Ford EU EEC IV&V specificities
Re: Ford EU EEC IV&V specificities
Unread postby Pym » Wed May 10, 2017 5:32 am
For information, I have a workaround to disassemble my 2 banks binaries. http://forum.efidynotuning.com/viewtopic.php?f=30&t=1260
This was really necessary, because, when using my EEC V test bed with OBD tools, I have just realized that calibration name was directly available.
And because, all EEC V calibrations are available through direct download, just with their name, it is really necessary to be able to disassemble them quickly.
Pym
Hacker
TunerPro on Moates chips
Unread postby Pym » Mon May 15, 2017 2:39 am
Some new files from Mondeo and Cougar V6.
My Mondeo has been identified (through OBD, still not unmounted) as using an EEC V MLP-427 with ATAFHE3 Calibration (REED).
My Cougar (not at home for now) should use an EEC V MLF-4G7 with KHAI8AU (USES), the same than the Mondeo ST24.
To be clear, it is quite simple to understand which Calibrations were provided for cars using EEC IV, but for EEC V, it is really more complicated.
Mondeo V6 MK2 (1996-2000) has more than 10 different calibrations on 3 different hardware. Ok, an engine update was done in 1998 (different injectors, lower engine displacement), but it looks more like based on options of the vehicle.
So for example, for ATAFH(E) strategy, I have 3 versions, mine ATAFHE3 (REED), ATAFHE4 (?) and ATAFHE5 (TICK), with 3 real different Ford part numbers.
These calibrations are really near, with small changes, but I can not link them to vehicle specifications.
When I compare them with KHAI8(A) strategy, I can find many common parts, but yes it was really updated (because of hardware only ?). Loom and Pin out should be the same.
We should find the same thing on US market, with Contour and Mercury Cougar, so probably more information ?
Pym
Hacker
Unread postby Pym » Tue Jun 27, 2017 12:46 pm
After some time, waiting for the Cougar, restoring the XR2i, working on the others and other things related with the season, I continue to work on this subject, just before holidays.
I have identified Cougar management, it is using a KHAICEY strategy, far away from what I was thinking. Catch code should be EMW0, but it is a 2003 Ford upgrade for this 99 car.
It seems that original catch code was UBBA with the hardware I ha expected, but another time, no way to understand why so many references were available for the same car, with probably the same options.
I will provide you the related files coming from the IDS.
For EECIV, it take me months to understand that the first number of the catch code was the year, this is now said.
Now I start testing my created binaries, step by step, because I have still not understood 100% of the related strategies.
To do it I use compatible ECU instead of the original one, to protect the one that is working since many years.
But a question, hardware code is the same, some chips have not the same trademark, but the thing that disturbs me, is the quartz.
In one I have got an E4VF-AA NDK8949 and in other one I have got an E4VF-AA NDK9009. Are they both 15mhz quartz ? Why have we this difference ?
Pym
Hacker
Unread postby jsa » Tue Jun 27, 2017 5:01 pm
Look at the number on the top of the silver can near the processor. It is the oscillator with frequency written on it. Part number could just be different for Intel Vs Motorola processor, but both functionally the same.
Cheers
John
EEC-IV GHAJ0 ANTI or COSY
Unread postby Pym » Wed Jun 28, 2017 4:54 am
Yes, for me this is the oscillator, but no frequency on it, only different numbers (probably year and week, but always ending with 9 ?). A sample is in attachment.
Pym
Hacker
Unread postby jsa » Wed Jun 28, 2017 5:14 am
I see what you mean now. Any markings on the end opposite the wire leads?
Cheers
John
Unread postby Pym » Wed Jun 28, 2017 7:07 am
jsa wrote:I see what you mean now. Any markings on the end opposite the wire leads?
Nothing more written on them, but I have opened 2 more VM120 ECU. This should really be the year and the week, I have 9005 (1990 week 5) and 9001.
I can not imagine 4 different frequencies on the same hardware.
