Foxbody Tuning Information
Unread postby decipha » Tue Jul 23, 2013 3:40 pm
The foxbody's have one of the crappiest tunes of all ford calibrations. It is almost impossible to properly dial in a bone stock fox without making extensive changes to the factory calibration. All of the foxbody ecu tunes are interchangeable, an A9L tune can be run on any foxbody ecu such as the A3M, X3Z, S0Z, D3D, A9P, A9T, etc... they can all be swapped with no problems. However, this is not true for those who use a Tweecer. The tweecer does not load the complete binary to the ecu so it cannot swap strategies. If you have a tweecer you must use your factory strategy "calibration type" otherwise the ecu will freak out.
I have made a performance stock foxbody calibration that I use on EVERY vehicle I tune. I have named it the A9L2, this is the calibration that Henry "should have" made.
All info on the A9L2 and the binary can be downloaded from http://info.efidynotuning.com/a9l2.htm
I highly recommend using this as your base tune to create your calibration, you, and your vehicle will be much happier from the get go.
Re: Foxbody Tuning Information
Unread postby Holland375 » Sun Apr 26, 2015 8:46 am
So if I am using a tweecer and have gufb can I load your A9l2 tune?
Holland375
Name: Enrique Erdmenger
Vehicle Information: Ffr roadster, ac cobra replica 1965.
383 stroked from 351w. Victor jr. Manifold with 42 lbs injectors and edge rook elbow with 90 mm throtle body and lightning maf. Forged eagle rods and probe pistons and 11 to 1 static compression. Procomp cam custom grind 542 lift at 50 ex and 534 in 112 separation duration 248 int 254 ex.
3550 transmition and 8.8 with 4.11. Msd dizi coil and 6al box.
Tweecer with a9l. Pro comp heads 220.dynoed at 397 rwhp and 450 foot pounds when it had a carb setup3 years ago.
Unread postby decipha » Sun Apr 26, 2015 9:26 am
yep no prob, but if u have any other strategy youd need moates equip
Unread postby Holland375 » Sun Apr 26, 2015 10:42 am
Ok thanks
Holland375
Unread postby jdiding » Sat Oct 24, 2015 8:02 pm
im having trouble getting the a9l2 to load in be2012 is there a trick ?
jdiding
Vehicle Information: 91 gt shorty headers , h pipe , flowmaster cat back bbk cold air , bbk 80mm mas air 19lb injectors, 70mm tb ported upper and lower stock intake 3.73 gears
moates f3 tuned on be2012
Unread postby decipha » Sat Oct 24, 2015 8:09 pm
nope no trick, make sure you have the gufb xls strategy definition file opened and then open the a9l2.bin calibration file
Unread postby jdiding » Sat Oct 24, 2015 8:15 pm
i caught what i did stupid mistake.. i have a mostly stock car so can i populate the required fields with factory data to get going then work from there
fn901 shows all 0.00 is that normal since the sealevelfn 904a table shows the correct values ?
jdiding
Unread postby decipha » Sat Oct 24, 2015 8:48 pm
you can leave it all stock and dial it in no prob
Unread postby jdiding » Sat Oct 24, 2015 9:12 pm
taking a look thru the tune its pretty diffrent the a9l2 is over stock cant wait to see hoe it runs !
jdiding
Unread postby jdiding » Sun Oct 25, 2015 8:01 pm
i do have a question regarding the tune loading on my tuning laptop that has the older build 26 version of be2012 the tune loads all messed up and i cant seen to get BE to update it is a registered
it does work just fine on my other desktop that i was playing around with the tune on everything works fine
jdiding
Unread postby decipha » Sun Oct 25, 2015 8:27 pm
thats typical BE is a mess, use tunepro and all them problems will go away
Unread postby jdiding » Sun Oct 25, 2015 8:44 pm
i emailed clint about getting the latest version to work since i had to download a new version for a9l2 to work right so its something with the old version that causing the problem
will tunerpro burn to a f3/ jaybird setup ? im not familar with tunerpro at all
jdiding
Unread postby decipha » Sun Oct 25, 2015 9:15 pm
yep
Unread postby jdiding » Sun Oct 25, 2015 10:01 pm
thanks now i just have to figure out a whole new tuning platform lol on the upside a9l2 loaded right into it
jdiding
Unread postby jhine5588 » Mon Apr 03, 2017 4:40 pm
I have successfully loaded A9L2 and everything appears to be working. I wanted to go check the ISCIBR payload per the writeup but nothing comes up when I Cntrl+F. Also after about 4 minutes of the car sitting here idling the CEL starts flashing.
