Injector Data
Re: Injector Data
Unread postby decipha » Fri Jul 08, 2016 11:56 pm
its not that big of a deal, you can put any value in there and dial it in regardless no problem
Re: Injector Data
Unread postby CrashD1n3r » Thu Jul 14, 2016 2:39 pm
Looking for Siemens Deka 80lb/h high impedance short style A2C32624700 for a 3.7 Mustang. I've been looking for a while but cannot find the info. Thanks!
CrashD1n3r
User
Vehicle Information: 2012 Ford Mustang 3.7 with 3.5 Ecoboost turbo and manifolds.
Re: Injector Data
Unread postby decipha » Thu Jul 14, 2016 7:38 pm
I use the shorties almost exclusively these days, its the exact same as the long body
Re: Injector Data
Unread postby CrashD1n3r » Thu Jul 14, 2016 8:54 pm
That's awesome thank you!
CrashD1n3r
User
Re: Injector Data
Unread postby StangD » Sun Jul 24, 2016 5:34 pm
This is a double post. I hit up the SN95 forum as well. Kill the other one if you like.
Bosch Type III EV1 24lb red body
PN LRS-37263
Stock Fuel Pressure
CBAZA-TM40
12.1 @119.50 NA
StangD
Supporting Member 25
Re: Injector Data
Unread postby decipha » Sun Jul 24, 2016 6:53 pm
i have nothing on the red 24s never seen or tuned a set before
Re: Injector Data
Unread postby StangD » Sun Jul 24, 2016 7:50 pm
Thanks, I'll do some more digging, or grab info from an older style and go from there.
CBAZA-TM40
12.1 @119.50 NA
StangD
Re: Injector Data
Unread postby rangerswap » Tue Aug 02, 2016 2:05 pm
Any info on Bosch 0-280-156-161? They are ev6, 12 hole, 240cc/24lb, bright red and are oem on 99-07 focus I believe.
rangerswap
Vehicle Information: 2001 Ranger with 1999 explorer 5.0l, 4r70w, EQE2
Re: Injector Data
Unread postby StangD » Tue Aug 02, 2016 4:13 pm
I misspoke when I asked a few days ago. Mine are the red skinny EV6 style 24s as well. Not EV1s. If you don't get a better answer I found slopes near advertised flow were about right. I'm still tuning but HI 23 and Low 24.5 is in the ballpark. I used the offsets etc from 42 greens which I have in another car. Hardly a precision answer but it will get you started if you don't'get a better one and have to do it the hard way.
CBAZA-TM40
12.1 @119.50 NA
StangD
Re: Injector Data
Unread postby rangerswap » Wed Aug 03, 2016 4:30 pm
Thanks for the info. Still looking for data on these. May have to do it the hard way like you said. First time changing a tune so I am still learning.
rangerswap
Re: Injector Data
Unread postby decipha » Wed Aug 03, 2016 5:36 pm
SBDC4 strategy / EKQ4 stock data - 2003 2.0L focus
ahisl 17.918
alosl 24.744
offset
16 0.947
15 0.947
14 1.033
13 1.171
12 1.322
11 1.503
10 1.743
8 2.505
6 4.658
0 4.658
looks to be 17lb injectors on the focus
Re: Injector Data
Unread postby rangerswap » Wed Aug 03, 2016 8:22 pm
I double checked and these injectors are rated at 240cc@3bar which would be about 24lbs@43.5psi. Application is for the 03-07 2.0/2.3 focus. Was there a high output version of that car?
rangerswap
Re: Injector Data
Unread postby StangD » Fri Aug 05, 2016 3:50 pm
rangerswap wrote:I double checked and these injectors are rated at 240cc@3bar which would be about 24lbs@43.5psi. Application is for the 03-07 2.0/2.3 focus. Was there a high output version of that car?
Yes, they had a turbo Focus. Model ZX3 I believe.
CBAZA-TM40
12.1 @119.50 NA
StangD
Re: Injector Data
Unread postby nanserbe » Thu Aug 25, 2016 12:07 pm
Anyone have the information for Ford F1TE-D5A 24lb injectors?
nanserbe
Vehicle Information: 1989 Mustang, TunerPro RT. converted to 5-Speed, A9L2 with Moates QH, Stock bottom end, Trickflow TW Heads (170s?), Trickflow Stage 2 cam, Siemens Deka 60lb injectors @ 40psi, 75mm PMAS MAF, electric fan, 180* T-stat, no A/C or Smog
Re: Injector Data
Unread postby decipha » Thu Aug 25, 2016 1:25 pm
i believe those are the stock injectors used on the 7.5L 460 engines in the trucks and the 93-95 cobra's
info is on the homepage
Re: Injector Data
Unread postby nanserbe » Thu Aug 25, 2016 2:26 pm
decipha wrote:i believe those are the stock injectors used on the 7.5L 460 engines in the trucks and the 93-95 cobra's
Sweet, thanks!
