A9L2 to binary editor
Unread postby RClements95 » Wed Apr 04, 2018 9:37 pm
New to the forum here,
Can decipha's A9L2 calibration be loaded to binary editor. If so what are the steps? When i download the file to my laptop it says I need to export it to an excel file and it will not allow me too. Any help is appreciated.
RClements95
Vehicle Information: 1993 Ford Mustang GT
A3M
Moates QuarterHorse/TunerPro RT
Re: A9L2 to binary editor
Unread postby decipha » Wed Apr 04, 2018 9:41 pm
no it cannot, the a9l2 uses the gufx strategy with tunerpro only otherwise you won't be able to see valid data
Unread postby RClements95 » Wed Apr 04, 2018 10:45 pm
Very good. Thank you decipha
RClements95
A3M
Unread postby pantera2023 » Wed Apr 18, 2018 11:24 am
I'm learning so please be understanding if I'm missing the obvious. Just the other day I loaded the GUFB strategy to BE, I then loaded the A9L2 calibration with MAF curves recommended in the start up tutorial as well as my manufacturers injector curves to my C3W1 with QH. My car started right up and idled smooth. Was that not supposed to work? I was going off recommendations from another one of your threads...Thanks
pantera2023
Premium Member
Vehicle Information: 1966 Mustang, 5.0L conversion, C3W1 ECU, GUFX strategy, Decipha custom tune, Quarter Horse, TunerPro RT
AEM-UEGO
Vehicle 2 Information: 2006 Ford F150, Built 5.4L, Vortech SC, SCT OBD2 programmer, custom tune
Unread postby decipha » Wed Apr 18, 2018 1:56 pm
the maf transfer hasnt moved so thats not affected
the spark table and modifiers are moved so usong the gufb def will show wrong values
Unread postby pantera2023 » Wed Apr 18, 2018 2:38 pm
Decipha,
I've been doing a lot of thread reading on this forum to get a basic understanding of the tuning process, I've read all of the pre and beginning steps as well as steps 1-4 . I have a BE dongle, but am just getting started in learning it. I have no problem switching to TunerPro RT if it's easier to learn and I can benefit from the great work you have doing here, especially if I can use the A9L2 def. Do you recommend me switching to TunerPro RT now while it's early? Also, I am about to purchase an EEC analyzer dongle, is that the preferred software? I have an AEM 30-4110 WB coming in the mail, per your advice on other threads.
My engine is a stock 95 mustang short block that I've freshened with new rings & honed cylinders, new bearings and polished journals, Erson cam, TFS high port iron heads, TFS Box R intake, 76mm C&L MAF, 75mm BBK TB, 30# Accel injectors, and shorty headers with X-pipe (I've read how you state I must eliminate an O2 sensor). It's in a 66 mustang with a 4 speed toploader... let me know if there are any glaring issues with my setup.
Thank you much.
pantera2023
Premium Member
AEM-UEGO
Unread postby pantera2023 » Thu Apr 19, 2018 10:08 am
Ok, on my own accord I've switched over to tuner pro RT. I've got the Injector Time offset vs. Voltage curve changed and a recommended MAFV transfer curve input. I'll plug away on more changes and start a new thread if I have questions.
pantera2023
Premium Member
AEM-UEGO
Unread postby decipha » Thu Apr 19, 2018 4:12 pm
I find tunerpro is much easier especially for a newbie as its much faster to get going than using BE, in any case I can't use BE cuz clint remotely disabled my dongle during an update a couple years back so im forced to use tunerpro
yep no problem
Unread postby Shaker666 » Tue Apr 24, 2018 11:38 pm
decipha wrote:I find tunerpro is much easier especially for a newbie as its much faster to get going than using BE, in any case I can't use BE cuz clint remotely disabled my dongle during an update a couple years back so im forced to use tunerpro
yep no problem
Now why would Clint do such a thing?
FYI, I'm still able to flash new tunes using BE and A9L2. I use TunerPro RT all the time when tuning my Buells, but I haven't quite made the switch for GUFB. Does the ADX you made have a full datalogging dashboard and everything? I want to switch to GUFX on TunerPro, but I'm planning to inject my '66 Mustang using the harness and CDAN4 setup I had in my '71 (RIP)... I think the only path forward for that is to continue using BE (SailorBob def).
'89 supercharged 8.6:1 5.0 Mustang: EEC-IV (GUFB:A9L) with EDIS8
'79 Bronco: 8.5:1 408M EEC-IV (GUFB:X3Z) with EDIS8
'71 Mach 1: RIP, but was CDAN4 on a 10:1 408W
'66 Mustang GT: needs EFI
'00 Mountaineer: 9.15:1 302W EEC-V, EDIS, 4R70W stock
'08 Buell: 10:1 DDFI-3
'09 Buell: 12.3:1 DDFI-3
Shaker666
Name: Manu "Shaker" Singh
Vehicle Information: '89 Mustang 5.0 LX Sport: blown 8.6:1 306 EEC-IV+EDIS8. Ported Vic Jr. heads, LMAF, Accufab 90mm TB, KB 2.2 Blowzilla w/Flowzilla, Deka 80s, AEM dual nozzle water injection, shorty stainless headers into 2.5" X-pipe, dual O2. A9L2 QH tuned.
Vehicle 2 Information: '79 Bronco Ranger XLT: 8.5:1 400 EEC-IV+EDIS8 ignition. Stock heads, LMAF, Ford 65mm TB, Cobra upper, 351W GT40 lower, Ford 24s. Full length headers with 1.75" primaries into 3" Y-pipe, single O2. TwEECed A9L.
Vehicle 3 Information: '71 Mustang Mach 1: Totalled
Additional Vehicles: '08 Buell XB12Ss Lightning: factory 10:1 motor with DDFI-3 control. Drummer exhaust, dual O2 mod, baro mod. DDFI-3 tuned via TunerPro RT.
'09 Buell 1125CR: factory 12.3:1 Rotax engine w/DDFI-3 control. APH Engineering exhaust, K&N air filter, tuned via TunerPro RT.
'07 Mazda 3S: mainly stock, minor suspension and chassis reinforcements.
'00 Mountaineer: 9.15:1 302W EEC-V, integral EDIS8. Stock with exception of 1" TFS intake spacer, cold air intake, and Magnaflow exhaust.
Unread postby decipha » Thu Apr 26, 2018 10:02 am
I asked him in person a couple years ago and he told me he doesnt allow binary files anymore for those that have obdii licenses to prevent reverse engineering.
Yea the tunerpro datalogging is significantly better than any other software.
I have most of cdan4 disassembled but I only use it as a reference for other 2 banks. I never made a complete xdf for it since no one has ever requested it and I never had the need. If you have dereks full cdan4 it would be wise to stick with that.
Return to Foxbody Tuning
