Cam designed for EFI vrs carb
nvrstuk
Vehicle Information: '68 Ford Bronco
A9l, Moates Qtrhorse
WOT only - 92uego
Unread post by nvrstuk »
I have a 460sb that I have the opportunity to get a camshaft specifically designed for EFI. Is it worth it as I am looking for HP and torque? I currently run this Comp Cam part # 35-427-8.
If there's no worthwhile gain then I can stay with the Comp Cam I have: part #35-417-8 which Michael has already tuned and works great. IF I can gain enough HP and Torque up to 6K then I'd go with a custom cam. If there's no advantage then why waste the $$ on it and another tune?
Spec's-
460sb
Ford Zheads, high port, 205cc
10:1 static
4.150" bore, 4.25" bore
Used in a 5350# Bronco. Not for racing but I do sand drags 2X/year. Rock crawling and off throttle response is extremely important. 40" tires, 5.13:1 frt/rear ratios, air lockers, tons, etc. This is to help with determining cam benefits
nvrstuk
WOT only - 92uego
Re: Cam designed for EFI vrs carb
242int/248exh
110Lobe seperation
1.65 rockers
No such thing as efi cam an engine is an engine.
Cam isnt going to help you what you need is a small supercharger to get you off the line. A twin screw in the 1.5L range would be ideal. A stock gt500 supercharger would be about perfect if you can fab it up.
nvrstuk
WOT only - 92uego
Asked because I called every aftermarket EFI manufacturer & they won't guarantee their system working with 6.5in of vacuum. They all said they need more vacuum. Hence my question as they all said I needed a cam designed for EFI (like more LSA). I was looking because I couldn't get it tuned good until Decipha did.
Back to a different cam choice. I'm dyno'd at 601hp at 5500 rpm now. Not interested in spinning this stroker more than 6k so is there more HP/torque available with this setup w/o a blower and a redesigned cam? Driveability and dependability is extremely important over a 20HP potential gain that I probably wouldn't ever notice since I'm never (except 2x/year on sand) ever clocking it and never go above 80mph.
Thoughts and thanks for the previous response.
Unread post by red5.0fogger »
That's just because it's an aftermarket system trying cover most bases without tuning. 601 is a lot of steam. You may just want to optimise the torque convertor since you seem to have all other puzzles pieces in order. a convertor too tight down low makes it feel sluggish before the engine really gets rollin'
Sevensecondsuv
1995 F-250 RCLB 4.9/T18/4wd
2000 Excursion 6.8/4R100/4wd
2007 Town Car 4.6/4R75E
2011 Ranger SCSB 2.3/M5OD/2wd
Sounds to me like you need more displacement. A bbf bolts into a bronco and will go 545 cubes with nothing more than a scat crank. Just an idea - obviously starting over on the engine sucks, but hey these are just toys, right?
Blklightning1
Vehicle Information: 2000 Ford Mustang GT
Unread post by Blklightning1 »
I am going to weigh in a little on this post. The cam # you posted is a Extreme Marine cam with only 218 int./224 exh duration @.050, with what I would call mild lift 0.495 int./0.503 exh. on lobe separation of 112 degrees (didn't see lobe centerline listed). Also an "rpm range" of 1200-5200. Pretty mild camshaft if you ask me even for 302CI, hence the "marine" statement, this cam should work well right off idle to a moderate rpm range in a boat, truck or mild heavy street car.
You state I from what I understand is, this is 460 CI "small block" engine using a A9L processor. And only 6.5 lbs of vacuum, I assume in gear! The cam is really mild for 460 CI, - comp cams says its an "aggressive grind" but (for what a 302 or small CI in a heavy boat trying to turn a prop) without seeing all the grind spec's I don't know the amount of overlap ground into the cam, to give much of opinion on the effect on engine vacuum. Which if it's really only 6.5 lbs at idle in "gear" (which leads to why exactly - mechanical reasons or vac leaks, cam not degreed) and yes a lot of efi systems won't like "low vacuum" per se.
If there is an issue with vacuum assisted power brakes due to "low vacuum", that is a separate issue. This cam should produce more vacuum than 6.5lbs vac. from 460 CI, which concerns me as to why. For example; I am running a custom grind in a 351W Turbo F150 combo with 238/242 degrees @ .050 and .565/.575 lift, it holds 13/14lbs of vacuum at 875 rpm in gear with 2400 converter. The 460 CI are "big block" displacement territory and should have a head/intake/cam combo to support that displacement.
You will see generic statements on camshafts listings saying EFI or Carb, NOS, Supercharger or Turbo grinds, which is more of a marketing tool than anything. All cams work "well" in a boosted application etc, just some will be "better" based on the rest of the engine etc.
Lobe separation, Lobe centerline and actual valve events will help cams to work "better" in certain applications. Low vacuum is an issue for speed density and stock programming in mass air systems and will cause idle and low speed driveabilty issues that have to be addressed via tune changes and possible torque converter changes, gearing etc to aid in drivability.
A 112 degree and higher lobe separation usually aids in better idle stability and will help raise the rpm that peak torque/horsepower is produced over a 106/110 LS range on a otherwise same cam grind (valves open overlap). And not by huge amounts either.
But, your seat of the pants dyno may not be able to tell much difference (other than idle/low speed issues) due to so many other factors. Good running (again subjective) engine combo's are just that - a well selected group of parts that complement each other and fit within a specific budget/rpm range.
Just as aa example: I have currently a high compression 408" NOS fogger carb foxbody, Turbo 351W F150 under 15lb boost Fuel Inj, higher boosted supercharged 302 2V Mustang FI, GSXR 750 FI all have had camshafts changes designed for the engine/vehicle application and would not use the same cam profiles.
Hopefully this info helps some as to camshaft selections, which all the cam manufactures have tested and their tech support is a good source of information for general applications. Of course, a custom grind is better (not everyone is qualified in that) and costs accordingly too. Catalog "shelf" cam grinds are for general applications and work OK for the masses.
Justin Jones
Vehicle Information: 1991 Ford Mustang LX 5.0 A9L Explorer Intake - Moss Ported, 70mm TB, 90mm Lightning MAF, 30 Lb injectors, GT40X heads, FTI cam 214/224 .600 1.7 rockers. 10:1 compression.
wbo2_innov_mtx-l
Unread post by Justin Jones »
You listed 2 part numbers: 35-427-8 and 35-417-8. I think you're talking about the first one. The issue I see with it is it's a reduced base circle, retro-fit cam) which isn't bad in itself. But any time the base circle is reduced you compromise the lobe design (ramp rates) a little. I suspect that combined with the 110 LSA might be causing the issues you describe. I hope you asked Ed for a full base circle cam and run the link-bar lifter set.