Pym
Hacker
Unread postby decipha » Wed Jun 28, 2017 10:46 am
no worries,
if the hardware code is the same that means all the internals are the same/interchangeable as well
Unread postby Pym » Thu Jun 29, 2017 1:56 pm
Yes, it is working fine, for now I see no difference, the engine is working as expected with it.
Pym
Hacker
Unread postby Pym » Wed Jul 05, 2017 1:34 am
Now I am trying to correct fuel quantity on this management, because I am using injectors 35% bigger than original ones.
To do it I am updating the fuel ECT table (Load-MAP vs ECT) and the fuel RPM table (Load-MAP vs RPM). This should be enough for my expectations.
Sorry for these names, as I have already said it was a strange management.
But this fuel calculation is always based on a table (that I have always linked with injectors), even for startup,
but for which I have difficulties to give a name or a meaning and it is related to its numbers.
I do not understand why they are high at 1700, 2800, 4500 rpm and low between.
This table could be very interesting to update.
I attach a screen copy of it. Have you ever seen such a table ?
For information, its fuel load parameter is a result of itself mixed with MAP, ECT, ACT and other things. Cells are divided by 2.
Do not forget it is an old management, without Landa sensor and adaptive learning and without MAF sensor.
Pym
Hacker
Unread postby jsa » Wed Jul 05, 2017 4:20 am
The lo slope and hi slope scalars should be changed to the new injector specs.
Got to wonder about how Interpolation is done ?
Cheers
John
Unread postby Pym » Thu Jul 06, 2017 12:24 pm
Yes, it would be the best way to process, if I was not based on stage 1 version and if I had found injectors slopes.
But stage 1 has not updated injectors slopes, mainly the fuel ECT table (Load-MAP vs ECT) and it is working fine like this, since more than 20 years.
Not the best way to do it but it works.
Pym
Hacker
Unread postby jsa » Thu Jul 06, 2017 2:54 pm
All the transients will be off until the slopes are done.
Are you able to log anything out of the eec yet?
What does the MAP transfer look like?
How about the other related functions and tables?
Cheers
John
Unread postby Pym » Thu Jul 06, 2017 3:55 pm
jsa wrote:All the transients will be off until the slopes are done.
Yes if it is managed in this way, but I do not think so.
I have not ordered the quarterhorse for now, I try to obtain results without it first.
You will find attached all tables involved in fuel calculation and the MAP transfer. Two more tables exist but are deactivated in calibration.
Other functions involved are, like tables, justs multipliers around 100%. Anything else is calculation.
The table that I have called fuel flow correction, is the base of the calculation, even for the startup.
Yes, really difficult to compare with a zetec management.
Pym
Hacker
Unread postby jsa » Thu Jul 06, 2017 7:07 pm
First off, do not base your approach on what they do in chips. It is likely the chip hackers do not understand why the changes they made worked in some way, It is probable you understand better.
What you have called Fuel Flow Correction- Load VS RPM does not make sense to be so aggressively changing fuel for many of the load-rpm intersects.
Is the fuel pressure regulator referenced to manifold pressure?
Load axis up to 100%, is that perload, is there a table that gives MAP VS RPM with Load output to 200%?
The MAP transfer is showing negative numbers, is that a result of the formula you are using or is the underlying data signed?
Should you keep MAP units consistent throughout, Hg" for example.
In the absence of Hi & Lo slopes, there is some scope for trimming the injector characteristics by changing lines 2 through 10 of MAP transfer.
The table you call Fuel Standard Multiplier Fuel Quantity - Fuel Load vs RPM, appears to be MAP Hg" VS RPM.
In MAP VS RPM and ECT, MAP rows go to 0.83 why not 1.133 like MAP Transfer?
If you can get logging up and running, it would allow you to bench test input changes, see the RAM values change and back track to the code that references that RAM location. You can attack the problem from both directions.