I'll start with this:
Low Slope 24.839
High Slope 24.839
Breakpoint 0.00001001
nanserbe
Re: Injector Data
Unread postby 89gtsleeper » Mon May 01, 2017 9:19 pm
Buddy has some injectors he believes are 24 lb. came from junkyard off a 2000 Lincoln.
Ev6 style... very dark gray. Really need injector data on these. Coming up empty.
Xr3e-c5b
0280155865
212416
89gtsleeper
Vehicle Information: '88 LX Notch w/ AOD & 4.10 gears
Stock 302 bottom, 6-7 lbs. Vortech V-1
Mass Air Conversion with A9P
QH/BE with my own modified A9P tune
Re: Injector Data
Unread postby decipha » Thu May 04, 2017 3:50 pm
those are stock injectors from a 2000-2003 Lincoln ls
do you know what vehicle they came out of specifically?
Re: Injector Data
Unread postby pitcockb1 » Mon Jan 22, 2018 9:09 am
I just got PMAS INJ60 injectors, and they come with static flow charts (39psi, 50psi 60psi) but no slopes.
is there an easy way to convert the charts to slopes?
it's in lb/s @0-10ms pulses
so the 10ms(100%?) i just multiplied out my 3600 (60x60) and got ~66lb
it shows the breakpoint as .002lb
but if i do the math on the 2 low slope numbers they give me (60psi in the "example" im about to explain) , i get vastly different numbers.
(i'm at work right now so I dont have the sheet unfortunately, but can provide around 5pm)
the low slope numbers come out to ~8 and ~12 which when multiplied out by (10/1.32 and 10/1.62) i get either 50lb or 77lb at 60psi for the low slopes.
pitcockb1
Vehicle Information: 1995 mustang GT 5.0
Cobra intake w/ 1"spacer
trickflow 170 heads w/ compcam rockers 1.6 ratio, AR3924 plugs
24#frpp lu24 injectors
O/R X pipe w/ jegs 2 chambers
C&L MAF
65mm throttle body
stock block
Re: Injector Data
Unread postby decipha » Mon Jan 22, 2018 10:10 am
the slopes are a number
post the data u have and we can take a look
Re: Injector Data
Unread postby pitcockb1 » Mon Jan 22, 2018 11:03 pm
ok, here's what I have
39psi
PW FLOW#/s
.98 0
1.21 0.001283
1.33 0.002075
1.5 0.002417 BKPT
2 0.003725
2.5 0.004608
3 0.005583
3.5 0.006644
4 0.007594
5 0.009494
6 0.011394
7 0.013294
8 0.015194
9 0.017094
10 0.018994
43.5psi
PW FLOW#/s
1.05 0
1.34 0.001662
1.45 0.002442
1.5 0.002767 BKPT
2 0.004017
2.5 0.004875
3 0.005783
3.5 0.0068
4 0.0077
5 0.0095
6 0.0113
7 0.0131
8 0.0149
9 0.0167
10 0.0185
50psi
PW FLOW#/s
1.11 0
1.51 0.0024
1.62 0.003583
2 0.004 BKPT
2.5 0.005108
3 0.006192
3.5 0.0073
4 0.0084
5 0.0106
6 0.0128
7 0.015
8 0.0172
9 0.0194
10 0.0216
at 50psi I'm doing some mathematics and getting 77.76 for the high slope and 72 for the low?
pitcockb1
C&L MAF
65mm throttle body
stock block
Re: Injector Data
Unread postby decipha » Tue Jan 23, 2018 1:03 am
can u post how u arrived at that?
I wont be able to be any help
best bet would be to just dial them in
were those all done at the same voltage? if so the 0 flow is your offset but did they give u any of the remaining offset data?
