 05 MAF
Re: 4 Cyl EDIS
Unread postby neald » Thu Nov 12, 2015 6:32 am
decipha wrote:a4a2 is the base cal i created, the strategy name is unknown, derek named his strategy file under the a4a1 box code which uses that strategy, he has the complete a4a1 strat for BE if you want to run a cbaza ecu with edis
I currently have the full CBAZA strategy from Derek. Will it not work with your a4a2 cal? Will I need to buy the Full a4a1 strat from Derek as well for EDIS? I'm sure the answer is yes but I just want to be sure.
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Re: 4 Cyl EDIS
Unread postby decipha » Thu Nov 12, 2015 7:51 am
yes you need the a4a1 strat from derek to run a cbaza ecu with edis
Re: 4 Cyl EDIS
Unread postby vristang » Thu Nov 12, 2015 8:26 am
Not until the kids get a little older... About all I have left now is a volvo head and 2.3 short block in need of rebuild.
That 2.3 car was fun to tinker with, I have missed it.
It's great that guys like Derek and Michael are still making improvements like this!
vristang
Re: 4 Cyl EDIS
Unread postby neald » Thu Nov 12, 2015 9:45 am
Very nice at least you have the heart of the project. I assume you still have the Quarterhorse or whichever tuning device you were using and ecu? Those are the main things.
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Re: 4 Cyl EDIS
Unread postby neald » Thu Nov 12, 2015 9:52 am
vristang wrote:It's great that guys like Derek and Michael are still making improvements like this!
I agree 100%. If it wasn't for them my project would be stalled dead in its tracks(literally). I have great respect that they donate all their free time and probably non free time to us guys that want to learn this.
neald
2.9 V6(stock), A4LD
CBAZA, 05 MAF
Unread postby decipha » Thu Nov 12, 2015 10:59 am
I wouldn't exactly sum both of us together, Derek has done far more for the DIY tuning community than I ever have, if it wasn't for him there would be very little support for these ecu's in the DIY community. And if it wasn't for him I would never have even gotten started tuning these boxes. I would say 99.5% of the credit goes to Derek and maybe 0.5% goes to me, I'm just the messenger spreading the word, Derek does all the hard work.
Unread postby Shaker666 » Sun Feb 11, 2018 11:31 pm
Is it possible to use TunerPro with the CBAZA.xdf and have EDIS functional using the A4A1/2 calibration?
'89 supercharged 8.6:1 5.0 Mustang: EEC-IV (GUFB:A9L) with EDIS8
'79 Bronco: 8.5:1 408M EEC-IV (GUFB:X3Z) with EDIS8
'71 Mach 1: RIP, but was CDAN4 on a 10:1 408W
'66 Mustang GT: needs EFI
'00 Mountaineer: 9.15:1 302W EEC-V, EDIS, 4R70W stock
'08 Buell: 10:1 DDFI-3
'09 Buell: 12.3:1 DDFI-3
Shaker666
Name: Manu "Shaker" Singh
Vehicle Information: '89 Mustang 5.0 LX Sport: blown 8.6:1 306 EEC-IV+EDIS8. Ported Vic Jr. heads, LMAF, Accufab 90mm TB, KB 2.2 Blowzilla w/Flowzilla, Deka 80s, AEM dual nozzle water injection, shorty stainless headers into 2.5" X-pipe, dual O2. A9L2 QH tuned.
Vehicle 2 Information: '79 Bronco Ranger XLT: 8.5:1 400 EEC-IV+EDIS8 ignition. Stock heads, LMAF, Ford 65mm TB, Cobra upper, 351W GT40 lower, Ford 24s. Full length headers with 1.75" primaries into 3" Y-pipe, single O2. TwEECed A9L.
Vehicle 3 Information: '71 Mustang Mach 1: Totalled
Additional Vehicles: '08 Buell XB12Ss Lightning: factory 10:1 motor with DDFI-3 control. Drummer exhaust, dual O2 mod, baro mod. DDFI-3 tuned via TunerPro RT.
'09 Buell 1125CR: factory 12.3:1 Rotax engine w/DDFI-3 control. APH Engineering exhaust, K&N air filter, tuned via TunerPro RT.
'07 Mazda 3S: mainly stock, minor suspension and chassis reinforcements.
'00 Mountaineer: 9.15:1 302W EEC-V, integral EDIS8. Stock with exception of 1" TFS intake spacer, cold air intake, and Magnaflow exhaust.
Unread postby decipha » Mon Feb 12, 2018 7:01 am
no, the a4a1 strategy is diferent than cbaza. You will need to get BE and the full A4A1 strategy from derek "sailorbob".
Unread postby Shaker666 » Mon Feb 12, 2018 9:17 am
decipha wrote:no, the a4a1 strategy is diferent than cbaza. You will need to get BE and the full A4A1 strategy from derek "sailorbob".
Fair enough. However, does this require an A4A1 strategy EEC or will a CBAZA EEC be able to run EDIS with the appropriate A4A1 definition and binary?
Shaker666
Unread postby decipha » Mon Feb 12, 2018 9:19 am
decipha wrote:A4A1 is the same hardware code as a cbaza automatic ecu
Unread postby Shaker666 » Mon Feb 12, 2018 9:32 am
LOL, thx for double confirming this.
Shaker666
Return to EEC-V & SN95 Tuning
