Re: A/C On - Surging Idle - Low AFRs
Posted: 2022 Nov 01, 20:47
Check voltage drop from compressor to battery ground with compressor running. It should be close to 0. check your grounds. compressor to engine block, engine block to frame. A bad ground can cause this with voltage backfeeding where ever it can.