Cheers
John
Unread postby sailorbob » Fri Jul 07, 2017 12:32 am
The 0SALTXA/C strategies use a single injector slope (A0).
What you are calling the 'Fuel Flow Correction' is probably the VE table and you need to check your conversion as I've only seen Ford use 0-100% for the values.
The MAP transfer table defines the pressure very simply, it only has two output values of 0.88 psi (input 0.000 v) and 30.94 psi (input 4.865 v and 10.240 v).
sailorbob
Tuning Extraordinaire
Unread postby Pym » Fri Jul 07, 2017 12:33 am
It is a bit easier for me to start on these chips, especially because of the security cut which is removed, but yes my last goal will be to rework it based on original management.
Screenshots are coming from the original management.
Yes "Fuel Flow Correction- Load VS RPM" stays still strange to me. No electric connection exists for fuel pressure regulator and it is fully linked to MAP.
The related Load axis takes in its calculation this table itself plus MAP, RPM, ECT, ACT. 100% is my adaptation for its scaler.
No negative value for MAP transfer originally, I just prefer to see vacuum and boost everywhere.
Table "Fuel Standard Multiplier Fuel Quantity - Fuel Load vs RPM" is using the whole result of the "Fuel Flow Correction- Load VS RPM" table, including MAP multiplication.
Its scaler has not enough rows, but the interest of this table seems really light for me.
Yes MAP table scaler is not using the highest values of the MAP sensor. Nothing is managed in tables over 0.83 bar of boost pressure, but results are always multiplied with MAP.
Originally, car run boost at 0.5 bar, with the security cut at 0.8 bar, so it seems logical to me, to be more accurate and to prevent having more rows in tables.
For now I have prepared 2 more binaries to be tested, one to run less rich at maximum boost pressure and another one, to manage the use of a 2.5 bar MAP sensor in replacement of the 2.0 one.
But yes, I will need logging, to identify other parameters and validate the ones I am not sure about.
I still need to identify ICV management to understand it, Boost valve management to modify it and other things.
The best way to to it, it to monitor error management in EEC, when elements are plugged / unplugged.
And I still need to understand, why many things were deactivated in calibration (same thing on 0FAC, 1AFA, 1ADA which use the same core).
Have they put this type of management in other cars (not for me), do they have planned to do it and make it evolve (for sure),
but they were probably stopped by the ecological rules in 1993.
Pym
Hacker
Unread postby Pym » Fri Jul 07, 2017 2:57 am
sailorbob wrote:The 0SALTXA/C strategies use a single injector slope (A0).
This should correspond to my 'Injector Flow Rate' scalar, multiplied by this 'Fuel Flow Correction'/'VE' table result or not if you are telling that its value is A0.
sailorbob wrote:What you are calling the 'Fuel Flow Correction' is probably the VE table and you need to check your conversion as I've only seen Ford use 0-100% for the values.
Conversion is currently a division by 2, by 4 it should match, but what a strange VE table. I known that CVH engine has not the best efficiency, but holes like this for certain RPM, I have never seen this on other VE tables.
Nothing it added to its result, before or after, it is just multiplied.
Pym
Hacker
Unread postby decipha » Fri Jul 07, 2017 10:49 am
the VE table on some strats does have a multiplier scalar
Unread postby sailorbob » Fri Jul 07, 2017 12:54 pm
'A0' is the Ford PID name for the 'Injector Slope'.
Whilst the table does not look like a typical VE table you can see the 'VE Multiplier for ACT' (aka FN305) and 'VE Multiplier for ECT' (aka FN326) multipliers before its lookup and the 'Engine Displacement' (aka BASEMD) and 'Airmass Flow Multiplier' (aka KVEFF) multipliers after it in the code.
sailorbob
Unread postby Pym » Fri Jul 07, 2017 1:42 pm
sailorbob wrote:'A0' is the Ford PID name for the 'Injector Slope'.
