Meth Kits Snow Performance Stage 1
Unread postby bunso » Thu Nov 05, 2015 10:42 am
Anyone have any luck with the Snow Performance Stage 1 Meth Kits? I'm not trying to just be cheap but I like the simplicity of this kit. I have installed of few of the Stage 2's but getting the adjustments right on the controller can be a bitch.
If nothing on these what kits are you guys using and recommend?
bunso
+Premium Plus Member
Vehicle Information: 2004 GT MMR Streetmod 900, On3 76mm turbo, 4r70w. (Still in Process)
Re: Meth Kits Snow Performance Stage 1
Unread postby decipha » Sat Dec 05, 2015 3:10 pm
Ive always use the AIS kits, theyve gone up in price significantly though
If using a pwm controller you can hook it up to the canister purge outout and the A9L2 tune is setup to control it so you van tune the meth in the ecu
Unread postby Fasterthangas » Wed Dec 16, 2015 5:12 pm
I'm considering meth injection if it proves effective for me. I think any hot rod in the AZ heat can benefit unless one is using race fuel or av gas. Our crappy Cali gas doesn't help.
Can my ECU control the meth system? I want to keep the install clean so I'm considering using my window washer fluid bottle. Opinions? Advice?
Fasterthangas
Vehicle Information: CBAZA
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
230/238 @ .050 custom cam
AFR Renegade 185 heads
Ford Racing EV14 34lb. injectors
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
1-3/4" shorty headers into 2.5" duals out the back with H pipe. Jones Maxflow straight through mufflers
Unread postby Fasterthangas » Tue Dec 22, 2015 6:23 pm
Anyone??
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby bunso » Tue Dec 22, 2015 9:41 pm
I cant really give any tuning advice on it honestly but I have installed it on a couple supercharged cars and it helped out the IAT temp issues we were seeing for sure. The main reason I started this thread was to see if anyone had tried the Snow Stage 1. I ended up going with the Snow Stage 2 just because I found it at a steal on Ebay new. Just go with a Stage 1 because its simple and works
Decipha will have to answer the tuning side of things. He will be tuning mine for the Meth here very soon
bunso
Unread postby Fasterthangas » Tue Dec 22, 2015 9:50 pm
Our gas is horrible hear and I suspect meth will help me run more timing and possibly pick up power.
Fasterthangas
'95 Mustang GT
347 SBF
10.0:1 cr
Systemax ll
90mm Lightning MAF
4" CAI
Accufab 75mm TB
G Force T5
3.73's
Unread postby decipha » Wed Dec 23, 2015 12:18 am
on the foxbody ecu i use the canister purge output to control the meth controller
on an sn94-95 its not so easy
you can hook it up to a wot switch
