mongoose BE 5.122
mongoose BE 5.122
Unread postby p4ndiamond » Sat Feb 10, 2018 6:47 pm
The problem arises when I try to read the calibration on the EEC. When I press read it asked me to turn off the ignition, which I do. BE then warns me to plug my laptop in. I press OK and it asks me to turn on the ignition within 10 seconds. I flip the "ignition" switch and nothing happens. After 10 seconds it aborts.
I can read codes from the ecm and it works fine. I managed to get it to read code from the ECU one time but it still pulls errors about the code but all values show ok. Any attempts to write erase the ECU but wont write back to it. This is happening on both vehicles. possibly something wrong with the Mongoose itself ?
p4ndiamond
Vehicle Information: 97 cobra W. Temporary (NPI swapped)
Hi tech stage 2 cams
Vortech V7 JT trim @ 10lb
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
3.73 Gears Detroit true trac
Mac o/r H Borla pro xs 2.5"
Re: mongoose BE 5.122
Unread postby decipha » Sun Feb 11, 2018 2:22 pm
make sure nothing is on the j3 port
otherwise something is screwy with BE it would seem
Unread postby p4ndiamond » Sun Feb 11, 2018 9:54 pm
Yeah J3 port is clear.
Did a reset of the BE but still got that issue.
When it does read the file size is correct and states that something is missing but the file itself is intact and refuses to write back . seems its missing something that identifies that its writing to the correct ECM . i cant recall the error code it was
any word on Tuner pro having the ability to write. or are there any other programs that will write a BIN file to the ECM through the mongoose
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby decipha » Mon Feb 12, 2018 7:06 am
i use pcmflash from the getting started write up but i need to talk to oleg about adding 2 bank support. it only supports 4 bank as of right now.
Unread postby p4ndiamond » Mon Feb 12, 2018 7:22 pm
How much is pcmflash . I saw Forscan also . how do you get that with the key. it asks for a hardware code but not sure what to put there.
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby decipha » Tue Feb 13, 2018 7:08 am
forscan doesn't support flashing as far as i know unless they added it in, last i tried it wasn't supported
for pcmflash you get the key sent in from oleg in russia, when it comes in you simply plug it in install the app and register it, theres a bit of a delay cuz the registration has to be sent through email but its no big deal
again, pcmflash is not supporting 2 bank flashing as of right now but i'll be working on that soon
Unread postby p4ndiamond » Tue Feb 13, 2018 7:20 pm
sweet that makes sense to me.
i may check that pcmscan out . seems like its legit. I have a 4 bank car also which would be perfect for it .
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Do you have a specific procedure order you use for hooking up the mongoose. just covering all my bases to ensure i am doing everything correctly. For reading and writing.
p4ndiamond
pi intake
NPI heads
4r70w Jmod
DDX4 Ecu on QH
Unread postby decipha » Tue Feb 13, 2018 8:22 pm
nope just plug it in
Return to EEC-V & SN95 Tuning
cron