'Airmass Flow Multiplier' (aka KVEFF)' can not be something like 8000 ? For me all rounded scalars like 8000, 4000, 1000, ..., 80, 40, 20, ... were used for conversion or related calculations.
I have always though that this references (aka FN305, aka BASEMD, aka KVEFF) were related with Binary Editor.
Are you using some kind of Ford reference like for the 'A0' ? Is it available somewhere ?
Pym
Hacker
Unread postby decipha » Fri Jul 07, 2017 4:40 pm
those are the actual ford PID names
theres some strat docs floating around
Unread postby Pym » Sun Aug 13, 2017 12:39 am
I have not found documents on this subject for now, I will try to match with available definitions.
Another thing, I have starting working on ATAFHE(3) strategy (97), it should not be an Euro specific strategy, but not sure about this.
This one is for the ford 2.5 6 cylinders available on Ford Mystique, Contour, Mondeo, Mercury Cougar and so on. It should be near AKAM(?) strategy.
I have a question on the subroutines arguments, especially for functions.
SAD disassembly gives an argument encoding E 4 and find properly function addresses.
It seems to work like argument encoding E 2, so I am able to recalculate function addresses,
but I have not found how the second parameter was calculated and same thing for SAD.
For example :
9 2bd1: ef,49,fb call 271d UUWordLU(Func78,176);
9 2bd4: 7e,cf,76,01 #args
9 2bdd: ef,3d,fb call 271d UUWordLU(Func79,1314);
9 2be0: 62,cf,14,13 #args
I can not identify register addresses for 176 (RPM) or 1314 (Load).
Other information.
rbase f0 2060
rbase f2 2348
rbase f4 25c8
rbase f6 36de
rbase f8 3ee4
rbase fa 4824
rbase fc 4f56
rbase fe 63f4
Rd2 = 280;
Rd4 = 380;
Rd6 = 680;
Rd8 = 880;
Rda = 980;
Rdc = a80;
Rde = 1080;
Re0 = 1180;
Re2 = 1280;
Re4 = 1380;
Re6 = 1480;
Re8 = 1580;
Rea = 1680;
Rec = 1780;
Any idea on this encoding ?
Pym
Hacker
Unread postby decipha » Sun Aug 13, 2017 9:24 am
u have to go to that 271d routine and see how its using those arguments
Unread postby jsa » Sun Aug 13, 2017 2:13 pm
Pym wrote:I have not found documents on this subject for now,
https://eectuning.org/forums/viewtopic. ... 60#p118899
Cheers
John
Unread postby Pym » Tue Aug 15, 2017 12:19 am
Thank you, this Electronic Fuel Injection Strategy Book was the one I was searching for and google has not been my friend in this case.
To come back to this E 4 encoding, it seems that only the function address is encoded, not the value provided. This value is used directly used for comparison.
But this value is not properly translated in disassembly, I have to transform the register address to match something usable.
For example [176] <=> Rd0 (a discrete FF value) + [176] <=> R77 (not so easy to understand), [1314] <=> [Re2+94].
Pym
Hacker
Unread postby decipha » Tue Aug 15, 2017 8:57 am
make aure u have in your dir file
rbase e2 1280
make sure u put all the rbase addresses at the very top of the dir file so it is done first
Unread postby Pym » Wed Aug 16, 2017 6:24 am
I have tried it and the result is the same. They are not exactly Rbase, but the issue is coming from the fact, that these shortcuts (I will call them like this) use signed bytes in addition.
Re2 = 1280; Re4 = 1380;
I was wrong [1314] is not [Re2+94], but [Re4+94] = [Re4-6c]. This is probably the reason, why Sad is not able to match them and why I was not able to do it at the beginning.
Pym
Hacker
Unread postby jsa » Sat Aug 19, 2017 3:20 am
Pym,
Rather than pollute the SAD bug thread, I'll continue discussion here.
Your KBAN7H4 at 224kb exceeds Ford's binary at 216kb.
Attached is Ford's and two later in the series.