Jeremy
jhine5588
Vehicle Information: 1983 LTD station wagon: Blueprint 5.0 longblock, TFS springs and intake, B-cam +4 degrees, MAC longtubes, catted H-pipe, Deka 80's, C&L 76mm 230whp/280ftlbs
Unread postby SlowBox » Mon Apr 03, 2017 5:17 pm
Ipsibr isn't a scalar, it's a readout on the dash. Load the adx and record a log.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby jhine5588 » Mon Apr 03, 2017 5:33 pm
Yeah, I was looking for it on the dash but it wasn't displaying. Here is a warm start to full warmup to when the CEL starts flashing and for a few seconds. The ACT is pretty warm.
I'm not sure if I used the correct ADX or not.
Jeremy
jhine5588
Unread postby jhine5588 » Sun Apr 09, 2017 8:43 pm
Does anyone have any insight into this? Will I have to make a custom dash to get the ISBIBR to display? Any idea as to why the CEL flashes? I'm 100% green to this, just looking for some help to get some things sorted out prior to getting it on the rollers to get it dialed in. Thanks.
Jeremy
jhine5588
Unread postby decipha » Mon Apr 10, 2017 1:03 am
ipsibr is the idle air integrator its on the upper left side of the dash
a flashing cel means you have a fault code
pull codes to see whats not working correctly
Unread postby jhine5588 » Mon Apr 10, 2017 3:18 am
That's what I assumed on both accounts.
I did a few searches and couldn't find a way to pull fault codes through Tunerpro. I also looked around in Tunerpro the other day and I couldn't locate any area that gives fault read outs. I have the ability to pull codes otherwise but is it possible to view faults in Tunerpro?
I didn't turn off the EGR valve after loading the A9L2... I wasn't sure if it is turned off or not in the base tune, honestly didn't investigate it yet, but I have that bypassed as the valve wouldn't clear my FPR. The fact that the CEL is flashing threw me off, as it doesn't do that in stock form... I assume that you programmed that into the A9L2 decipha?
Thanks for the help... I'm trying to not be too much of a PITA.
Jeremy
jhine5588
Unread postby decipha » Mon Apr 10, 2017 7:13 am
yea thats me to let people know they have a major problem and not drive the car til they fix it
its not egr thats already disabled
u cant pull codes through tunerpro, have to do it the cel reading way
Unread postby jhine5588 » Mon Apr 10, 2017 7:39 am
Haha, ok thanks. I have a beeper box and an old Brick so I'll take a look when I get freed up.
Trying to get the car good for summer between a kitchen remodel.
Jeremy
jhine5588
Unread postby SlowBox » Mon Apr 10, 2017 8:30 am
You need a TPS. It's doing all kinds of crazy shit and you never touched the throttle.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby jhine5588 » Mon Apr 10, 2017 9:03 am
SlowBox wrote:You need a TPS. It's doing all kinds of crazy shit and you never touched the throttle.
Roger. I honestly didn't even look at it because I'm a bit overwhelmed being new to the EEC.
I believe I have another on a stock TB. Thanks.
Jeremy
jhine5588
Unread postby jhine5588 » Mon Apr 10, 2017 3:31 pm
So no TPS codes but I have a code 41- ego not switching, lean bank 1 (I have a small exhaust leak on the passenger side, which is bank 1 correct?), 91- o2s not switching/ss1 ckt fault (seems to be a circuit fault?) and 96- fuel pump ckt open (this is a modified stock harness to fit into my 83 LTD and the fuel pump works fine). Also a code 15 but being it's a checksum... I'm not concerned.
Update: Cleared the codes with my Brick and ran it through a couple cycles and it is idling better than it was before. Haven't let it run long enough to see if the CEL stays off. Will clearing codes reset the KAM?
Jeremy
jhine5588
Unread postby jhine5588 » Mon May 01, 2017 5:46 pm
I've mended it... Ground wire in the wrong cavity on the engine harness for the O2's. O2's are switching properly now and exhaust leak is fixed.
Jeremy
jhine5588
Unread postby decipha » Mon May 01, 2017 10:20 pm
nice
Unread postby jhine5588 » Tue May 02, 2017 4:34 pm
Yeah, I fucked up lol
So now my CEL is coming on for a TPS issue. TPS reads fine upon cold start. Once engine reaches temp and I cycle the key it reads 1.25v idle and .75v WOT. I've tried both TPS sensors I've had laying around. I did not try a new sensor yet. I'm letting the engine cool down to see if it's a temp issue or not.