Re: Injector Data
Unread postby pitcockb1 » Tue Jan 23, 2018 7:09 am
yeah, they gave me an offset table as well.
for the high slope, i took the 10ms pulse and multiplied it by 3600 (60seconds in a minute, 60 minutes in an hour) giving me the lb per hour at what i'm assuming is 100% DC
the low slope, i took the breakpoint, and multiplied it by 3600 (getting into hours again) and then multiplied it by (10/2) (assuming 10ms is 100% DC, and 2ms would be a 20%DC)
the low slope was where i was getting confused, because if i used the two points they give me below the breakpoint, then i get way different results. one will be 79 the other will be 56, which is why i'm using the breakpoint now.
The math works on all the flow numbers if you make sure to multiply out the percent duty cycle assuming 10ms PW is 100%. So all the numbers above the breakpoint give a similar outcome (slight variances)
for 39psi i got 68 hi slope and 58 low slope
for 43psi i got 66.6 high slope, and 66.08 low slope
I was hoping someone knew of a program or something to input the flow data and spit out slopes. I think EEC analyzer has a flow table like that in the fuel injector section, but I don't have a license to test if it will turn that data into slopes.
pitcockb1
C&L MAF
65mm throttle body
stock block
Re: Injector Data
Unread postby decipha » Tue Jan 23, 2018 8:58 am
nor do i
it looks like at 39.5 psi at 6 it should be 0.01xxxx, looks like you left out that 0
typically the low slope should be higher than the high slope
i don't get the data, according to what you posted, the injectors flow more at 39.5 psi than they do at 43.5 psi ??
according to the data they gave you the injectors look to be most linear at 50psi over the breakpoint, in both the 39.5 psi and the 43.5 psi flow data there was a 15% fluctuation in the slope above the breakpoint, at 50% it was less than 1% where it went almost perfectly linear over 2ms
10msec does not correspond to 100% duty cycle, in all of the data lists they gave you the injectors went perfectly linear over 4msec, the slope of linear flow / time is .0019 0.0018 and .0022 respectively
since you listed it as flow/s and i broke it down in to a msec
.0022 flow/s per msec * 1000 (msec in sec) == bring it back to 2.2 flow/s <<whatever unit thats in
* 3600 (lbs/sec to lbs/hr) == 7920 flow/s per lbs/hr
if we assume thats supposed to be 79.20 lbs/hr that would mean your injector flows 32% more than advertised at 50psi which is very improbable
best bet is to hit up PMAS and see if they have any injector data, if you get in touch with the owner nick tell him to call decipha he has my cell #
Re: Injector Data
Unread postby pitcockb1 » Tue Jan 23, 2018 9:52 am
the flow is in pounds per second. sorry, that's what the "#/s" was meant to convey.
pitcockb1
C&L MAF
65mm throttle body
stock block
Re: Injector Data
Unread postby decipha » Tue Jan 23, 2018 9:59 am
it can't be, that would equate to 7,920 lbs/hr, if divided by the msec that would give 7.92 lbs/hr
I assure you neither of which is correct unless im way out in left field some where
Re: Injector Data
Unread postby pitcockb1 » Tue Jan 23, 2018 10:37 am
i think what it means, is if it does 10ms pulses for a second it will flow that much. which is why i was taking the pound per second number and multiplying it by 3600, and not multiplying by another 1000.
so for the 50psi
at 10ms PW(a full second of 10ms pulses maybe?) , it flows .0216 lb of fuel per second.(x60)
1.296lb per minute (x60)
77.76lb per hour.
which seems reasonable to me, but i sent out a message to PMAS, so we should hear back soon i hope.
pitcockb1
C&L MAF
65mm throttle body
stock block
Re: Injector Data
Unread postby decipha » Tue Jan 23, 2018 11:05 am
77.76/60 == 1.296
there's no way the injector flow capacity increased by 30% with just 10psi more pressure
Re: Injector Data
Unread postby pitcockb1 » Tue Jan 23, 2018 11:08 am
.0216/.018994 = 1.137 (~14% increase 39psi -> 50psi)
pitcockb1
C&L MAF
65mm throttle body
stock block
Re: Injector Data
Unread postby decipha » Tue Jan 23, 2018 11:31 am
.018994 * 3600 == 68.37
you thinking its really a 68 lb/hr injector?