Cheers
John
Unread postby jsa » Sat Aug 19, 2017 4:00 am
  Sub714:
0 8843: f2                pushp                push(PSW);
0 8844: b0,58,46          ldb   R46,R58        R46 = R58;
0 8847: 37,46,1e          jnb   B7,R46,8868    if (!B7_R46) goto 8868;
0 884a: 45,6e,00,f4,34    ad3w  R34,Rf4,6e     R34 = 27a8;
0 884f: a1,75,0a,36       ldw   R36,a75        R36 = a75;
0 8853: b1,2d,46          ldb   R46,2d         R46 = 2d;
0 8856: b2,35,38          ldb   R38,[R34++]    R38 = [R34++];
0 8859: c6,37,38          stb   R38,[R36++]    [R36++] = R38;
0 885c: 15,46             decb  R46            R46--;
0 885e: d7,f6             jne   8856           if (0 != R46) goto 8856;
0 8860: c7,e8,14,00       stb   0,[Re8+14]     [Re8+14] = 0;
0 8864: c7,e8,15,00       stb   0,[Re8+15]     [Re8+15] = 0;
0 8868: b0,83,24          ldb   R24,R83        R24 = R83;
0 886b: 39,24,30          jb    B1,R24,889e    if (B1_R24) goto 889e;
0 886e: 9b,ff,a4,02,00    cmpb  0,[Rfe+2a4]
0 8873: df,29             je    889e           if (0 == [8c0e]) goto 889e;
0 8875: a1,3c,23,36       ldw   R36,233c       R36 = 233c;
0 8879: a0,97,38          ldw   R38,R97        R38 = R97;
0 887c: 10,08             rbnk  8
0 887e: ef,2d,a0          call  28ae           Sub376();
  Sub376:
8 28ae: f2                pushp                push(PSW);
8 28af: 8b,36,04,38       cmpw  R38,[R36+4]
8 28b3: db,06             jc    28bb           if ((uns) R38 < [R36+4])  {
8 28b5: 65,04,00,36       ad2w  R36,4          R36 += 4;
8 28b9: 27,f4             sjmp  28af           goto 28af; }
8 28bb: 71,df,6d          an2b  R6d,df         R6d &= df;
8 28be: a2,37,3a          ldw   R3a,[R36++]    R3a = [R36++];
8 28c1: a2,37,3c          ldw   R3c,[R36++]    R3c = [R36++];
8 28c4: 6a,36,3a          sb2w  R3a,[R36]      R3a -= [R36];
8 28c7: 6a,37,38          sb2w  R38,[R36++]    R38 -= [R36++];
8 28ca: 6a,36,3c          sb2w  R3c,[R36]      R3c -= [R36];
8 28cd: d6,05             jge   28d4           if (R3c < [R36])  {
8 28cf: 91,20,6d          orb   R6d,20         R6d |= 20;
8 28d2: 03,3c             negw  R3c            R3c = -R3c; }
8 28d4: 6c,38,3c          ml2w  R3c,R38        R3cL *= R38;
8 28d7: 8c,3a,3c          divw  R3c,R3a        R3c = R3cL / R3a;
8 28da: 35,6d,02          jnb   B5,R6d,28df    if (B5_R6d)  {
8 28dd: 03,3c             negw  R3c            R3c = -R3c; }
8 28df: 66,36,3c          ad2w  R3c,[R36]      R3c += [R36];
8 28e2: 71,df,6d          an2b  R6d,df         R6d &= df;
8 28e5: 71,ef,6d          an2b  R6d,ef         R6d &= ef;
8 28e8: f3                popp                 pop(PSW);
8 28e9: f0                ret                  return;
Cheers
John
Unread postby Pym » Sat Aug 19, 2017 4:46 pm
Yes, my KBAN7H4 version is the 216kb Ford version extended to 224kb + 2 banks swapped to be recognized by SAD.
TSAD seems to give the same result.
