V6 Auto Trans 2-3 shift issue
Unread postby NxCoupe » Wed Jun 08, 2016 9:54 pm
I'm having an issue with a v6 auto holding 2cd gear out to 7k when I am commanding the shift at 6100. Any insight? I have the tuneful in sect if that would help.
NxCoupe
Vehicle Information: 2012 5.0 6 spd, on E85, offroad pipe, GT500 mufflers, just started tuning process, gained 40 rwhp over stock so far.
Black with black interior, base model, built shortblock.
SCT Xcal4, using Advantage to tune it.
Vehicle 2 Information: 1992 Mustang Coupe, coyote 5.0, turbo, 5 spd, race car build in progress. Used to run in NMRA Real Street, now building it for NMRA Coyote Modified
Vehicle 3 Information: 1993 Calypso Mustang Coupe, 5.0 no options, strip down coupe. Only has auto and cruise, didn't even come with a radio, lol. Future plans are to put a Windsor with an On3 turbo kit and an AOD with a brake.
Additional Vehicles: 1993 2.3L 5 spd Mustang coupe, future turbo 2.5 build.
Moates chip, BE tuned
GSS340 pump
Spec Stg 3 clutch
V8 T5 with custom input shaft, billet shifter
8.8 rear end with 3.55 gear, 4 wheel disk
V8 front spindles and brakes,
V8 sway bars front and rear
CC plates
FRPP cockpit adjustable shocks and struts. Soft to race with the flip of a switch!
Have 57mm turbo, Stinger header, ebay blow off and waste gate purchased so far.
Re: V6 Auto Trans 2-3 shift issue
Unread postby decipha » Thu Jun 09, 2016 6:13 am
it sounds like you only changed the WOT shift rpm scalar and didn't re-calculate the 2-3 shift speed function
go reduce the mph at the top of the 2 - 3 sea level shift function to the MPH that it should shift at
Unread postby NxCoupe » Thu Jun 09, 2016 9:37 pm
I believe I did that. I have a lot of success with 5.0s with the changes I make. If you want to see the tune I can post it, but I would rather email it to you.
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Thu Jun 09, 2016 10:00 pm
email or post either is fine, best to PM instead of email though since that goes to my tele, make sure its zipped otherwise the email server will delete the file
Unread postby NxCoupe » Fri Jun 17, 2016 7:23 am
It won't let me PM you the .mtf file nor will it let me post it here. If you can't get it by email, then I'm at a loss.
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Fri Jun 17, 2016 8:43 am
Unread postby NxCoupe » Mon Jun 20, 2016 6:01 am
It worked from home. Must have been my internet connection....
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Mon Jun 20, 2016 6:12 am
no i added mtf to the allowed extensions
Unread postby NxCoupe » Mon Jun 20, 2016 9:53 am
Ah, cool, thanks! I thought the link was showing me I was a dumbass. lol.
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Mon Jun 20, 2016 9:57 am
it was, you didn't follow the directions as outline in the forum rules for posting
Unread postby decipha » Mon Jun 20, 2016 11:09 am
looks like your nvbase calc was off throwing everything out
Unread postby NxCoupe » Mon Jun 20, 2016 8:48 pm
decipha wrote:looks like your nvbase calc was off throwing everything out
Rear gear was changed to a 3.73 so nv needed to be modified to compensate, unless you're saying I did it incorrectly. Please elaborate. EDIT: Just got the pm. That's taking into account the gear change?
Also, in another thread here a guy posted he shut off rpm based shifting, how is that done? viewtopic.php?f=8&t=755
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Tue Jun 21, 2016 5:44 am
you have the ratio set to 3.31 not 3.73
never heard disabling rpm shifting, i never knew there was any rpm shifting used other than the wot shift scalar checks
Unread postby NxCoupe » Tue Jun 21, 2016 6:49 am
My bad, yeah, was thinking of another tune, I knew it had a different ratio than factory in it. I should have checked before I posted that. But at any rate, how do you calculate N/V?
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Tue Jun 21, 2016 11:23 am
n is rpm, v is vehicle speed at a 1:1 gear ratio
divide
N / V
since that trans doesn't have a 1.0 gear ratio you have to cross calculate, this is all detailed in the trans write up on the homepage
http://efidynotuning.com/trans.htm
how did you calculate it?
Unread postby NxCoupe » Tue Jun 21, 2016 12:27 pm
new gear ratio divided by old gear ratio multiply times N/V. I read the trans info and did not see an actual N/V calculation, did see the formula you put in for altering shift points, but is that the same as what we are talking about? Can you share how you arrived at 40?
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Tue Jun 21, 2016 1:02 pm
yea no prob, when i get to my laptop ill add the full nvbase formula to the trans write up
Unread postby NxCoupe » Fri Jun 24, 2016 11:25 pm
Yep that fixed it. I had a DOH moment I guess, for some reason I thought it had a 3.73 in it, but it didn't. Changed the NV to 40 and it worked perfectly. Set the trans rpm's and matched the mph to get it close and the thing is shifting great he said last I spoke with him. thanks a ton!
NxCoupe
GSS340 pump
Spec Stg 3 clutch
CC plates
Unread postby decipha » Sat Jun 25, 2016 6:57 am
no prob dont mention it, thats what the forum is for
Return to CAN Tuning
