Begineer Help, EEC-V with QH, no live data?
Unread postby SirRex » Sun Dec 31, 2017 9:48 pm
I am new to this and am looking for some help. I just bought a new Moates QH, a used EEC-V ECM ('04 CrownVic CBR2), and downloaded TunerProRT.
I have the ECM setup with a bench power supply and have the QH installed and connected to my PC but I am unable to see any data. No sensors are connected to the harness, but I would still expect to see battery voltage. When I connect an ELM327 device to the PCM, I am able to see battery voltage. So I would expect to see this in TunerPro as well.
Did I miss something in the setup process? I set the ADX patch. I tried both RZRSA and FBFG2 strategies and uploaded them with a stock bin.
The only other odd thing I noticed is that when I downloaded the stock bin, the bites written was only 32768 bytes. The getting started write up noted 262,144 k. Is this a bad ECM? Would this matter if the QH is performing the strategy?
SirRex
Vehicle Information: 1990 Mustang LX 5.0
Re: Begineer Help, EEC-V with QH, no live data?
Unread postby witnlyn » Mon Jan 01, 2018 11:07 am
not sure but you might of missed a power wire on your bench harness. just a thought.
witnlyn
Premium Member
Vehicle Information: 1999 Mustang, 5.0L transplant
Unread postby decipha » Mon Jan 01, 2018 1:00 pm
did you enable the datalogging patch before writing the tune?
there is nothing that says bytes written when uploading so u must be doing something wrong
read the getting started write up on the homepage and post back what u were doing wrong
Unread postby SirRex » Mon Jan 01, 2018 1:34 pm
Sorry, My bad. I used the wrong terminology and could see how it was misleading.
When I read the stock chip (tune) to buffer and then saved that to a file, TunerPro stated the size was only 32,768 bytes written.
This is in contrast to what I read in your getting started article, that it should be 262 kB.
SirRex
Unread postby witnlyn » Fri Jan 05, 2018 9:08 pm
Did you get it figured out?
witnlyn
Premium Member
Unread postby SirRex » Sat Jan 06, 2018 1:44 pm
I figured out why the stock bin was only 32 kB. I didn't change the buffer end address to 0x03ffff as the getting started article stated. Now it is 256 kB and I have no reason to believe there is something wrong with the used ECM.
I still don't have any live data. I apply the patch and transfer the bin to QH. I will continue to troubleshoot and post what I am doing wrong when I figure it out.
SirRex
Unread postby witnlyn » Sat Jan 06, 2018 2:19 pm
still using bench harness? Do you have power to pins 55,71,97 and ground 24,25,51,76,77,103? some wires maybe spiced together in harness already. eec-v
witnlyn
Premium Member
Unread postby decipha » Sat Jan 06, 2018 5:01 pm
your the second person with a logging issueother peraon was using rzasa as well
imma post up my current files here shortly to make sure its not outdated files causing the problem
Return to EEC-V & SN95 Tuning
