Page 1 of 2
Telorvek and PTP2
Posted: 2024 Feb 17, 11:31
by ErikM
I have tried everything I can think of... cranks but won't start, no injector pulse. swapped ecu to a WSX2 with RZASA with the PATS patch applied burned to a Moates chip with no luck. Anyone have experience with this setup?
Re: Telorvek and PTP2
Posted: 2024 Feb 17, 11:54
sounds like your either missing the crank sensor input or the injector voltage feed.
What does tunerpro show on the dash while cranking? You should see rpms as its turning over.
Posted: 2024 Feb 17, 12:21
by ErikM
I have power at the injectors, didn't check crank rpm with TunerPro but OBDLink with bluetooth adapter shows crank rpm
Posted: 2024 Feb 17, 16:03
Then you have some issues.
Posted: 2024 Feb 19, 20:19
by ErikM
got it, must have a corrupt burn, reprogrammed again and everything is good
Posted: 2024 Feb 19, 20:51
by ErikM
one more thing, i don't see where to change cooling fan on/off temperature setting
Posted: 2024 Feb 23, 09:55
by ErikM
also, what would cause the trans to ship super fast? like 1 to 4 in 50yards
Posted: 2024 Feb 23, 12:25
check your oss teeth count and make sure your speedo is accurate
Posted: 2024 Feb 25, 13:31
by ErikM
ok, oss was 12 changed to 24. found the fan temp settings... one more question, gear ratio settings. factory would have been 3.27, it has a 3.73 now
Posted: 2024 Feb 25, 14:01
simple change it
be sure to set the vid speedo switch to 0 so it uses the cal values
