Recommendations on custom fab vacuum harnesses and fuel rails
I interested in hearing what you all recommend or do as a means of creating the vacuum lines/harnesses for custom setups or replacements for factory. My car is different so there are no factory vacuum harnesses to use. I came up with something to get things operational but I want a clean if not almost “ almost factory look”. Basically, what is everyone doing to source vacuum “hose” “lines” “fittings” etc? I’m currently of the mind that I just need to buy a bunch of random stuff and spend a bunch of time brainstorming the different combinational outcomes but my brain says there must be a better way. Thanks I’m advance
Re: Recommendations on custom fab vacuum harnesses and fuel rails
vac line is line wire it comes from one spot and goes to another, very simple.
I buy lengths of various rubber hoses and use the assortment packs of fittings if needed or if reducers are needed I prefer bush bushings.
Like these
https://www.ebay.com/itm/192894630008?c ... u2EALw_wcB
and these
https://www.amazon.com/Dorman-47380-Vac ... 998&sr=8-5
Like these
and these
