IRCM mod?
IRCM mod?
Unread postby korn_kid_12 » Thu Jan 04, 2018 8:52 pm
I read this in the pretune write up. I am trying to understand what is being requested. I have a 1995 Mustang which has the control module between the water pump and the radiator. I assume this is the IRCM. "On vehicles equipped with a IRCM - Ignition Relay Control Module, the fuel pump relay trigger should be tapped prior to the module and ran to an external high amperage relay with a minimum 10 gauge wiring ran to the fuel pump and relay. The relay power feed is recommended to be ran to the alternator charging post for the greatest voltage achievable. This is required on all high performance vehicles." Is there a write up on how to make this modification? By the way I also run an external Vortec fuel pump. 190lph in tank.
korn_kid_12
Vehicle Information: 1995 GT Saleen Clone, Cobra Intake, SCT BA3000 MAF, Stock short block, Ported e7's, MAC long tubes, MAC O/R H pipe, MAC cat back, MSD 6a, Blaster coil, accel cap and rotor, FMS 9mm wires, , Vortech V3-SI, F-303 cam, Anderson Power Pipe, Innovate LC-2, Quarterhorse with tuner pro rt and other goodies.
Vehicle 2 Information: 2016 F250 6.7l Power Stroke
2011 Lexus IS250 F Sport
2001 Stingray 200LX
1995 Macgregor 26s
2004 AquaTrax R12x
2006 AquaTrax F12x
2010 Ford F150 SCREW FX4-(Traded in 4/12/2018)
1991 Mustang GT Restored and 5 speed swapped (Sold 12/31/2017)
Re: IRCM mod?
Unread postby SlowBox » Fri Jan 05, 2018 10:12 am
No write up needed. The stock IRCM is barely enough for the stock fuel pump. Anything bigger and you need to put it all on a bigger relay. Just tap the stock trigger wire and run your new wiring.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Re: IRCM mod?
Unread postby decipha » Fri Jan 05, 2018 2:16 pm
the fuel pump trigger wire comes from the ecu its usually the same wire color up to the ircm, u can tap it at the ecu if its easier for you
Re: IRCM mod?
Unread postby korn_kid_12 » Sun Jan 07, 2018 9:46 am
Would it be reasonable to use the 10 or 8 gauge Wire I have running to the Trunk from the battery for the external pump and the trigger wire I am using for the external pump relay to add a second relay and power the in tank pump with it. So basically run both pumps from the same battery and trigger wire with 2 different relays.
korn_kid_12
2001 Stingray 200LX
1995 Macgregor 26s
2004 AquaTrax R12x
2006 AquaTrax F12x
Re: IRCM mod?
Unread postby decipha » Mon Jan 08, 2018 2:54 am
yea no problem
Return to EEC-IV Tuning