Subroutines at 273e, 277c, 27ba, 27f8 are XXByteLU subroutines, 2836, 2872, 28ae, 28ea are XXWordLU subroutines, but are not recognized like this.
Subroutine at 2926 is well recognized as UUByteLU and UUWordLU for 2972. Everything on bank 8.
Difference between these subroutines is near nothing, but seems to generate the issue and no directive can force recognition and functions identification.
I have no interest on this strategy, except using its ignition map and its manifold volume on my ATAFHE3.
It is easier when main part of the functions are identified, because ignition is processed a bit differently, based on calculation or based on its returnless fuel system, I do not know for now.
Pym
Hacker
Unread postby Pym » Mon May 07, 2018 3:53 am
I finally started to rewrite a proper version for strategy 0SLT(XA) more known as 0FAB.
For history, I was using a modded version, based on classical chips used since 25 years.
No way to get smart results with that, even if it works fine at 90%.
Ignition advance is "well" done, but fueling is updated in tables directly, including VE table, ignoring injector slope update.
It was certainly done quickly on a dynamo-meter on a specific setup.
Maximum boost, security cut and over boost management are managed by patches, which I wanted to clean up too.
I have an issue, with this boost management, it can be managed properly up to 1.13bar in code (originally 0.870 bar) on a 2bar MAP sensor.
Over that, it is a bit complicated, I have to deactivate over boost (or it will have no high limit), reactivate security cut or reuse the patches.
The best thing to do is to put a 2.5bar MAP sensor, patch only one place (to permit using values greater than 1.13bar in a table and this time it is a home made one)
and another time, to extend management to 1.5bar (no need to get higher on standard compression).
So my question, does anyone has the weber marelli MAP transfer function for 2.5bar MAP sensor which can be found on some specific Escort Cosworth and why not the 3.0bar one too found on Sierra ?
Same thing for the BAP voltage.
I can recreate them, it is really linear, but specifications are not really accurate, if I compare them to known MAP transfer functions.
Pym
Hacker
Unread postby jsa » Mon May 07, 2018 5:30 am
Are they not frequecy like other Ford MAP and BAP?
Cheers
John
Unread postby Pym » Mon May 07, 2018 6:26 am
jsa wrote:Are they not frequecy like other Ford MAP and BAP?
Yes, you have refs APS or PRT 02/03 (2Bars Sierra, Fiesta and other brands), 05/01 (3Bars Sierra and other brands), 06 (2.5Bars Escort T35 and other brands) and finally 03/03 (1Bar).
They are all analog sensors and always used on weber/marelli management, except for Fiesta.
Pym
Hacker
Unread postby Pym » Fri May 11, 2018 11:53 am
I have searched for this MAP transfer, had a look at related disassembled binaries and found nothing, it should work differently, not a chance to find an usable MAP transfer function.
Anyway a basic MAP transfer 0v = 0.061b and 4.865v = 2.5b does the job for 2.5b MAP sensor, when you know its accuracy, it is more than enough.
Some additional calculations, to adapt voltage limits and this part is OK.
But I have tested updates on Injectors slope and results are horrible. Goal is to go from 18lbs/h to 25. After 21 car is not working in stabilized mode, but still too rich at WOT.
This is because I am wrong, it is not Injectors slope, this scalar should be related with Airmass, but to be clear, I think there is no Injectors slope stored as scalar on this management,
like on others of this period. Injectors slope seems hard coded and the only way to deal with it (without changing code), is really to update related tables or a dedicated multiplier.
Knowing the number of calculations that are inactivated by flags and the fact that this strategy was created for one car / one engine, I begin to have doubts on its interest.
Pym
Hacker
Unread postby jsa » Sun May 13, 2018 12:33 am
Is it just doing an interpolate between min and max MAP values?
Or is it taking MAP volts and looking up a function that outputs some sort of Air Mass value or further still some sort of fuel pulsewidth subject to RPM and ACT ?
