So I read "To determine max N/A load do WOT in 2nd gear from idle to redline and note load at each 1300 rpm interval."
Am I supposed to do this from a dead stop or from a roll? Or does it not matter as long as I can capture load at 1300 and up?
decipha wrote:i have a histogram setup for fn035, if you click the history table button two buttons to the right of the show dashboard button it will pop up with the histogram tables
click on his_perload_err table from the drop down, then select running average from the next drop down under view, do a wot pull and the perload error will be saved in the far right column (730+ tprel)
