Starts then dies when warm
Unread postby yeastieBoB » Sat May 12, 2018 8:43 am
Wouldn't start when warm (>150 ECT), so I kept increasing Crank PW ECT Modifier FN348 until it would start. After that it would start, but then almost immediately shut off unless I worked the gas pedal. Once I drove a little ways it seemed fine after that. It's done this a few times since loading A9L2.
Is there something in the tune I can adjust to help with fuel after startup? Or should I worry about that after I have my WB installed? Thanks
yeastieBoB
Re: Starts then dies when warm
Unread postby decipha » Sat May 12, 2018 10:55 am
It seems a lot of people confuse cranking pw with startup enrichment. Cranking PW is the time you have to hold the key in the crank position before the engine fires off. From that point on startup enrichment takes over.
It sounds like your cranking pw are fine now and you need to dial in enrichment fuel thats assuming your base fuel is dialed in (injectors and maf).
Ford fuel control can be broken down in to 3 modes. 1st is cranking pw, thats the time you have to physically hold the key in the crank position before it fires off meaning >1000 rpm's. 2nd is base fuel i.e dialing in the injectors and maf which can only be done on a warm and stabilized engine. 3rd and last is startup enrichment.
If you dont have to hold the key in the crank position with the starter engaged for long to get the engine to fire then your cranking pw is fine. If you haven't dialed in base fuel yet then you can't dial in startup enrichment yet. Once your base fuel is dialed in you can then for dial in the startup enrichment "lambse subtractor" table.
The other big contributor to startup is dialing in the isc multiplier fn1861 / fn1862.
it all covered in the startup enrichment write up on the homepage
Unread postby decipha » Sat May 12, 2018 11:16 am
i just added this to the fuel write up, give it a check over has more details
Unread postby yeastieBoB » Sat May 12, 2018 1:18 pm
Yep, I was confused. Thanks for clearing that up!
yeastieBoB
Unread postby yeastieBoB » Sun May 13, 2018 10:33 pm
So I need to be able to make some adjustments so I can drive this thing. I can’t tune base fuel if I can’t drive it or fill the tank. It stalled at a stop sign today and it wouldn’t restart. I’m currently waiting on the side of the road for it to cool off completely to see if it will start. This sucks.
Edit: I did notice that when it stalled ACT was >160. I’m guessing that’s contributing.
I did get my WB installed today and it’s set up for data logging.
yeastieBoB
Unread postby yeastieBoB » Sun May 13, 2018 11:09 pm
I made it home! I don't know what's going on with this thing. Had to wait until ECT and ACT were near 130.
I know heat soaked ACT sensors can cause problems, but I wouldn't expect that to just start happening all of a sudden.
Anyway, I got to get to bed. I took a log of my drive home. Car was running rough. Note that I haven't completed validating the WB logging. Watching it vs the dashboard, it looked accurate so far.
yeastieBoB
Unread postby 89mustangcoupe » Tue May 15, 2018 1:42 pm
I was actually going to make a thread I'm having the same problem my car starts right away I went down the road and went back home and it got to 170 degrees etc and Iat were like 90. Now I tryed to restart it after shutting off in driveway and it keeps cranking. Im running the supercharger belt off because I just put new head gaskets on motor and trying to get it tuned without supercharger belt on for now. So I need to dial in my base fuel table? Then dial in my start up enrichment?
