Wideband Setup - Logging Inputs Write Up
Unread postby decipha » Thu Nov 17, 2016 12:21 pm
Re: Wideband Setup - Logging Inputs Write Up
Unread postby decipha » Tue Mar 07, 2017 8:59 pm
Ive decided its best to use the superlogger for logging inputs for additonal widebands oil pressure fuel pres etc...
Unread postby Landho » Tue Mar 07, 2017 11:48 pm
Thanks!
Also - for us newbies - some clarifications. In BE, it's Transfer Functions... where you map EVP to AFR (assuming using EGR, in BE from either data logging or User pref screen - click Transfer Functions, select Ch 1 Transfer Function, choose EVP, then assign to AFR)
Supperlogger is a Moate product, http://www.moates.net/superlogger-p-304.html?cPath=31 (am I allowed to link? I am not a sponsor nor do I own this product {yet})
Check your wideband ground, too... Innovative MTXL .. I had a weird issue getting my wideband to dial in, causing me to chase exhaust leaks and other areas for several hours ... I got frustrated and decided to work on electric fans for a while - I moved my fan wiring around, specifically the ground for the fan relay was same post (behind dash) as ground for wideband. After change, wideband was all of the sudden relatively in-line with what I expected to LAMBSE. Maybe it was my fan relay, or something else... regardless, as the instructions say don't steal power from other sources for the wideband, I suggest to not leverage common ground posts or at least try another ground post if you're having weird issue with wb output.
Also - BE folks - Probably everyone knows this... but, I didn't ... so - when using BE to log with wideband and trying to use the dashboard to view AFR, be sure to right-click on the AFR cell in the BE dashboard and select config - then choose AFR as the tag (or whatever name you assigned to your transfer funtion to assign EGR or whatever to wideband input). It's also possible when you license your wideband and install the license than, for some odd reason, your user preference setting for "save datalogs with calibration" may get checked ... and you'll complain to BE developer that your logging isn't working anymore, when in fact it is saving to the location of your saved calibration.
Landho
Premium Member
Vehicle Information: 1969 Ford Bronco, poor man's frame-off restomod.
Dart 347 stroker, forged, zero balanced w/ Dart Iron Eagle heads, b303 cam, scorpion 1.6 roller rockers, A9L EEC, Shorty headers (for early bronco),2.5" pipes y-pipe into magnaflow, 30# injectors, Explorer gt40-ish style intake w/ 1" plenum spacer (to clear tall valve covers), PMAS HPX w/ 3" blow through tube. no smog. Innovative MTX-L2 wb o2, Tweecer RT, Binary Editor
Vehicle 2 Information: Part Bronco... '72
Vehicle 3 Information: Tuned lifted 2013 Expedition driver.... tuned, cold air, cat-back
Additional Vehicles: 2017 Jeep Rubicon, 4.5" lift, 35" tires - boring!
Unread postby decipha » Wed Mar 08, 2017 12:48 am
yep link away this is the users forum we need not worry what other forums require
good tip, all grounds should always be filtered tĥough the chassis as outline in the pre tune info, that being said, motors are very electrically noisy due to their windings, they should never be tied in to anything
Unread postby dukes62gal » Sun Mar 12, 2017 5:39 pm
How do I set up a transfer for an Autometer WB with 1.30 lambda at 0V and 0.70 lambda at 4V (MAX)?
dukes62gal
Vehicle Information: 88 Mustang GT, 302, Hellion Turbo kit, 78mm Turbonetics "Benita", ProComp heads, TF street heat intake, Crane 2030 cam, 1.6 RR, 70mmTB, Deatchwerks 78lb. inj, GS-340/255 lph pump, Blow through HPX Slot MAF in 3" housing, Tremec 3550, 3.55, A9L, Moates QH v1.6, Tunerpro RT, Autometer WB
Unread postby decipha » Sun Mar 12, 2017 6:37 pm
what software are you using?
Unread postby dukes62gal » Tue Mar 14, 2017 5:17 am
Tunerpro
I tried to figure out the calculation using the steps outlined on Moates website, but the 4v max instead of 5v must have thrown me off. Your WB02-C is the closest match I could get, but obviously it is still off.
dukes62gal
Unread postby SlowBox » Sun Mar 19, 2017 10:54 pm
Decipha,
If the EGR position range is 0-52535, why do you divide the payload by 12,800 to get voltage instead of 13,107? I made an equation for my LM-1 and I'm curious why you did what you did.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby decipha » Mon Mar 20, 2017 11:05 am
2^16=65536 / 5.12 maximum volts = 12,800
Unread postby SlowBox » Mon Mar 20, 2017 12:20 pm
Excellent. I'll need to change my voltage correction then to dial the equation back in.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby Willy87 » Tue Aug 01, 2017 9:39 pm
I have an AEM wbo2 and I'm now learning to tune with TunerProRT. I read in your wide-band write-up that you can right click on the dashboard on the "Wbo2-LC1" gauge and select the AEM wbo2 in a drop down. I'm having trouble finding this drop down option. When I right click the gauge I see edit gauges or values. Do I need to go into edit gauges and just add the gauge? Or am I missing something and there's a pre-set list for the AEM wideband?
