6-rib to an 8-rib
Forum for discussing engines in general, anything engine and not tuning-specific belongs here, such as power adder discussions (turbos, blowers, nitrous, meth / water injection, exhaust setups, etc...)
6-rib to an 8-rib
Unread postby RIKIL » Mon Apr 03, 2017 10:00 pm
A while back I sourced and made some parts so I can use an 8 rib belt on my supercharger. I am just now getting around to installing the new parts and I have a question about the pulley that attaches to the crank:
the original pulley is 6.5" diameter and the new pulley I have is 7.0" diameter. This is about 15% larger in circumference. The pulley on the supercharger is the same diameter. What effect will the 15% bigger pulley have? It'll push more air but is it something I should not do (and find a 6.5" pulley)? Need to change the tune?
RIKIL
++Premium Elite Member
Vehicle Information: Red, 1992 F150, 351W, 4R70W, Vortech V-2 Si trim blower, Snow Performance water/meth injection system, custom cam, Edelbrock Performer intake, Twisted Wedge 205cc heads, shorty full-length headers, MASS Air (converted), tuning with CBAZA / QuarterhorseRT, 4x4, short bed, 33" tires
Re: 6-rib to an 8-rib
Unread postby decipha » Tue Apr 04, 2017 11:57 am
thats 15% overdrive you have now
you need to find the max rated blower rpm and make aure your not over spinning it
its simple math
lower pulley / upper pulley = ratio
ex: 7/3= 2.33
engine rpm *ratio = blower rpm
6200*2.33=14,450
as for the tune you should be good no changes needed there just make sure the extra powah doesnt the take out your fuel system i.e. go lean
Unread postby RIKIL » Tue Apr 04, 2017 8:58 pm
so here's what I came up with...
My blower has a max rating of 52,000 RPM with a 3.61 gear ratio. so...
6.88(crank pulley) / 2.86(blower pulley) * 6000PRM * 3.61ratio = 52105
I found the 6.88 pulley on-line.
For me I think 6000 RPM is high, I will get above 5500 but that is probably it. So I am probably safe here.
RIKIL
Unread postby decipha » Tue Apr 04, 2017 9:56 pm
yep your good, factor in belt slip and your even more legit
them little vortechs make some massive heat when driven though, Id recommend putting at a minimum a 15 and a 10 gph meth nozzle on it both spraying into the blower and never use any less than 50% meth or just use the blue 0 degree rated windshield washer fluid
Unread postby RIKIL » Sun Apr 16, 2017 12:12 pm
decipha wrote:yep your good, factor in belt slip and your even more legit
What do you think the effect would be if I directed a 2" pipe of cold air from the outside directly onto the top, outside of the blower to cool it? I have an intake area which is not behind my radiator.
RIKIL
Unread postby decipha » Sun Apr 16, 2017 2:04 pm
minimal at best
Return to Speed Shop & Engine Talk