Re: Injector Data
Unread postby pitcockb1 » Tue Jan 23, 2018 12:09 pm
as nice as it would be, probably not. I'll wait to hear back from PMAS and let you know what they tell me.
pitcockb1
C&L MAF
65mm throttle body
stock block
Re: Injector Data
Unread postby ironmanisanemic » Tue Jan 23, 2018 2:14 pm
Here is a good article explaining how ford injectors are characterized. http://injectordynamics.com/articles/fo ... erization/
This should help you understand your flow chart.
ironmanisanemic
A+ Contributor
Vehicle Information: 89 Ford Bronco - 393W, Professional Products 190cc heads, Custom Comp Cams hyd roller cam, Edelbrock EFI Mustang intake, 10:1 compression, 30lb TrickFlow injectors, ProM 80mm Mass Air Meter, 2-1/2" into 3" y pipe, no cat, and hooker aerochamber muffler. U4P0 computer with Quarterhorse and BE, EA. AOD with all of the goodies.
Re: Injector Data
Unread postby decipha » Tue Jan 23, 2018 2:43 pm
no rly its rather useless just basic knowledge
Re: Injector Data
Unread postby Helomech74 » Mon Feb 05, 2018 1:12 pm
Could I request the unscaled data for a set of Deatschwerks 88lb injectors going in my 98 Cobra. The data that was programmed into my Pro-M EFI I believe is totally wrong. I just need the high and low slope and breakpoint.
Helomech74
Vehicle Information: 1998 Mustang Cobra, Pro-M EFI
Re: Injector Data
Unread postby decipha » Mon Feb 05, 2018 5:48 pm
deatsch dosnt post their flow data to my knowledge
I have no info on them
Re: Injector Data
Unread postby Helomech74 » Tue Feb 06, 2018 9:47 pm
Yeah, they keep referring me to their spreadsheet for the Ford Data, but I need unscaled data, the spread sheet doesn't do anything for me since it's geared more towards SCT. Thanks anyway. I'm going to just use 83 for the high slope and 95 for the low slope to start since I'm running 39psi base pressure and I believe their injectors are tested at 3 bar.
Helomech74
Re: Injector Data
Unread postby decipha » Wed Feb 07, 2018 1:34 pm
the sct data is for a ford that would be the data you need
simply multiply the injector slope by 3600 and that will convert it from lbs/sec to lbs/hr
60 sec * 60 min == 3600 seconds to hours
Re: Injector Data
Unread postby Helomech74 » Fri Feb 09, 2018 12:13 am
This is the data they have for these injectors, there's other data on the spreadsheet for different deltap numbers, but this is the main info they keep referring me to.
40 psi 55 psi
Fuel Injector Breakpoint 0.0000100 0.0000125
Fuel Injector High Slope 0.0247500 0.0312280
Fuel Injector Low Slope 0.0596350 0.0742300
Fuel Inj. Min Pulsewidth 0.0002500 0.0002500
Max Allowed Inj Duty Cycle 1.999 1.999
If I multiply the high slope numbers by 3600 I get 89.1, but the low slope number comes in at like 214.6 and there's no way that's correct. The car is running decently right now with the High slope set at 83 and the low slope set at 91, I just hate not having the correct data. I've been back and forth with their customer service with no luck.
Helomech74
Re: Injector Data
Unread postby Chris42163 » Sun Feb 18, 2018 11:53 pm
Need injector info on
Trick Flow 120 lbs/hr injectors
A little digging says these are:
Delphi 621061
Lucas 01D136B
Accel 74120
Actually 111 lb/hr @ 43.5 psi
I found one source: https://www.fiveomotorsport.com/lucas-1 ... rs-01d134b
Claims: 3BAR, 14v dead time: 0.455 ms
Another forum post claimed an entire range of volts to IO times, but they do not jive with the above source:
8 1.36
8.8 1.21
9.6 1.07
10.4 0.92
11.2 0.79
12 0.73
12.8 0.67
13.6 0.71
14.4 0.72
15.2 0.68
16 0.63
16.8 0.54
17.6 0.48
18.4 0.42
19.2 0.33
20 0.27
I don't know if anyone still uses these forums, but it would be amazing to get some help with these injectors since I have 2 cars running them. Thanks!
Chris
Chris42163
User
Vehicle Information: 91 turbo Mustang LX
331 c.i. Dart
AFR205
TFS-R Box
FTI Custom Cam
Precision GT42R-76mm Compressor
880 rwhp
Vehicle 2 Information: 93 turbo Mustang GT
363 Dart
AFR205
Super Victor Intake
Jay Allen Cam
Precision GTS76
954 rwhp on E85
Re: Injector Data
Unread postby motorhead1991 » Mon Feb 19, 2018 11:49 am
Not that anyone wants or needs the Ford data for stock 14lb injectors, but decipha does have it if you do.
motorhead1991
PreviousNext
Return to General Hardware
