looking for help with 8061 code
Unread postby jeeptech77 » Thu Apr 19, 2018 10:09 am
Hello can anyone help me find the tom lawrance 8061 dissembler
and direct me to information on using it correctly.
my second thing i need to find and correctly learn how to operate is PCMX
i am working with eec4 la3 bin
i have tried the sad dissembler and have been told it does not work with la3
i have also tried the tuner cats dissembler and have yet to get it to work it is unknown if it will work with la3
thanks for any guidance
Jason Davis
jeeptech77
Vehicle Information: 1988 ford thunderbird turbo coupe la3 ecu quarterhorse and binary editor
Re: looking for help with 8061 code
Unread postby jsa » Thu Apr 19, 2018 3:31 pm
Hello Jason,
Post up your LA3 bin.
It is Bill Lawrence not Tom.
I can send you the BL disassembler.
SAD is now up to V3.06, which version did you try?
Have you tried SAD806X V1.2?
Yes CATS seems useless for anything other than GUFB.
Cheers
John
EEC-IV GHAJ0 ANTI or COSY
Unread postby decipha » Thu Apr 19, 2018 3:56 pm
last i knew the bill lawrence disassembler wasn't functional and required some users input before it would function correctly, i know derek fenwick sailorbob and michael patton mpatton made updates to it over the years, no idea where its at now or what its up to, I use SAD as i prefer the listing
anywho, the disassembly write up on the homepage will give you all the specifics
Unread postby jeeptech77 » Fri Apr 20, 2018 6:07 pm
jsa it was my mistake typing tom instead of bill i had it wrote down .
if you could send it my way i would really appreciate it .
as far as the sad version i used i got it off the write up decipha has here i have since deleted it as i was told it will not work .
i could see in the header that it loaded the bin but that's all it would do i am open to suggestions
thanks jason
jeeptech77
Unread postby ranga83 » Fri Apr 20, 2018 8:43 pm
LA3 (2)_lst.txt
just had a look, SAD looks like it will work. attached is the initial output file
ranga83
Vehicle Information: 1996 EF Falcon 4.0 inline 6, 4TAD ecu, tunerpro, and moates q/h
Unread postby jeeptech77 » Tue Apr 24, 2018 7:48 am
ranga83 thank you ! i found the link to sad downloaded it and i can see it load the bin but what it dissembles is little compared to what u posted
https://github.com/tvrfan/EEC-IV-disassembler
do you have any pointers as to what i may be doing wrong ?
jeeptech77
Unread postby motorhead1991 » Tue Apr 24, 2018 8:14 am
SAD only works one way (yes, I'm the same Motorhead from EECTuning). Post up the output so we can compare I the two.
motorhead1991
Unread postby jsa » Wed Apr 25, 2018 5:31 am
Here is the BL disassembler and help file.
It is harder to use than SAD806x or SAD.
Cheers
John
Unread postby jsa » Wed Apr 25, 2018 5:51 am
Cheers
John