Willy87
Premium Member
Vehicle Information: 1991 Mustang 5.0 , A9L ,Moates Quarter horse and TunerPro RT.
aem-uego
Unread postby decipha » Wed Aug 02, 2017 1:49 am
download the latest universal adx file off the homepage for eec-iv
go to the dash make sure eec-iv dash is being view and not the eec-v dash, its the default dash so it should pop up first, anywho, wbo2-aem is the wideband, it should show up right in the middle of the screen already, you can right click on it and select an lc1 plx etc... aem is the default though
be sure to download the latest gufx xdf off the homepage too, i added some things to it just last night, you will have to remove the universal adx patch and re-enable it to get the latest and greatest goodies
I must admit im fuckin tickled with where i finally got her, i went from a foxbody to my marauder using the same ADX, its so nice
Unread postby Bad86capri » Wed Aug 02, 2017 2:26 pm
Speaking of the Marauder. How do you like it?
Bad86capri
Vehicle Information: 86 Capri T-Top. Oxford white, grey trim and canyon red interior. 306 with twisted wedge heads, Anderson b3 cam, holley systemax intake, ev6 30lbs inj., c&l 80mm maf, 70mm tb, longtube headers. Im currently using a plx wideband mounted in the driverside header. Tuning with moates quarterhorse and BE although sometimes i play around with Tunerpro
Unread postby decipha » Wed Aug 02, 2017 3:01 pm
its a comfortable car, she does pretty good on economy too i can knock down 20mpg with the cruise set at 85mph, ill prob b driving her up to indianapolis this year for PRI
Unread postby Thefoxmulder » Wed Feb 07, 2018 9:38 am
Decipha,
About to install the QH in the car for the first time. I have a ZT-3 Zietronix WB in the car already so I was going to try and use the analog out from it.
In case the image derps out:
V AFR
0 = 9.6
1 = 11.9
2 = 14.2
3 = 16.4
4 = 18.7
5 = 21.0
I've read the wideband/input page a million times. I know you don't list the ZT-3, but I was trying to figure out how to calculate it correctly over to Lambda. Any help would be appreciated.
Thefoxmulder
Vehicle Information: 1993 5.0
A9L
F303
Windsor heads
5 speed
Explorer intake
Bolt ons
19lb EV6 inj
94/95 MAF
Stock intake
65mm Accufab TB
Unread postby decipha » Wed Feb 07, 2018 2:08 pm
that chart you posted is incorrect according to the zt-3 manual
http://www.zeitronix.com/installation/Z ... ctions.pdf
using the analog out 0-5v (white wire) on the zt-3 the default output is:
0 == 9.6
5 == 19.6
according to them their output equation is:
AFR == 2* (Volts 0-5) + 9.6
they reference 14.7 as stoich
thus, referencing the logging page http://efidynotuning.com/config.htm the equation comes out to
( 2 * (X / 12800) + 9.6 ) / 14.7
which simplifies down to
1.333 - 0.653 == 0.68
0.68 / 5 == 0.136
0.136 * (X/12800) + 0.653
anywho, i added it to the adx and to the wideband write up
enjoy
Unread postby Thefoxmulder » Thu Feb 08, 2018 7:05 am
Thanks Decipha.
I really appreciate all of the help and effort you put into building the site, A9L2, and everything to go along with that. My first start was ridiculously good for a first try. Idled better than it ever has.
I'll load the new ADX and get the WB hooked up this weekend.
Thefoxmulder
A9L
F303
Windsor heads
5 speed
Explorer intake
Bolt ons
19lb EV6 inj
94/95 MAF
Stock intake
65mm Accufab TB
Unread postby decipha » Thu Feb 08, 2018 9:55 am
cool no prob I do what i can
Spartan2 Transfer?
Unread postby KLRPMKN » Sat Oct 13, 2018 12:02 pm
I'm just getting my feet wet and getting all my data in order. Sorry for the newbie question.
Using a Spartan2. The unit did not come with transfer data but according to their website, "Linear Output: 0[V] @ 0.68[Lambda] linear to 5[V] @ 1.36[Lambda], 10[AFR] linear to 20[AFR] equivalent for gasoline." That's all Ive been able to find on this controller.
Is it as simple as this?
Volts Lambda
5.12 1.36
5.00 1.36
2.50 1.02
0.00 .68
0.00 .68
Is this accurate? And will it be a sufficient number of data points for TP to log lambda correctly?
KLRPMKN
Vehicle Information: 87' Mustang 5.0 (Converted 4cyl car)
A9L2/GUFX
Quarterhorse w/Tuner Pro RT
88' Engine harness converted to MASS Air w/Pro M harness. VSS, Fuel V+, Fan Control pinned to ECM.
Vehicle 2 Information: 04' Cobra- "The Pumpkin"
Unread postby decipha » Sun Oct 14, 2018 8:17 am
tunerpro requires no user setup, you simply right click the wbo2 gauge and select your wideband from the drop down menu
your wideband uses the plx transfer
more details
Unread postby KLRPMKN » Sun Oct 14, 2018 10:00 am
Excellent. Thank you for the confirmation!
KLRPMKN
A9L2/GUFX
Return to General Hardware
Users browsing this forum: No registered users and 8 guests