Cheers
John
Unread postby Pym » Sun May 13, 2018 8:41 am
jsa wrote:Is it just doing an interpolate between min and max MAP values?
I have seen different MAP headers for some tables with a direct conversion, probably directly volts => bars, so the second idea is the good one.
To come back to my injector slope, I have still not found the right solution.
It is easy to identify on "modern" strategies (GHAJ0, 92ED1, GSAZ1, ...), but not in my case, code is the same for (0SLT.., 9WNQ.., ...).
I am searching for a multiplier or a divider, just before injector command, but I can only see subtracted values.
I will have to play with some kind of AFR calculated register to deal with it. If you have another idea...
Pym
Hacker
Unread postby Pym » Sat May 19, 2018 12:24 pm
OK, I begin to understand how it works, it seems to be based on A9L principle.
Airmass is calculated, then single slope (the one I had identified at beginning) divides it and with constants it provides timing.
Then some kind of AFR calculation is done (in fact fuel air ratio), that will multiply previous result.
The issue is that, before outputting, additional things are taking into account.
- A minimum constant timing is added, probably related to offset.
- Another constant timing is added to, probably related with a fake break point.
- Finally battery correction is added.
Without updating everything, without real reference, impossible to get proper result.
I have still to confirm it after new tries (when the result will be good).
Pym
Hacker
Unread postby jsa » Sat May 19, 2018 4:07 pm
Are the extra constants global adders and multipliers that allow an overall tuning tweak to fuel?
From what I have seen in general, a number of fuel trims are done in the background for the slower changing parameters like temperatures, evap purge, etc. Then tweaks in foreground before firing the injector.
Are the loaded and stored ram values used in more than one place? Are they calculated and stored by one subroutine then loaded by another subroutine that tallies up the final value?
Cheers
John
Unread postby Pym » Sun May 20, 2018 12:55 pm
jsa wrote:Are the extra constants global adders and multipliers that allow an overall tuning tweak to fuel?
Extra constants are only used as adders at the end of the calculation, they should directly affect fuel tuning, but the results are really light, their importance is not so big.
Globally the same thing for 4 different strategies, between 1988 and 1992, everything is semi sequential injection, everything uses same injectors (or their replacement references with small differences on scalars),
3 strategies are full closed loop, one uses lambda sensor on closed / open loop and a different engine displacement.
To describe where registers are calculated and stored, it is not really complicated, I will give you an example of what I have understood, if it really uses a VE table, registers come from one strategy :
- Air Mass is calculated (with each required information, strangely including CO correction) => [124]
- Air Mass is multiplied by a coded constant and divided by Injector Slope (Except when engine starts) => [180]
- Desired AFR is calculated essentially based on tables and functions, related with ECT/ACT/MAP/RPM/... => R68
- Extra constants are trans coded as ticks (strangely only when some constant flags are set or not) => [214]
- [180] is multiplied with R68 and prepared with itcks related routine to provide main injector information in ticks => [312] line to open and [310] for the other.
- Acceleration injection adder is calculated based on TPS and other information and multiplied by another coded constant and divided by Injector Slope and finally trans coded as ticks=> [300]
- Main injection routine, based on flags, dispatches that on registers for each line, using [310], [312], [300], [214] and battery correction [2a6] as adders and pushes vectors based on flags => [228 => 244] including line to open and previous values
- Vectors select the right registers to provide to HSO routine and call it.
It seems really simple, but adding 40% (real injector difference) to what I think is Injector slope, generates really lean idle or stabilized mode (if not stalling).
Updating constants to raise [214] value, changes nothing, the main result is done by raising Battery correction [2a6] by 80% to stabilize everything.
On my daily stable version (which is not really clean), only VE tables and expected AFR are changed.
OK, to expect AFR 14.8 at idle to provide 13.5 at real and 15.3 at WOT to provide 12.5 is not the best thing to do.
Pym
Hacker
PreviousNext
