Injector data populated by EA
Unread postby 89FiveOh » Mon Mar 19, 2018 10:00 am
Hello,
When running datalogs thru EECAnalyzer, some of the injector values in the higher rpms turn red when calculating injector timing. I think this means I cant get the pulsewidth to happen within the time needed before the valve closes. Can increased fuel pressure aid in the making the injector bigger so to speak? Will increased fuel pressure make up for the undersized injector in this rpm range?
thanks
89FiveOh
GUFB A9L
Binary Editor/EEC Anaylyzer
Innovate MTX-L PLUS
MOATES QuarterHorse
308
Custom Cam (HR)
AFR 165, 58cc
BBK 75mm (24lb/hr calibration) MAF
5 speed
3.73 gears
NA
Full length BBK headers with H-pipe thru Flowmaster mufflers
Re: Injector data populated by EA
Unread postby decipha » Mon Mar 19, 2018 11:10 am
yes, you basically gain a 1% increase in flow per each psi of fuel pressure over rated
so if you have 19 lb/hr injectors rated at 40psi, if you kick it up to 80psi you gain 40% more flow
19 * 1.4 == 26.6 lbs/hr @ 80psi base fuel pressure
Unread postby 89FiveOh » Mon Mar 19, 2018 6:39 pm
So, to get a 30lb’er with 24’s, I need approximately 25% more. I could add 25 more pounds to the stock 39.5psi for a total of around 65 psi?
Does this require messing with the tune again or will adaptives curve back in any fueling changes?
89FiveOh
GUFB A9L
Innovate MTX-L PLUS
MOATES QuarterHorse
308
Custom Cam (HR)
AFR 165, 58cc
5 speed
3.73 gears
NA
Unread postby SlowBox » Mon Mar 19, 2018 7:25 pm
I made an adx payload to calculate intake valve duration and display a percentage of the valve event vs the injector pulse. Based on what I've seen with my own car, you'd need to stay under 40% duty cycle ish at max rpm at wot to fit the entire injector pulse into the chamber for each cycle. Honestly, beginning and ending the pulse during the intake stroke and fitting all the fuel into the chamber before the valve closes isn't really important at all at high load where there's tons of velocity in the runner. What doesn't make it will be there the next time the valve opens, and it'll fix itself each time.
I ended up doing several hours worth of research looking at valve event duration at different rpm, excel spreadsheets, cam cards, injector duty cycles and pulsewidth, etc and got my injector timing table dialed in really nicely. Start a new thread if you want and I'll post up what I've learned.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby decipha » Tue Mar 20, 2018 12:58 am
correct your math is sound
24 * 1.25 == 30lbs/hr at 65psi base
no, you cannot go from 24 lb injectors to 30 lbs injectors without redialing in the injectors.
if you do decide to raise the fuel pressure to 65psi, id recommend kicking up the offset 20% and raising the low slope and high slope as well as breakpoint 25% for starters
then adjust to get your fueling back where it was
