2 step/ launch control
Unread postby 91foxgt » Sun Jan 07, 2018 1:14 pm
I am currently running a A9L2 tune in my 91 mustang gt and stumbled upon an option called two step. I was curious to see if it would work so i enabled it and tweaked it to the rpm i desired. It seems to "kinda" work but it's not that great. the rpm goes up to my desired limit but it fluctuates too much. I have it set a 3500rpm for now but when i step on the gas the rpm just keeps randomly bouncing between 2300rpm and 3700rpm which is a pretty big gap. Also the car vibrates way to much. I want to know if there are more settings to it for it to operate better and smoother.
91foxgt
Vehicle Information: 1991 ford mustang gt 5 speed
Re: 2 step/ launch control
Unread postby SlowBox » Sun Jan 07, 2018 2:35 pm
Indicated RPM or actual? I posted a video of my car on the 2 step in another thread and the tach gets pretty wacky, but actual engine speed stays pretty consistent. If the car vibrates too much for your taste on the stepper, I assume this is your first experience with one? Welcome to the forum.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
Alex's Parts springs
10:1
FMS B303
GT-40 upper and lower
65mm TB
80mm Mk8 MAF
Decapped injectors
E85
Motorsport shorties
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Unread postby 91foxgt » Sun Jan 07, 2018 5:47 pm
ohh so its just the tachometer showing wack rpms while the actual rpm is good. Also yes, it is the first time having 2 step in my fox so i assumed the vibration wasn't right. Anyway i have another question, the 2 step is engaged with or without the clutch pressed in and i want to change it to where its only on with the clutch pressed. Is there any settings for that? btw my trload (transmission type) is set to 0 and if i change it, the 2 step doesn't work.
91foxgt
Unread postby SlowBox » Sun Jan 07, 2018 5:57 pm
The stepper uses the clutch switch on the pedal, the neutral sensing switch in the trans, and the vss to trigger the second limiter. I do not have a clutch switch and mine works if the trans is in gear at a stop. TRLOAD is 2 in my tune.
SlowBox
Advanced Tuner
5 speed, 3.73
GT-40P heads
10:1
FMS B303
65mm TB
80mm Mk8 MAF
Decapped injectors
E85
Motorsport shorties
A9L/A9L2/GUFB
TunerPro v5
Moates QH v1.6
Unread postby 91foxgt » Sun Jan 07, 2018 6:58 pm
I'll change my trload to 2 also and see if it works. Thanks
91foxgt
Return to Foxbody Tuning
Users browsing this forum: No registered users and 5 guests
