AC functions controlled by the PCM?
Posted: 2022 Aug 06, 19:58
Trying to figure out how to make my MS3 run the stock AC system.
But Im honestly not sure where to start on this, guess knowing the proper function of the whole circuit would help.
Looking over the PCM pinouts you have it seems that theres 3 pins that go through the PCM for the AC system
#41 AC HP
#69 AC wot switch
#86 HVAC
I would wager that #41 and #69 are grounding signals sent to relays in the CCRM to cut power to the AC clutch field.
What does pin #86 do?
#41 AC HP
#69 AC wot switch
#86 HVAC