89mustangcoupe
Vehicle Information: 1989 ford mustang lx coupe a9l ecu, moates quarter horse, plx dm6 wideband,tuner pro rt, 302 stock block,9:9:1 CR sealed power forged pistons, eagle I beams, eagle crank, gt40p heads with mild porting on exhaust, crane conical valve springs ,1.7 crane cams cobra rockers, Anderson n-21 cam, Vortech V1 S-trim, FMIC, Siemens Deka 60lb injectors, pro products AFPR, PMAS HPX-E Blow thru MAF, typhoon professional products intake with 1 inch spacer, bbk 75mm tb with egr delete,msd blaster coil,accel distributor module, Mallory hyfire 685, T5 trans, strange 35 spline axles and full spool with 4:10 gears, FMS shorty headers bbk x pipe, flow masters to tail pipes, Autolite 103's
Vehicle 2 Information: 89 Camaro RS 305 TBI Auto Stock
Unread postby 89mustangcoupe » Tue May 15, 2018 1:45 pm
I believe start up enrichment is off because I tuned injectors and maf already but didn't really mess with start up yet. I'm assuming it's dumping to much fuel on start up when it's warm
89mustangcoupe
Unread postby 89mustangcoupe » Tue May 15, 2018 2:10 pm
i uploaded a screenshot of my tables does this look right? not sure if i need to up the numbers around 150 degress or decrease the numbers.
89mustangcoupe
Unread postby decipha » Tue May 15, 2018 7:15 pm
base fuel table cannot dial in fuel and should not be touched unless running an alternate fuel
read the fuel write up i state it numerous times
you need to determine if its cranking pw or startup enrichment causing your issues
Unread postby yeastieBoB » Tue May 15, 2018 8:01 pm
edit: removed post
yeastieBoB
Unread postby yeastieBoB » Tue May 15, 2018 8:13 pm
In regards to my issue, I was verifying my tune and noticed Injector Breakpoint FN389 was all 0. Each time I update it, save it, and then re-open it, all the values are zero again. What am I doing wrong?
yeastieBoB
Unread postby decipha » Tue May 15, 2018 8:31 pm
your plugging in the wrong value for that specific breakpoint function
there are two different functions with different equations, the one you use depends on the injector breakpoint data your given
AS WITH ANY PARAMETER, ALWAYS PAY ATTENTION TO WHAT YOUR CHANGING FROM AND TO
compare your breakpoint to the a9l2 and see where you went wrong
Unread postby yeastieBoB » Tue May 15, 2018 9:47 pm
decipha wrote:your plugging in the wrong value for that specific breakpoint function
Thanks. I see the two Injector Breakpoint parameters (lbs/mass and lbs/rev), but I don't understand how to know which parameter to use based on my injector data. I assumed FN389 lbs/rev since that is the only one mentioned on the A9L2 Base Calibration page.
    FRPP 30 lb/hr @ 55psi
    B302
  • Low Slope 37.504
  • High Slope 35.952
  • Breakpoint 0.0000253007
yeastieBoB
Unread postby decipha » Wed May 16, 2018 5:38 am
lbs/mass is what the reference data is giving you
i thought i had the equation *1000 in there
regardless of what the software shows you, the stock breakpoint I have in the a9l2 is 0.000010 lbs/mass
Unread postby yeastieBoB » Wed May 16, 2018 6:49 am
Thanks, but I'm not sure what you mean about the equation. You're correct about the stock breakpoint in the A9L2.
Am I not just updating the Injector Breakpoint lbs/mass using the breakpoint 0.0000253007?
yeastieBoB
Unread postby decipha » Wed May 16, 2018 4:15 pm
yep thats it plug it on in
Unread postby yeastieBoB » Thu May 17, 2018 11:17 am
I could use more help with this issue, please. My next step is to verify my WB is logging correctly, but I can't do that if I can't drive it.
Let car idle 7 minutes. Restarted fine with ECT 196 and ACT 138.
Let idle another 8 minutes. Would not restart with ECT 178 and ACT 148.
Those two ECTs are within the same range in the Crank PW ECT Modifier table, so I don't think that table needs adjustment.
I have not modified my Startup Enrichment table. I believe that at those ECTs no startup enrichment is done.
I'm not sure what else might need adjustment. Any ideas?
yeastieBoB
Unread postby decipha » Thu May 17, 2018 4:12 pm
startup enrichment is always needed regardless of temp
sounds like you have mechanical issues, verify spark fuel and air one of the 3 is missing or not enough
Return to Foxbody Tuning
