99 mustang v6 to 5.0HO swap
Non specific forum to post pic's or link(s) to video(s) of your vehicle(s). Be sure to include your goals with your vehicle.
Re: 99 mustang v6 to 5.0HO swap
Unread postby witnlyn » Sat Dec 09, 2017 5:58 pm
Was able to have car idle enough to get warm but my wide band is showing rich .75 to .79. Gauge and dash reading same. don't know where to start to get lambda to go leaner, using stock maf transfer from home page and 42# injector data from home page.
idlelog1.zip
witnlyn
Premium Member
Vehicle Information: 1999 Mustang, 5.0L transplant
Unread postby decipha » Mon Dec 11, 2017 8:26 am
what is your lambse commanding?
double check your fuel pressure if it checks out rape the maf curve to dial the fuel in, then after you get the fuel dialed in compare it to the stock MAF curve to see if its the injectors that need to be dialed in or if its just the maf that needs the love
Unread postby witnlyn » Mon Dec 11, 2017 8:52 am
Ok thanks
witnlyn
Premium Member
Unread postby decipha » Mon Dec 11, 2017 8:59 am
re-read above reply ^^
I edited it so it doesn't say knock curve it says MAF curve lol, my auto-incorrect strikes again
Unread postby witnlyn » Mon Dec 11, 2017 9:41 am
On maf tables you have MAF raw what is that? Does it change when Maf kg is changed?
witnlyn
Premium Member
Unread postby decipha » Mon Dec 11, 2017 12:29 pm
the raw maf function is there for development when you need the binary values, you shouldn't be messing with that, the comments should tell you more
Unread postby witnlyn » Mon Dec 11, 2017 12:41 pm
Thanks. If I get time tonight I’ll see what I can accomplish.
witnlyn
Premium Member
Unread postby witnlyn » Tue Dec 12, 2017 5:17 am
made some progress got lambda up to .94 at idle. lambse is commanding .96. will have to work through rest of maf curve. just to make sure are there any adaptive or tables I need too turn off or set high?
witnlyn
Premium Member
Unread postby decipha » Tue Dec 12, 2017 7:08 am
nope adaptives only close the gap the fuel error factors in the kamrf's
Unread postby witnlyn » Sat Jan 06, 2018 10:14 am
Cooling fan running continuously when ignition is on. Swapped my v6 ccrm to a v8, could that be the cause? If so I’ll have to get another cause can’t find my v6 one probably trash can ate it.
witnlyn
Premium Member
Unread postby decipha » Sat Jan 06, 2018 5:04 pm
yep the ecu signals to the ccrm are different
no need in replacing it simply go in the tune and adjust the low speed invert polarity scalar
Unread postby witnlyn » Fri Jan 12, 2018 9:13 pm
I think my ccrm is bad. Want to test signal from pcm to ccrm for fan control input, what should I be looking for ( low voltage or ground ) from pcm ?
witnlyn
Premium Member
Unread postby decipha » Fri Jan 12, 2018 10:02 pm
depends on how you have it setup could be either
Unread postby witnlyn » Sun Jan 14, 2018 6:18 pm
Took CCRM connector from old harness and hooked up to power to test ccrm. With power on relays engage, when I ground wire that comes from ecm (low fan control input) relay opens. My ecm harness is out of a 2002 gt so have pcm pin for lsf set =0. Have tried both ways with invert fan output but no change. Going to check for sure pin location and other harness connectors for wire locations to see if I have a wire dead headed somewhere.
Also having issue with no power to A/C compressor with dash switch on or off position with pressure switches jumpered, have power up to pressure switches when turned on.
I'm sure it's probably all related
witnlyn
Premium Member
Unread postby witnlyn » Tue Jan 16, 2018 6:52 pm
Had some luck this evening. Got cooling fan working correctly so far (not sure about when a/c is on if it runs yet) but it no longer is on the minute I turn switch on. A wiring issue between ecm and harness, moved pin from 28 to 19 solved it. Now for a/c I did get power to compressor but then it was always hot with ignition on no mater where control switch was set, but I have an idea now what to do. It all boils down to the difference between years in wiring, hope no problems come up with transmission next!! In the spring I'll have Decipha do a remote tune once I get the bugs out.
witnlyn
Premium Member
Unread postby decipha » Tue Jan 16, 2018 7:42 pm
did u flip the ac_rly_is_nc scalar?
if the ac clutch engages with key on or when engine running that switch needs to be flipped
Unread postby witnlyn » Wed Jan 17, 2018 6:23 am
There’s a little bit of a difference in the wiring from 2000 to 2002 that I think my 2000 ecm doesn’t like so going to wire it like 2000 diagram and should be good
witnlyn
Premium Member
Unread postby witnlyn » Wed Jan 17, 2018 11:10 am
Something I noticed while messing around with it in garage (too cold to drive it) when I put it in gear and just idle my afr goes leaner like from .85 to .95. Is that normal?
witnlyn
Premium Member
Unread postby decipha » Wed Jan 17, 2018 3:29 pm
yep
Unread postby witnlyn » Wed Jan 17, 2018 6:31 pm
re wired a/c and works as should, needs charged yet but tests good with engine off. What tells fan to cycle when air is on that didn't happen?
witnlyn
Premium Member
Unread postby decipha » Thu Jan 18, 2018 3:38 am
if the ac isn't charged then the pressure switch is open and the ecu isn't going to engage the clutch on the compressor nor turn the low speed fan on for it
Unread postby witnlyn » Thu Jan 18, 2018 6:21 pm
A/C Charged and Fan works as it should. Have a mystery wire that I'm at a loss as to where it goes. tested with ohm meter to ground.
witnlyn
Premium Member
Previous
Return to Garage & Project / Build Forum
