FBFG2 datalogging
FBFG2 datalogging
Unread postby adfosterm3 » Wed Feb 07, 2018 8:34 pm
Anyone have a matched xdf and adx for fbfg2?
Mine used to work and now its not. Tried the archived xdf files with the adx I have and have had no luck.
adfosterm3
Vehicle Information: 1999 Ford Mustang v6 with full 04 v8 swap Fgfb2 strategy, quarterhorse
Re: Fgfb2 daralogging
Unread postby decipha » Wed Feb 07, 2018 8:49 pm
make sure u enable datalogging in your tune before u try to log
get the adx that matches the date of your xdf and all will be well
soon as i get time im updating all the datalogging to dma with the latest universal adx
fbfg2 will be last as i use fbgi0 in lieu of it more often then not
Unread postby adfosterm3 » Wed Feb 07, 2018 10:11 pm
I have enabled it prior. My adx doesn't have a date, just says decipha.adx. I try to use any other fgfb2 adx such as 08032017 it just give a null values
adfosterm3
Re: FBFG2 datalogging
Unread postby decipha » Thu Feb 08, 2018 5:25 pm
post your current tune file i'll patch it and post it back
Unread postby adfosterm3 » Thu Feb 08, 2018 11:45 pm
Tried again today when I was off. Started with a completely new tune on a stock bin. Got everything adjusted and setup right and car starts. Soon as I apply the daralogging patch it does the dashes on the odometer and constant running fan with endless crank. My tablets recharging at moment. Will post file tomorrow with my rough draft of what I have done so far
adfosterm3
Unread postby decipha » Fri Feb 09, 2018 6:03 am
just as the patch comments say the engine has to be off before applying the patch
Unread postby motorhead1991 » Fri Feb 09, 2018 10:05 am
decipha wrote:just as the patch comments say the engine has to be off before applying the patch
This is because you're rewriting sections of the console routine. Ever played with a core function on a computer while the OS is booted up? Same thing.
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation
Unread postby adfosterm3 » Mon Feb 12, 2018 8:00 pm
Did it with engine off, when done uploading I turn the key and dashes and constant fan
adfosterm3
Unread postby decipha » Tue Feb 13, 2018 7:06 am
that means your xdf datalogging patch code is corrupt, use the newest fbfg2 xdf from the homepage
Return to EEC-V & SN95 Tuning
