Page 2 of 2
Re: 2008 Super Snake Failsafe Engine Mode
Posted: 2021 Oct 25, 23:55
by jcbryant
Here is the MTF file I was sent by kenne Bell for this car originally. When I loaded this in the car a year ago to try and turn traction control back on it set the Engine Fail Safe Mode.
SXH15I_11.zip
(516.59 KiB) Downloaded 245 times
Posted: 2021 Oct 26, 08:02
Load the file in i posted and see if it still sets an etc fault
Posted: 2021 Oct 27, 18:16
by jcbryant
Loaded the test tune you posted. Loaded no problem. Failsafe Engine Mode still present. P2104 is gone P0600 is present. Here is a screen shot after programming and checked DTCs
Screenshot (76).zip
(159.14 KiB) Downloaded 246 times
Thank you
Posted: 2021 Oct 29, 13:27
p0600 isn't an ecu problem that means you have another module not working correctly. It should fire up and run albeit not happy since its not setup for any of the stuff on it.
fill out a vehicle info sheet for her and PM it to me and I'll hook you up
Posted: 2022 May 16, 17:32
by jcbryant
where did the post go that had the bin file you sent to tune with pcm flash and mongoose?
Posted: 2022 May 16, 20:25
its in your private thread on the premium member side
