Methanol / N2O / WBO2 Code - GUFB
Unread postby decipha » Fri Apr 17, 2015 10:39 am
Its been long over due that someone come up with some code to get efficient control of the ecus for added "accessories" lol
Ive been plugging away at GUFB over the past 3 days and am about half 55% complete with the special decipha code for all the goodies listed above
Im currently stealing a few ram addresses and hopefully a few that are unused to make the code work
If anyone has any info on these registers let me know
99 im using as a mask
98 im saving minimum act
4d im saving min fuel error
Im swiping LAMMUL and the filtered egr locations too, and using the am1 and am2 outputs to trigger the n2o and meth
oh and btw, i moved over to 0xA000 (8000) for the code, so from here on out i declare 0xA000 ~ 0xA500 as deciphas special code location
Re: Methanol / N2O / WBO2 Code - GUFB
Unread postby decipha » Fri Apr 17, 2015 2:08 pm
I need one more word of ram, anyone have any suggestions?
Unread postby decipha » Sat Apr 18, 2015 10:30 am
I decided to snatch 325, i cant find where its used so hopefully itll work out
Unread postby sailorbob » Sat Apr 18, 2015 10:57 am
I wouldn't use that address as it's part of one of the HSO queues.
sailorbob
Tuning Extraordinaire
Unread postby decipha » Sat Apr 18, 2015 11:30 am
whoa!
so i cant use any of those 4 addresses
damn it man
ill keep hunting
thanks, if it comes down to it i can make it a static calc, not ideal though
Unread postby decipha » Sat Apr 18, 2015 1:40 pm
how about using 1AE through 1B3
those look to be used to store dtc's
Unread postby sailorbob » Sun Apr 19, 2015 5:15 am
Those are fault filter count addresses so you don't want to be trying to use those.
sailorbob
Unread postby decipha » Sun Apr 19, 2015 5:40 am
yea i figured worse case it would just set faults
Its hard to find free ram
how much free ram does cbaza have?
Unread postby sailorbob » Mon Apr 20, 2015 12:39 am
No idea if CBAZA has any spare ram addresses. Probably not much, if any, as it's got one of the most full roms of all the eec-iv's.
sailorbob
Unread postby decipha » Mon Apr 20, 2015 5:06 am
yea thats what i was thinking, plus they have some serious trans payloads too
maybe its time to just give up on these old ecus lol
Unread postby decipha » Mon Apr 20, 2015 8:52 am
hey derek how does GURE look as far as ram?
Unread postby sailorbob » Wed Apr 22, 2015 1:24 am
I don't know enough about GURE to comment with any authority, it's not one I have spent much time looking at.
sailorbob
Unread postby decipha » Mon Apr 27, 2015 8:00 pm
so ive decided to bypass a bunch of the sub routines from the vector list in an attempt to gain a few bytes of ram
appears as though now i need a guinea pig, anyone with a gufb ecu wanna be the test mule? Preferably a high rpm revving engine
Unread postby xr4x4ti » Tue Apr 28, 2015 7:38 pm
I will when I get my car back on the road in a few weeks
xr4x4ti
Vehicle Information: Turbo 327, A9L
Unread postby xr4x4ti » Tue Apr 28, 2015 7:39 pm
What did you bypass ?
xr4x4ti
Unread postby decipha » Tue Apr 28, 2015 9:05 pm
a bunch
Unread postby decipha » Tue May 05, 2015 6:00 pm
n2o code is done, finished it today
Imma let the man review it and if he approves ill post it
There are 4 pins that must/should be wired up, all grounds
1) boo brake on/off pin, disables n2o during power braking
2) knk input pin, ground this pin to allow the n2o code to run
3) sc bypass pin / AM1, this pin grounds the n2o solenoid to spray the juice
4) SIL, I have the shift light output coming on when it actives the n2o so u can see its active
the knock input is questionable, Id rather use the octane bar but I cant find its port, on GURE i found it at D1, thats a scratch ram for gufb, anyone have any info?
Unread postby decipha » Sun May 10, 2015 11:08 pm
making some minor adjustments and hoping to have this a-go this week
Unread postby decipha » Sat May 16, 2015 9:23 am
n2o code is in its final stages of completion, I'm about to revise it a touch and shoot it back to the man for his approval. Once he gives it the go its on like donkey kong!!
Unread postby decipha » Sat May 16, 2015 6:57 pm
just sent it off for approval again
we shall see !!!
Unread postby xr4x4ti » Tue May 19, 2015 2:37 pm
Does this initial N2O code include the WBO2 or that "phase 2"?
xr4x4ti
Unread postby decipha » Tue May 19, 2015 3:06 pm
yea it includes wbo2 reference, if it leans out it will shut off the n2o