Jeremy
*Edit- It seems to be temperature dependent. After sitting in the car KOEO the ECT came down to around 120 and the TPS started reading proper. What is odd is both sensors do this...
jhine5588
Unread postby decipha » Wed May 03, 2017 9:24 am
check for shorts between the circuits, those two are completelt independent unleas your internal regulator has gone to shit
wouldnt hurt to toss pin46 aig return to chassis ground too
Unread postby jhine5588 » Wed May 03, 2017 2:04 pm
Got the new TPS but didn't install it. Fired the car back up today and have been letting it run and doing some step tuning to the MAF and the TPS has been acting fine... I'll keep an eye on it but it seems to be just fine.
Is there a way to raise the ECT limit aside from changing the FN126? I have a mechanical fan and sitting in the garage playing with the tune the ECT is staying around 230. I understand this is a little high and that it will be lower once air is moving through the radiator but it seems to kill spark every time the ECT comes near 235 and the LAMBSE turns red on the realtime tuning dash and engine wants to stall. I also understand this is a safety feature and I plan on re-enabling this once I'm able to drive it when my driveshaft comes back from being lengthened. Thanks.
Jeremy
*Edit- So after almost an hour of running and playing with the tune the TPS messed up again. Plugged in the new TPS and still fuckered.
When you said the "two are completely independent" I assume you're talking about in an electrical aspect. I was thinking (and hoping) that the radiant heat in the engine bay/throttle body (using the ECT as a reference) was causing the issue in the TPS. A wiggle test shows no difference in voltage readings either. I'm going to check for shorts on the TPS wiring now as the voltages are reading wrong but I'm leaning towards the EEC being a concern...
BTW- Pin 46 is already grounded with the shields by the EEC.
jhine5588
Unread postby jhine5588 » Wed May 03, 2017 7:05 pm
Looks like it might have been an issue at the EEC connector. When I wiggle it it drops the TPS signal. It's all working well now. I'll depin it and fix the spread pin.
Here is a datalog... I can't seem to get the idle down. I closed the throttle plate about 1.5 turns and it still wants to idle around 950. Plus the timing is jumping all over... 14-30. Coming from a carb and from VE tables on the Megasquirt setup I'm kind of a stickler to know exactly where my spark is at idle.
Jeremy
jhine5588
Unread postby decipha » Thu May 04, 2017 3:31 pm
the attachment is gone now with the forum ported over
2 things you want to check for
make sure the throttle position stays the same when off throttle
spark at idle should be aroun 14 or so
Unread postby jhine5588 » Sun May 07, 2017 5:46 pm
The TPS stays around .7-.8v at idle.
I drove it up the road today and anything past about 1/4 throttle the ECT goes to 240 and car falls on it's face just like it was in the shop?? I replaced the ECT when I first got the car running last fall. I took a snapshot but I don't think it will be worth looking at. I can post if it will let me. When I drove to the gas station to get some fresh gas today a state trooper decided I shouldn't be driving a car with no reggy, no insurance and no inspection... Luckily he let me flat tow it home and didn't give me any tickets. Oops!
I'm puzzled by the ECT reading going all fucky unless it is an internal EEC issue, which is probably likely.
Jeremy
jhine5588
Unread postby decipha » Sun May 07, 2017 8:53 pm
.7 and .8 is a major difference, you need to make sure it stays within 0.02 volts every time it returns back to closed throttle
does the ect shoot up everytime you go half throttle even when the car is cold?
if it only does it when its warm it could be air in the line or its low on coolant / overheating
if it does it when its cold too then its screwy
the act and ect is also tied together internally so it could be a faulty act throwing it off too but just showing on the ect
Unread postby jhine5588 » Mon May 08, 2017 4:33 pm
KOEO TPS reads .74 then creeps up to .8 and remain at .8 through multiple WOT movements. The ECT stays with ACT on a cold start. ECT does not jump when going to WOT while running cold. TPS jumps around between .6 and .8 at idle.
Jeremy
Edit- I think slowbox is right, this TPS has had it. It is bouncing around between .81 and .87 at idle. What gets me is the spark advance keeps jumping around between around 14 and 24. Also with the TPS unbolted from the TB when the engine is warm the ECT still goes to 240 with a WOT hit when it is reading 215 prior to revving. I'm going to verify all of my voltages going into the EEC next.
jhine5588
Unread postby jhine5588 » Mon May 08, 2017 6:03 pm
I reloaded A9L2 to start fresh. Reset idle and started over...
Spark is good
TPS jumps between .82 and .88 very quickly but hangs around .88 mostly.
Idling around .96 VMAF at 900 RPM
I attached an idling snapshot. Is this TPS voltage OK?
Jeremy
Edit- Got it running a bit better and took it up the hill quick with just a breath on the throttle, runs fine. Turned around and laid into it a little and falls on it's face... I uploaded a new snapshot labeled Road Test. I'm really not sure what is the issue here :(
jhine5588
